Question about KitchenAid KESC308LSS Electric Kitchen Range
Clean glass top
I have a hotpoint range on one burner i have a burnt area on top i do not know the best way to clean i have tryed my scrub pad that came with my stove and the cleaner i used is CERAMA BRYTE also i put a wet cloth on top of the area and thn tryed to clean buy still the same Please help
THANK YOU
KATHRYN
  • 473 Answers
Best thing to use is a scraper with a razor blade in it. Put it at about a 30 degree angle and this will get it off. Usually the user manual will talk about this.
Posted on Dec 04, 2007
How do I clean burner base and cap and the dirt in the crevices. tried using the pin but did not clean too well. Can the base be removed and cleant
Put the burner base and caps in a resealable plastic bag.
Pour in about 1/4 cup ammonia.
leave in a safe place away from kids and pets.
leave for about 1 to 2 days.
In the sink dump the ammonia.
Wash the parts with water and scrub with green scrub pad.
CAUTION!!! Ammonia is strong stuff. Use gloves goggles and do not breath fumes. Open windows.
Never never never mix with bleach.
Sep 18, 2013 | Jenn-Air JDS8850 Dual Fuel (Electric and...
Rings won't come out around glass cooktop
I have had pretty good success with the green scratch pads
Mar 09, 2013 | Whirlpool Kitchen Ranges
Cleaning black cooktop surface - what products to use.
It is recommended that you use a straight edge razor blade and push in one direction to remove anything stuck to the surface of a glass cook top. Stubborn, cooked on, substances can be cleaned by scrubbing with a light abrasive cook top cleaner and/or a green kitchen scrub pad. The green srub pads are considered non-abrasive and safe for cook tops. You can also use liquid dish detergent (such as Dawn) to break through grease and grime. DO NOT use steel wool, SOS pads, or any scouring powders. These products can permanently scratch or dull the finish on your cook top. If you have any questions please let me know. I hope you find this information helpful.
Apr 27, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
What's the best way to clean gas stove top pieces?
Remove from stove soak them in a sink of hot water and bleach for about 15 min then lightly scrub with scouring pad and they should come sparkling clean.
Jan 28, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
The glass top on my Spectra feels smooth but the burner area is turning black. How can I return it to it's spectuled gray?
if its a build up you can use a razor scaper after you warm it up just a bit
'warm the burner do not get it hot
then scrub the dust with a non abrasive pad/sponge
with a chem. called cryramabrite
Oct 04, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How to remove burnt grease, fix lightly scratched black stovetop?
Hi, I assume we are talking about a flat glass top. First the bad news. using any abrasives will permanently scratch the glass hence the dull spot. You can however make it look a little better. Grease spots and the like can be removed with a flat razor blade scraper which needs to be held flat to avoid the corners making scratches. Use any good glass/ceramic cooktop cleaner ( which is the ONLY cleaner you should ever use ) (available in your local grocery diy store and some hardware stores). The cleaner is a thick liquid, put about a dime size drop on each burner area and use a paper towel to buff out the finish like waxing a car. Once it looks clean flip your paper towel over and shine the top to like new. Good Luck!
Jan 28, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
Top burners spark intermittently with burner valves shutoff
Remove the burner caps (where the gas and flame come out) and wash in warm soapy water, using a plastic toothbrush like brush to scrub thoroughly.
Also clean/scrub the burner bases and ignition knob on the top of the cooktop.
When you reassemble, make sure the burner caps are properly seated in the burner bases.
Jan 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Burner on glass stove top has turned black
The nice grey-flecked surface coating is very thin; the solid black is underneath. You've "cleaned" the coating off -- that's why further scrubbing just makes it worse. We did the same thing :-(
Dec 06, 2008 | Maytag MER5770 Electric Kitchen Range
White glass cooktop hard to clean
First thing I thought of was that your pots have oil or build-up of some kind on the bottom. Try cleaning them with a solvent of some kind. As an experiment, try using a pyrex pot to see if that makes a difference. As for cleaning the cook top, I use a vinegar and water solution with a soft cloth or very low abrasive scrubber as you can scratch the glass quite easily on some kinds.
Sep 17, 2017 | Jenn-Air JES9860 Electric Kitchen Range
KitchenAid KESC308LSS Electric Kitchen Range Logo
140 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
