Question about Sony Ericsson K800i Cellular Phone
Not powering on
Phone not powering on?why
  • royaltiger Dec 04, 2007
    K800i not powering on might be erom problem..can u suggest how to fix it.
    Problem Solver:
  • 18 Answers
Replace your bettery
Posted on Dec 04, 2007
What is the problem with my cisco 7921 phone it has a blank screen
Does the phone power on at all? If you hold down the red button on the front it should power on. If it is not powering on, either your battery is dead (needs a charge) or your battery or phone may be defective. Try plugging in the the power supply and then turning the phone on to see if it powers on.
Cisco Phone Power Brick
Aug 27, 2012 | Cisco 7921G IP Phone
How to power nokia 5610 xpressmusic without using the power button?
My dear friend, sorry, there is no other way to power on your nokia 5160 xpress music phone. The only other way you can power it on is to get the phone opened and use an object to touch the power button manually.
If your phone does not power on by the power button, first ensure that your battery is fully charged. Then you check if your phone is working properly. Test your battery by inserting it in another phone and try to charge it for about 2 hours, then you power on the phone to see if the battery will turn it on. Then you insert a well charged battery into your phone, then you power it on, if it turns on, then it means it is the battery you are to replace, but if it does not, then it means there is an internal problem with the phone.
Hope this helped you.
Jan 09, 2011 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
Lg ks660 reset code
Hi
1 Connect phone powered off
2 Add power to clip
3 Wait for correct Stage Mode then press power button on phone
4 Keep phone power button held until 2 solid LEDs on clip
5 A factory reset maybe required to finish unlock
Factory Reset
If the phone is still locked then power on phone and enter 2945 select factory reset
Jan 04, 2011 | LG KS660 Cell Phone
When My phone is on then 1sec leter phone swich off
A battery function requiring power charge. Provide the phone a full system charge about 45 minutes should store original phone capacity to handly entire functionality pass the power on a few seconds display mode. check on the phone saver or background display and lightening settings. Power saver features could cause the phone to power to sleep mode when not in use. an extensive setting of power saver screen display only a few second soon after the phone is powered on could be distracting to user experince, especially when least recogision of the phone is made by owner
Dec 05, 2010 | Nokia 5220 XpressMusic Cellular Phone
How power need Cisco 7941G-GE IP Phone
These phones can take their power from a Power over Ethernet switch, where all you need to do is plug the phone in to the switch and it gets its power from there.
You can also get power cubes for these phones, but they do not come with the phone as standard, as most people like the convenience of having the power coming from the switch, and not needing to use up a further power socket in the floor/wall.
Hope that this helps!
Nov 06, 2010 | Cisco 7941G-GE IP Phone
No power on
Hi,possible problem with phone not powering on are,
Battery and phone board dead.
Battery can make the phone not to come on,how? If the battery cell is dead and can not power on the phone. You will need to replace the battery for the phone to power on.
The phone board.After you have tested the battery, You can now test for the board. When a board is dead,you willneed to flash the phone for the phone to power on.Flashing a phone will restore back the phone to normal.Use this link to flash the phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
after flashing the phone, if the phone does not come on ,that means the phone board is totally dead,and you will need to get a new phone.
Take care.
Sep 26, 2010 | Nokia N70 Cellular Phone
7940 cisco ip phone being powered by a power brick seems to loose power when connected to the ethernet. When ethernet is disconnected, power comes back. Ethernet works fine when phone is not connected. No...
Change out your cable from the wall drop to the phone. A Cisco phone is capable of receiving inline power (Power Over Ethernet) via the blue and brown pairs of the cable. It sounds like you may have a cable with a short in either the brown or blue, or both pairs, shorting out the power when it is connected via ethernet.
If you can, have your IT Tech check the cable, and the line through the wall to the switch.
May 26, 2010 | Cisco 7940 IP Phone
Need to turn phone on but the power button is broke. It charges and turns on but just the charging screen
you need to replace the power button so that you can power your phone well again.
But there is another way by which you can power the phone without the power switch. This will involve you opening the phone cover so that you can gain access to the power button area on the phone board/panel.
Get a phone screw driver, open the phone, insert the battery into the phone, get a tiny wire and bridge the power switch panel and the phone will power on.
Try this, and it will work. I am very sure about this.
Take care.
Mar 18, 2010 | Samsung Blast Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
57 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
