Question about Dell W3201C 32 in. LCD Television
23 inch lcd tv by dell wont turn on as if no power
Tv wont turn on on dell 23 lcd tv 1 year old 2 dell lcd it take about 1 minute or to for picture to staiten out after turning on after minute or 2 picture great
  • 233 Answers
If this is a DELL W3201C read this.
Have the same model and same problem
probably It is a bad inverter board, in my case one of the 16 transformers is burnt out on the inverter board. still trying to find a replacement component. if not replacing the board is the only option or getting the inverter board repaired.
by the way, this TV has a Samsung panel: model LTA320W2-L03. so it needs parts for a Samsong not a DELL.
DELL does not manufacture or fix them becuase they don't make them
Posted on Dec 28, 2007
    New Friend:
  • 90 Answers
Well, my first question is: Is this a 23 or 32 inch Tv. This is a conflicting listed question. Let's just say for the records, that it is a 3201C. Your TV firmware version may be outdated. Therefore, it's causing the tv to not respond properly upon powering up.
2 sugesstions: Do a factory reset. This will allow manu specs to be reset. Menu + Setup + Factory RESET
Check your firmware version I believe the current version is 51-7
I know its not the inverter, because if after 2 minutes, the TV actually works, then there is a strong possiblity that your backlight board/ Inverter is working properly. Also, when in absolute doubt, the power board is the board that provides equal voltage to each board to make it correspond and run as one.
Posted on Feb 08, 2009
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Jun 04, 2010 | Sanyo DP32746 32 in. LCD Television
Toshiba regza 32hl67 losing its' picture and motion is slow
I have a toshiba regza 32hl67 LCD tv which is only 2 1/2 years old. The picture on this unit just started to go the other day (screen darkens but images are still visible and the motion/movement is very slow). I contacted Toshiba and they just said to unplug the tv for 3 minutes to reset the tv. This doesnt work. I am VERY upset with Toshiba, after paying $800 for a tv that only lasted 2 1/2 years. If anyone has had similar issues and know how to fix it, please let me know. Thanks
Apr 26, 2010 | Televison & Video
TV wont turn on--power light blinks but no picture
The problem is in the power suplly board.In the LCD TV this board is common to the rest function.If the reparation cost is 80% on the new LCD I suggest to buy one new.
Sep 01, 2009 | Toshiba 23HLV87 23 in. LCD Television
Lcd sanyo
Could be main or power board
Dec 30, 2017 | Sanyo DP23625 23 in. LCD Television
VIORE LCD TV/DVD won't turn on
19 in wont turn on. red light just solid , unplugged for a day still same , is there a reset button
Aug 18, 2008 | Televison & Video
Dell 23" LCD TV Won't Power On
i had this problem before ,i fixed mine by unplugging all cables wires and power plug ,then hold poweron button in for 5 minutes this will reset unit
Mar 22, 2008 | Dell W2306C 23 in. HD-Ready LCD Television
Lcd tv picture problem
My 3 yr-old 30" Olevia LCD HDTV lost picture after being on for about 1-2 min. Does any one encounters a similar problem or has any suggestion as to how or wherther it can be fixed. Thanks.
Jan 11, 2008 | Olevia LT26HVX 26 in. LCD Television
Dell W2300 LCD TV Picture Problem
Your problem is due to intermittent power in the backlighting circuit. This is usually caused by swelling of electrolytic capacitors in the power board. If you can find an honest electronics technician it is about a $40.00 fix.
Jan 03, 2008 | Dell W3201C 32 in. LCD Television
Dell W3201C 32 in. LCD Television Logo
661 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
