Question about Magic Chef CER3725AA Electric Kitchen Range
Oven or smooth top will not turn on. breakers are good and it is plugged in.
  1. the oven nor the smooth top works
  2. when i turn on a burner "20" appears in the display then the clock comes on.
  3. after a few seconds it quits working. nothing ever heats up.
  4. we left the smooth top on by accident then the everything just shut down.
  5. it is not in sabbath or on delay.
  6. the appliance has worked well until today.
  7. is there a reset button or combination of buttons to reset, we tried unplugging the appliance for an hour to reset but still the same.
  • 22 Answers
Unplug the range. Wait a few minutes, then plug the unit back in.  Reset the clock per your user manual. A pdf copy of your manual may be available on line at the Magic Chef site or the Maytag site, since Maytag has or had a similar model.
Posted on Dec 04, 2007
Magic Chief "Chateau" double oven,
I just had the top completely off of our Magic Chief, which I love and refuse to part with, to fix a problem with one of the burner switches. I believe if you pry up gently in the crack in front with a blade, i.e. small pry bar or screwdriver, being very careful to not chip the paint, the top will snap loose from the two prongs that hold it in place. Then if you disconnect the cluster of wires going to the burners, which is very easy to do, (they just plug together) and remove one screw holding the ground wire toward the back, you can lift off the whole top and get to all of the good stuff. I find the quality of our old Magic Chief Chateau to be of exceptional quality, much better than I see today and I'm pleased that our burner problem was just loose screws. Good luck.
Jan 02, 2011 | Magic Chef Kitchen Ranges
Oven quit working . Stove top burners work just
if its an electric start. then the problem is usually the ignitor for oven. if you change this yourself, be carefull they are very fragil. hold on to igniter by its base. slide ignitor into steel case then install. and hook up the 2 wires for ignitor.
May 14, 2010 | Ovens
Clock works, locked door appears and door is locked, burners do not work
locked door appears In the clock display?? this is the eoc telling us that there is a problem with the door interlock or it's system . however this has nothing to do with the top burners/ there independent of the oven system . now when there is a code in the display. the oven will not heat and you may not be able to dor open . this is a job for service tec . turn off power for 15 min. and retry .mm
Nov 22, 2009 | Frigidaire PLEF398AC Electric Kitchen...
I Have the whirlpool Oven RBD306PDQ8 - The power went out in our neighborhood, when it came back on the clock display will not appear. We can set the clock, it stays on the panel for about 10-20 seconds...
When the power came back on, it sent a power surge to the ERC (clock assembly). Try turning the oven breaker off for 10-15 minutes, this is to reset the ERC. If the display still doesn't work, you will need to replace the ERC-Electronic Range Control.
Oct 04, 2009 | Ovens
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Jenn-Air JES9860 burners and oven stopped working problem with display
sounds like you lost power to your stove. if you can't reset the clock, it needs to be replaced. in otherwords, the power outtage shorted out the clock.
have a technician replace it.
Jan 14, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Frigidaire smooth top stove
MY OVEN IS WORKING, THE STOVE TOP DOSEN'T. tHE CLOCK SHUTS OFF WHEN i TURN THE BURNER KNOB OFF AND WHEN i TURN ONE BURNER ON THE CLOCK FLASHES 12:00 AND THERE IS A SHORT BUZZER SOUND COMING FROM BEHIND THE PANEL. CAN I FIX THIS MYSELF?
Dec 16, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
Oven controller not functioning
9. The time of day does not display on my electronic oven control. If I push the CLOCK pad on the control panel the time will display for a few seconds and then it goes blank again.
  • On many ranges with electronic controls the time of day display can by turned off or on by holding the CLOCK keypad down for 15 seconds.
    Push and hold the CLOCK keypad. The time will appear for a few seconds, and then disappear and finally it will reappear and beep. Release the keypad and the time should continue to display. Follow this same procedure to turn the time display off.
http://www.frigidaire.com/support/FAQ-New_Electric_Smooth_Range.asp#9
Nov 04, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Oven display won't work
rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Dec 16, 2006 | Maytag MES5770 Electric Kitchen Range
Magic Chef CER3725AA Electric Kitchen Range Logo
387 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
