Question about GE WSXH208A Front Load Washer
Computer panel Here I thought I was getting a good machine. I have had this machine for a little over a year and I have the problem with it not draining. thanks. I do have another problem that just started. The cycle stops at 25 min and then you have to push the start button to get it going. Tonight the control panel start humming and the machine wasn't even on. Is the computer panel going? Has anyone had this similiar problem and have a solution without paying a fortune for a repair man?
    President:
  • 1,294 Answers
Your second prob is related to the first. First plug off the wall.
Check your outlet filters, clean out. The machine will not spin if the filter is blocked. Also check your inlet into the machine. Clean screens on both ends of the pipes. Refit carefully. If you have manual, check for filter cleaning.
Re the electrical connection check out your wall socket
Posted on Dec 04, 2007
I have a Pfaff creative 1471. When I turn it on the light flashes across like normal, but the computer display is blank. The normal little reset of the machine does not occur and the machine will not run....
The 1471 is getting on in years. It is not uncommon for the PC board to develop a fault. It can be replaced, however, cost is prohibitive unless you can find a repairer with a 'good' used board.
Good luck
Oct 19, 2013 | Kenmore 15218 Mechanical Sewing Machine
Have kitchenaid undercounter ice maker, came with the house i bought a year ago. the problem is the water freezes in the resevoir. i have replaced the circulating pump, the thermistor, some sensor,...
on the right side of the ice bin and above the cutter grid are 2 sensor plugs, unplug the one towards the rear of the machine (usually has light brown w/red striped wires). if this does not fix the problem then replace the main control board and the transformer. Also the water doesn't go to the grid, it rolls across the evaporator, freezes a slab of ice that then slides down to the cutter grid. the cutter grid should be somewhat warm, it is what cuts the ice into the little squares. I've worked on these machines for around 7 years now and have only seen this problem once, this should fixya
Mar 02, 2011 | KitchenAid KUIS18NNT 18" Automatic Ice...
Have a KUDS24SEAL5 superba and no lights come on after pressing any of the buttons. Power to machine is good. Several months ago it would not start properly by pressing 'start'. Would go directly to...
It sounds like the main control board has gone wacky....
replace the control board
. That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 20, 2010 | KitchenAid Dishwashers
What is appropriate fuel pressure on 1999 Expedtion 5.4 liter engine. Expedition has run great for 9 years. Now will accelerate properly when pedal depressed. Chugs at lower speeds and, also, at hgiher...
you either have a bad sensor or fuel control problem call ford dealer they will give you correct pressure if you speak with maintenance. berrydalewolf
Oct 29, 2009 | 1999 Ford Expedition
Duet washer rubber gasket replacement
ive never taken the front panel off, ill give you its tigth anbd dark, but the clamp inside is removed with a small ratchet( 9/32" is size), its definetly a little aawkward, to undo, adn even more to reattach, butit can be done with A LOT of patience
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bought a dell laptop, 12 month warrantly expired.its not even 2 years. rang for support said the motherboard needs replacing. thought laptops and computers are supposed to last much longer than that.they...
Dear Wezi786.
Have to have more info, What exactly is your computer doing? what brand is it? explain your situation a little bit better in your own words.
a-tripod@hotmail.com
Good Luck
Nov 04, 2008 | Computers & Internet
Fisher and Paykel IW810AU fault code 105
I have found out from a repair agent that the fault code means there is no or corrupted communications between the display and motor drive module.
It may be simple as a loose cable, if the washing machine has been moved recently.
In my case I have a very slow little leak in the hot water solinoid (Bad spelling I know) thus causing it to leak on the circuit board and over time rust the connections. Basically my machine was not worth repair as the main circuit board was a tad too expensive. It was still cheaper than a new one (even after all the extra costs were put into consideration, ie - Labor and transport costs) but my machine is 8 years old and I thought for an extra couple of hundred dollars I could get a new one with warranty.
I know there are people out there bagging these machines, but 8 years out of a item (without any servicing) that uses moving parts, electricity and water is pretty good.
Hope this helps?
cheers
Dave
Apr 13, 2008 | Washing Machines
No power to DL3700 Pro
suspect the power cable, if it's not getting power..just for fun, test that cable on something else first.
Feb 28, 2008 | Office Equipment & Supplies
5 yr old washer is leaking
Ellbee, remove the two screws at the bottom of the front panel and lift it towards you. Two clips on the top that hold it will release. You can now get a good look at the pump. Catriver..post back.
Sep 19, 2006 | Frigidaire GLWS1339C 3.0 Cu. Ft. Top...
GE WSXH208A Front Load Washer Logo
52 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
