Question about Dell OptiPlex GX260 PC Desktop
Can't open case
I have a desktop case in which I can't open the top. The two buttons release fine, the left side comes apart, but the right side seems to be 'stuck'. It's a refurbised system and from my understanding there are no screws holding the case togeather. Any suggestions?
  • Anonymous Apr 01, 2014
    The Dell came with a 3.5" floppy disk that has had better days, when I opened the case I found that the floppy is attached to the rack and there is no room to unscrew the floppy from the rack, I cannot open the other side of the case because it is attached to the mainboard. I also tried to open the top and no luck reaching the screws in the rack. The reason I need to pull out the floppy or replace it, is because the floppy runs constantly, and the only way I can get it to stop from the outside of the case is to put in a disk. Help, if you can please.
  • 56 Answers
Dell optiplex have very tight casings, dont be afraid to use force.
I have one myself and it is a struggle to get the casing off.
as long as those 2 side buttons are pushed in just give it a good tug and hopefully it should come off.
Posted on Dec 04, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hi goatcheeze
Right, you have to pull the 2 triggers, and pull at front, with certain force, it will came out.
don't be afraid.
How do i remove the front cover of my dell computer tower 8250
Not sure if you can pull the front cover off this particular model, but to open the PC:
  1. Make sure the PC is powered off and disconnected from the AC outlet.
  2. If facing the front of the PC, lay it on its right-hand side, so it lies flat.
  3. At the back of the PC at the top left, there is a release button. There should also be a release button on the bottom of the PC near the rear (slightly indented into the bottom). While pressing both of the release buttons, pull the cover upwards and the case will open like a clam.
Jul 18, 2014 | Dell Optiplex GX150 Tower Computer - 1GHz...
How to open gateway 300c desktop
There are several casings. You'll just have to pick one that fits your computer. Before you begin anything. Turn off your computer and remove the power cable. New Midtower Case 1 Look for a release handle on the top of the new midtower case. 2 Push the release handle inward. 3 Swing the case down from the top to open it. Microtower Case 1 Lay the computer down so that the left side is face up. 2 Locate two cover release levers on the back of the case toward the middle of the left side panel. 3 Squeeze the release levers together, then lift the panel up, swinging it away from the back of the case. Old Midtower Case 1 Lay the computer on its side, so that the left side panel is face up. 2 Remove any retaining screws along the left side of the back of the case that are holding the panel in place. These screws may be removed with your fingers. 3 Locate two release levers at the top and bottom of the back side of the case, and push them away from each other. 5 Swing the panel up and away from the case to open it while holding the release levers.
Jan 01, 2011 | Gateway 300 C PC Desktop
How to open case desktop
Lay it on its right hand side and you will notice there is a release button on the bottom the same as the top. Press these 2 buttons together and it will just hinge open. Cheers from Scott and plz dont forget to vote
Oct 20, 2010 | Dell P4 2.8 GHz (DELLDIMREF1100) PC...
Unable to remove cover from dell dimension 8400 desktop pc
This Dell Support, and the Service Manual for the Dimension 8400,
http://support.dell.com/support/edocs/systems/dim8400/SM/index.htm
In the Service Manual main menu, left-click on - Opening the Computer Cover
1) Computer off, and unplugged from power. (Always unplug the power cable from the surge protector. Then if the power cable needs to be removed from the computer, do so)
2) Remove all cables to the computer
3) Lay the computer on it's Right side.
(As you face the computer, your right side is the computers Right)
4) There is a Release button on the Top of the computer case, and a Release Button on the Bottom of the computer case.
These are located at the Rear of the computer.
The preferred method of opening the computer case, is to press one release button in at a time, and slightly lift up on the side of the computer case, where that release button is located near.
Then go to the other side of the computer case, press this release button in, and lift up on the computer case.
The computer case opens like a clamshell. The computer case is hinged at the front.
Example:
Computer laying on it's right side. Press the Top release button in, and lift up on the computer cover located near the Top.
Now press the release button on the Bottom. Lift the computer case up.
The computer case opens from the back, towards the front, like opening a car hood.
Feb 18, 2010 | Dell Dimension 8400 PC Desktop
How do I get a dell dimension 3100 case open it seems pop riveted shut. is there a trick or do the pop rivets have to be drilled out
Easy.
1. Stand in front of the PC i.e. you face the start button.
2. Push the tab at the top back of the casing
3. Pull the right hand side cover of the casing and it should just pop open - the latches are at the bottom.
I think most people try to open the left side and wonder why the ......
Mar 12, 2009 | Dell Dimension 3100 PC Desktop
How to open PS2 slim console? Uncrewed all but still cannot open.
When you have all of the screws out of the case of the system, flip the system right side up and separate the top portion from the bottom, starting the separation from the rear of the system. The top and bottom clip together in the front of the system by the memory card ports, but if you start to separate the case from the rear, it should pop apart easily. You don't have to use alot of force to get the top to come apart from the bottom. Make sure though that before attempting to reassemble the case, check the power button to see if it is seated properly in the little holders on the bottom portion of the case. Then put the top back on, and gently press the top and bottom together to clip the two halves together. Throw the screws back in and you should be good to go!
Nov 03, 2008 | Sony PlayStation 2 Slimline Console
How do i open the 300gl box
Opening the case is a breeze; remove three large thumbscrews, and you're in.
Jun 01, 2008 | IBM PC 300GL PC Desktop
Trouble removing case on Dell Dimension 4600c
Try this...
I work on these systems on a weekly basis and they can be very difficult to open. I would make sure that you have already removed the feet from the bottom and turn it so that the heavy side (technically right side up) will be facing the floor. Place the palm of each of your hands on each of the buttons and squeeze the system as hard as you can while holding the system maybe an inch or two off of the floor. The plastic buttons basically cover a metal release tab that is actually part of the frame. All of the clamshell type cases are tough to open because of this. Good luck.
Apr 24, 2008 | Dell Dimension 4600C PC Desktop
Disassembly manual
Hi, every desktop pc is almost the same to open up and take apart nowadays, if you want to checkout some of these videos should give you more than enough info..
http://www.youtube.com/results?search_query=disassemble+pc
All the best
John
Jan 02, 2008 | Sony VAIO PCV-W510G PC Desktop
Removing cover from old Gateway PC to add memory
If your Gateway PC is laying horizontally flat. There will be a black button in front of the PC on the left side of the CD-Rom. Push really hard. And WallAA!
Dec 25, 2007 | Computers & Internet
Dell OptiPlex GX260 PC Desktop Logo
849 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
