Question about Altec Lansing ACS 48 Computer Speakers
Blowing Fuse I have a 2.5amp fuse in my speakers, but it keeps blowing. Not sure what could be the root of the problem. Do I need a bigger fuse? It may help to note that the country I'm in runs off a 50Hz cycle, not 60Hz. Not sure that makes a difference. The speakers were working well for over a year and then all of a sudden the fuse blew, and each new one I put it, it kept blowing them. I have other Altec speaker systems that work well and are still working. Would really like to solve this as these speakers sound fantastic!
  • haraz Jan 30, 2008
    Customer (Hans R. Zelsmann)
    01/17/2008 01:19 PM
    Question Reference #080110-000127
    Subject: ACS48 speaker system
    Product: Portable Audio
    Satellite Speaker Systems
    Region: Europe
    Date of Purchase: 09/01/2002
    Submitted: 01/10/2008 10:44 AM
    Last Updated: 01/11/2008 12:28 PM
    Status: Updated
    Store of Purchase: Macway- France
    Discussion Thread
    Customer (Hans R. Zelsmann) 01/10/2008 10:44 AM
    Last week I submitted to alteclansing@custhelp.com the problem with
    my ACS48 speaker system ; I believe that here is still a customer but
    NO help at all. You simply sent back my questions. Astonishing and
    rather deceiving ! So I will try once again.
    As it seems the electronics of the amplifier are dead and any
    replaced fuse (1,25A at 220V) blows immediately. The resistance (DC)
    at the entry of the mains plug is about 11 ohms.
    This major failure happened during my absence from home and is most
    probably due to several power cuts of the mains in the neighbourhood
    of my home. It is worth to note that the ACS48 unit initially was
    switched off. However, when the power is re-established the ACS48
    unit switches on automatically !
    This type of ABNORMAL REACTION led to the vaporisation of the fuse on
    subsequent power cuts and at the same time to destruction of
    electronic parts.
    Would you, please, be so kind and reply to the following questions:
    Q1) Did you already experience this kind of problems and is there a
    simple fix ?
    Q2) Is there a diagram of the electric circuit available for the
    ACS48 with indication of the type of the components ?
    Q3) Which of the present Altec Lansing 2.1 speaker systems would you
    recommend for replacement at comparable output power at BEST sound
    quality ?
    Q4) If there is no chance of repair, should I really trash the
    loudspeakers and change to BOSE ?
    Thanks for your answers.
    haraz077@hotmail.com
  • ncschulzes Aug 11, 2008
    I have replaced the (blown) original 2 amp/250 volt fuse in my ACS 48 with a similar fuse and have now blown two more just as soon as AC power was restored to the system. The first time I replaced the fuse, I plugged the system into a live outlet; the second time, I had the system already plugged into a switched outlet strip, then turned on the strip. I have not yet tried higher amperage fuses for fear of frying the electronics. Are these speakers history?
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hi Nattydred
Depending on your country, and voltage, you may need a voltage regulator, or a Battery Backup to keep the fluctuation of energy at line. regular will be 60Hz. so is better to start on that solution first.
Posted on Dec 04, 2007
E315 cerwin vegas speakers and one keeps blowing a fuse when I turn it up to the normal volume I play them.Can I use a bigger fuse or is it the speaker?About a yr old rarely used until the last few mo
Try playing the speakers at a friends house or something to see if you blow their fuse. If you don't then you know for sure that you need a bigger fuse, but if you do then it's the speaker.
Jun 03, 2013 | Audio Players & Recorders
Speaker fuse
Most likely there is something wrong with your speaker. A bigger fuse is not going to help, and could cause more damage.
My atc fuse would keep blowing I put a bigger fuse it didn't blow that but I herd a zap noise from my TCCM now my 4x4 won't work 1999 jimmy
What you have done? You Just damage the TCCM and that's why you will not manage to shift 4x4. Why this happened? Because you had shortage somewhere and you receive blown ATC fuse.You put a bigger fuse in capacity where the was stronger to blown and the fault moved to the tccm system which was not protected and blown.Ask for an expert to check and see whether the fault is easy to get fixed.
Jan 02, 2013 | 1999 GMC Jimmy
1996 Toyota Corolla blowing fuse
probably have a brake light out
Apr 04, 2010 | 1996 Toyota Corolla
Fuses keep blowing
if the inline fuse is blowing, you are putting out more power than what is getting to it, thus overloading the fuse and blowing it. Try a bigger fuse first and if that doesn't work, you will need to get a larger guage power cable with the bigger fuse. Also check your ground is properly grounded.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Oct 08, 2009 | AudioBahn A2150HCT Car Audio Amplifier
2009 e250 keeps blowing 10 amp parking fuse then
if it keeps blowing the fuse you have a short in the wiring
Sep 11, 2009 | 2009 Ford Econoline Cargo
Amp blowing fuses
Your amp is blowing fuses to protect your circuit. The type of 12V battery does not matter. For whatever reason you are over driving the amp. 2 Ohms sounds like a very low impedance for a car amplifier output. I am assuming you have the two 12" speakers wired in parallel. Most are rated at 4 Ohms which means you are pulling twice the current with the 2 Ohm load. Also, the bigger the speaker, the bigger the magnet, the bigger the coil, the larger the inductance, the heavier the load. Make sure these speakers are matched with your amp. A small amp driving large speakers will shut down at high volumes. Try putting them in different channels. Good Luck.
Jun 17, 2009 | Kenwood KAC-9152D Car Audio Amplifier
My fuses keep blowing and they share a fuse with the interior lights
If you are running an amp it needs to have a dedicated power line with a fuse break this fuse break will make sure that you dont blow the amp do to a power surge. The bigger the wire the better, also make sure ground is good bare metal and clean.
Mar 10, 2009 | Car Audio & Video
Fuse keeps blowing?
The fuse is a protective device. Fuses dont blow unless the amp ( in your case ) is drawing too much current. DO NOT put a bigger fuse in. Obviously, there is a problem with the amplifier inside the sub. If the sub is under warranty, send it in for repair to an authorized warranty depot. If not it's not under warranty, then take it to the authorized warranty depot anyway. Why ? because they will have the schematics ( electrical diagrams ) to troubleshoot the unit quickly and it may be a common problem. If it is a common problem, the factory may have released a modification and possibly it could be covered under warranty under a factory 'goodwill' program. Good luck. Rob
Mar 03, 2008 | Energry Speakers Energy Speakers S8.3...
Altec Lansing ACS 48 Computer Speakers Logo
353 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
