Question about HP LaserJet 2100 Printer
Shadows on prints
The printer leaves a shadow from text/graphics repeatedly down each page. Each page has a faded "copy" of the above text repeated down the page. I have tried to use the utility cleaner many times but it does not help. The problems occurs less, the more the printer is used throughout the day. Replacing the toner does not solve the problem either. How can I stop this?
I have a HP Laserjet 2100. It has the exact same problem. It repeats "ghost' images of the text above, down the page. I am VERY mechanical and do not know where to purchase a fuser for this model or how to install one. Can you walk me through the process on a 2100?
  • Kasmodan2 Dec 04, 2007
    Another person offered this solution and thought I would add it here. Determine where the ghosting is coming from. Put a piece of paper in the outside manual feed. Let it suck almost the entire paper in, then quickly lift the toner cartridge door to stop it from pulling more of it in. Lift out the toner cartridge. If the ghosting IS THERE, then the problem is the toner catridge. If the defect is NOT there it is the fuser. Rebuilt or low quality toner cartridges can cause this problem.
  • reago Dec 20, 2007
    Thank you for the suggestion. Problem was my print cartridge. I replace it - no more problem
  • 417 Answers
The comment from Kasmodan2 is true it can the toner cartridge, but is most cases it is the fuser. I repair HP laserjet machines day in and day out to replace the fuser is easy.
  1. Turn power off
  2. Open cover at right hand side rear
  3. Remove data cable
  4. Open top cover remove toner cartridge and press button on right hand side and slide the right hand cover off
  5. Open the back cover and lower the door all the way down
  6. Remove the two silver screws
  7. Take out the paper tray as this will be easier to remove the back cover
  8. Pull the back cover from the bottom and should unclip be careful not to break this cover.
  9. Once open then you will see the fuser unit unplug the connections and remove the screws then slide out the fuser unit
  10. Refit the new fuser unit plug in all the connections and reverse the above process
  11. Turn machine on and test if all good the machine will work fantastic if there is a constant red light repeat above and check connections if still red light then the new fuser faulty and not heating up.
Hope this helps all of you
Thanks J
Posted on Jan 12, 2008
Faded print
using the D-pad on your printer, scroll down the menu until you get to "maintenance"
Press OK
Scroll down to "clean printhead"
press OK
The printer will now make some noises and after about 30 seconds will say complete.
Now scroll down once more to "Print test page"
press OK
load paper and press the start button
Iff the printed page looks ok...job done. If still faint, repeat the above steps once more.
Nov 18, 2013 | Kodak ESP5250 All-In-One InkJet Printer
How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Jan 01, 2013 | HP Photosmart C3180 All-In-One InkJet...
Hp LaserJet 1012- prints shadows and repeats text/ figures...
just clean and calibrate your printer be sure your head cardrige is aalso clean and or new.
May 26, 2009 | HP LaserJet 1012 Printer
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
MINOLTA QMS magicolor 3100 printer, repeat shadowing
Рthe rechagin corona in imije unit is demeged change it
Mar 12, 2009 | Office Equipment & Supplies
Dell 5110cn Printer Printing Blue Shadows
I did the following and it has stopped printing "shadows". I don't know if it was one solution or the other (or both) that worked.
1.On the face of the printer press the "Menu" button>Admin Menu>Maintrnance>Color Reg Adj>
Auto Correct>Yes
2. "Menu" button>Admin Menu>Maintrnance>Clean Developer>(Pick problem color)>Yes.
Hope it helps
Aug 16, 2008 | Dell 5110cn Laser Printer
My copies and prints are blurred with shadows
That was the Solution that the ink cartridge required a replacement
Aug 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Shadows on prints
Hi, The problem your having sounds like a Fuser . The Fuser will cause printed text to give a ghosting look down the page were it repeats itself.
Nov 30, 2007 | HP Color LaserJet 2600n Printer
Text "ghosts" or shadows
Replace Drum or blade(if possible) will fix on most types of copiers/printers, or rarer it is cause of fuser.
Oct 19, 2007 | Ricoh Aficio 1013F Copier
HP LaserJet 2100 Printer Logo
536 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
