Question about Philips MCM570 CD Shelf System
Just clicks and wont turn on
The standby light comes on when the power cable is plugged in, and it just clicks about every 3 or so seconds, i think this might be because i was looking on the back of it and saw a little switch that canged the voltage, and i flicked it to the lower voltage setting while the stereo was on. (it does the clicking while on the original setting, and the lower setting also) any info on fixing this would be much appreciated!
  • justin6992 Dec 23, 2007
    Oh i get it now lol, thankyou! that was very helpful! So i can get a repairman to fix this for me?
    Scholar:
  • 31 Answers
Hi Justin6992,
You have been very honest and told us the facts behind the fault, thanks for your good fault description...
Now what you have done by flicking that little switch is:-
Altered the input power design of the stereo system.
The switch is there so that the user can connect it to either the USA power supply of 110-120 volts, or connect to the Australian/New Zealand power supply of 230-240 volts.
When you turned the switch over you lowered the input to 110-120 volts yet it was still plugged into a 230-240 volt power supply.
This has blown a component inside the power supply and
now it must be replaced.
This is a specialised replacement process by a service man..
The clicking sound is made by the internal power supply (Its called a switched mode power supply) and it has detected the blown component and it is trying to reset itself automatically for you, but it cant because of the faulty component.
Its very clever in its design and if it wasnt clicking there would have been quite a loud 'bang" and a lot of smoke when the switch was moved to 110-120 volt position.
Regards From YUBEUT
Posted on Dec 04, 2007
Why wont the Television click on, when remote is pressed?
If it turns On just for a moment; at least, and the standby/power light at its front panel comes ON; and it goes OFF withing seconds; the main board to the set is faulty. If standby/power light at the front panel does not come On; the main power supply regulator board [inside] the TV is faulty.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 11, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
Toshiba 50hp66 Plasma repeats power sequence without turning on
A case of which came first the chicken or the egg, Power supply board may be the issue or the sustain board--have you looked for the usual bad caps on the power board?
Dec 03, 2012 | Toshiba 50HP66 50 in. Plasma Television
My ps3 is hooked up and everything it comes on but it won't come up on my tv screen, BUT EVERYTHING IS HOOKED UP, The hdmi cable is plugged in to
Please do the following steps to reset your PS3 display :-
Turn the PS3 off into standby mode (red light on)
Press and hold the power button. It will beep when you first press it then beep again 5 seconds later. Release the power button when you hear this second beep.
Wait for the PS3 to detect your HDMI cable.
Hope this helps and thank you for using FixYa
Dec 28, 2010 | Sony Playstation 3 (PS3) Console
PS3 wont work with AJAX after using HDMI cable
ps3 does not reset the video automaticly you have to reset it yourself any time you go from one mode to the other
to do the vid reset just hold the power button when in standby(red light) untill you hear second beep then release
Nov 03, 2009 | Sony Playstation 3 (PS3) Console
Wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
Mar 25, 2009 | Beko 324250WN 28" TV
Jvc rx-dv31 standby light comes on, but wont turn on, just clicks then turns off
sorry but this is an electronic malfuction or failure , it will need repair
leave it unplugged to prevent further dammage untill you can take it to your local electronic repair shop
electech
Oct 27, 2008 | JVC RX-DV31 DVD Player
Red light comes on but the shuts off?
Mine did that and it really pised me of, sony told me to turn the power switch onthe back of the console on, when the stand by light comes on to push and hold the on button for at least 3 seconds until you hear a second set of beeps. This however didn`t work so I sent it back to Sony Australia and got it fixed up no worries.
Oct 11, 2008 | Sony Playstation 3 (PS3) Console
My Sanyo TV DS20930 wont turn ON at all
try unplugging for the power source for 60 seconds hold in the power for 10 seconds then plug the power cord while you are hold int power button in then release the power button... now try it (turn it on)
Apr 17, 2008 | Sanyo DS20930 20" TV
Philips MCM570 CD Shelf System Logo
346 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
