Question about Sony Handycam DCR-TRV350 Digital Camcorder
Cartridge loading cartridge will not load...have gotten message c31:40 on screen with flashing arrow
  • Gymbob Dec 04, 2007
    occasionnally the receiver will accept the cartridge and retract into the camera but I get the message C31:40 with the flashing arrow....
  • J5BALL Jan 27, 2008
    I have tried to reset the machine. The taping drum spins when the tape is loaded but the machine will not bring the tap into the compartment. After a few seconds the taping drum stops spinning and the error message C31:40 is displayed. Without the tape in the cradle, the machine will bring the tape cradle into the camera like everything is fine.
  • 169 Answers
The cylinder drum of your camera is not running that why c 31:40 is appearing to the screen...or may be the cylinder drum is stuck up...if the drum not running when you move it it is possible that it have to replace the whole cylinder assembly but if it's freewheeling then try to clean the contact of the cylinder connection pin using a pencil eraser sometimes it is a poor connection only...
Posted on Dec 09, 2007
How to factory reset the hp pro 300 laserjet printer
1. Power down the printer
2. Press and hold the lower left hand corner of the screen
a. This is normally where the progress bar starts loading on the screen
3. Power on the printer
4. Release the left hand corner once the "Permanent Storage Init" message appears.
or alterative way
2. Press and hold the right arrow button on the navigational bar
a. This button will flash for a moment when the printer boots up
Jul 14, 2016 | HP Office Equipment & Supplies
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
When i turn the laptop on all i get is a blank screen with the mouse arrow nothing else.
When you turn it on, does it initially show a "splash" screen (a picture) ?
Does it initially show any information, such as the amount of RAM installed,
or any "press <blah> to enter SETUP" message?
If not, then the motherboard has a problem.
If it does display the above, then it will try to load Windows from your disk-drive.
If the disk-drive is not connected, or it has "died", then Windows cannot be loaded,
and all you'll see is a blinking white "underscore".
If Windows does start to load, and you see the mouse-arrow pointer, then Windows is loading, at least partially.
Take your computer to a qualified technician at a computer-store, for thorough trouble-shooting & repair.
Feb 12, 2011 | Compaq Presario 700 470024-192 Notebook
I have been trying to load the stapler but when I put the cartrage back into the unit it starts making a weird noise and the the screen still shows load staples so I do not know whether I am doing...
Remove the stapler cartridge and look on the clear plastic part of the cartridge. Do you see the arrow pointing towards the puncher side of the cartridge. The arrow of the replacement staples should line up. I've had customers put the staples in upside down before. The only problem is that you then have to take the staple cartridge apart to remove these staples and reuse them. . You just have to release the 4 clips at the bottom and carefully remove the piece. Be careful of the black arm that hangs down when the cartridge is held in the up position. When replacing the bottom back on, the orientation of this arm is important ( upside down or right side up) . This tells the copier that the staples are out. Hope this helps.
Jan 13, 2011 | Canon imageRUNNER 5570 Copier
The ink droplet is flashing orange, and the up arrow is also flashing orange. It pulls the paper to load, but it won't print.
Remove both in cartridges
Unplug printer
Wait at least 2 minutes
Plug the printer back into the outlet
Wait until printer stop
Reinstall both ink cartridges
If the ink droplet is still flashing, that will indicated a bad cartridge
Jun 11, 2010 | HP Deskjet D4260 Printer
Ink red light on . which colour is out?
When red ink light flashes - one or more ink cartridges is low. When you print, a message on your screen will tell you which one(s).
When red ink light remains on - one or more ink cartridges is empty. When you try to print, a message on your screen will tell you which one(s).
Furthermore: When following the procedure for installing a new cartridge, if the red ink light was on or flashing, pressing the ink button will cause the carriage to stop with the cartridge that needs replacing under the "ink out mark" (ink droplet with a slash through it).
Jan 08, 2010 | Epson Stylus C66 Inkjet Printer
Flashing red symbol on screen - not 'no cassette loaded' symbol.
I had the same problem with my ZR800. After lots of searching on the net I found out what the symbol indicates. It means that the little battery that holds the memory for the clock is weak. It's under a little cover behind the main battery compartment. I put in a new one that the flashing icon is gone. I put the battery I took out into another ZR800 and the icon started flashing on it. A simple solution that Canon should have posted in the manual.
Dec 19, 2009 | Canon ZR800 Mini DV Digital Camcorder
Do not see align or clean catridges at preferences /features
hi,
To Align the cartridges, please perform the following instructions.
  1. Load unused plain white letter or A4 paper into the input tray.
  2. Press the Setup button.
  3. Press the down arrow button to select Tools and then press OK .
  4. Press the down arrow to select Align Print Cartridges and then press OK . An alignment page prints.
  5. After the success or failure message displays, click OK to continue. Recycle or discard the alignment page
Regards,
Sagarjd
Nov 21, 2008 | HP Photosmart C4180 All-In-One InkJet...
Printer won't print properly.
Please perform the following steps:
  5. After the success or failure message displays, click OK to continue. Recycle or discard the alignment page.
Regards,
Sagarjd
Nov 08, 2008 | HP Photosmart C4180 All-In-One InkJet...
Would not print C5280 Flashing Failure Print Cartridge allignment
Solution
  4. Press the down arrow to select Align Printer and then press OK . The unit prints a test page, aligns the printhead, and calibrates the printer.
Cause An incorrect type of paper is loaded in the input tray. If you have color or photo paper loaded in the input tray when you align the printer, the alignment might fail.
Nov 04, 2008 | HP Office Equipment & Supplies
Sony Handycam DCR-TRV350 Digital Camcorder Logo
59 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
