Question about Dyson Vacuums
Very little suction in hose no tears in hose
Very little suction in hose no tears in hose side filter clean DC07 Just tried the low extension to vacuum under the bed very little suction on extension . the side filters are clean .NO tears in the hose underneath the vacuum >What else could it be ?
  • Anonymous Mar 26, 2014
    Looking for stairs extension hose for dyson cylinder vacuum dr3
    Novelist:
  • 171 Answers
Hi there, SmartAlec from NelsonVacuums.com.au . I have fixed hundreds of Dyson DC07 vacuum cleaners over the last few years and i would say there are 2 possible causes for the loss of suction.
1st is that the filter looks clean but is actually worn anyway. The way to tell is remove the washable filter from your vacuum cleaner. Take out the foam insert this seems to last longer that the other part. Hold up the plastic cage to the light and look at the white part (well it used to be white anyway) you should be able to see light through it. If you cant see through it you need to replace it. Here is a link to that filter for purchase . To verify this is the problem just run the vacuum without the filter in you should see an improvement - note do not actually **** up material the filter is there for a good reason.
2nd problem is that you have a blockage in your radix assembly. If you take off the whole dirt bin and feel the suction on the upright part where the chamber joins the vacuum (basically bypassing the radix) if there is good suction here you will either need to replace the cyclone top or dismantle and clean it. (it is very difficult to clean as it doesn't completely dissassemble)
Hope this helps - If you want more help send me a message
HAPPY VACUUMING ! :)
Posted on Aug 26, 2009
  • 33 Answers
You might not need to buy anything. Look at this and see if it helps:
http://www.fixya.com/support/t2827418-very_little_suction_in_hose_no_tears_in
Posted on Jan 26, 2010
I have a Dyson DC07 and it has lost suction. I have checked the belt, cleaned the circular filter and emptied the dirt chamber. The hose still has plenty of suction but I can't use the hose the vacuum...
Here are some things you can check.First you need to see if the problem is with the suction or agitation.If the suction on the hose for using the attachments is low you either need new filters a new cyclone(they are not cleanable) or it is clogged.To check for a clogg remove the cyclone and turn on the vacuum cleaner.you can put your hand over the suction side of the handle tub and feel if it has suction there.Reinstall the cyclone and again check the hose.If it is the same you don't likley have a suction problem you have an agitation problem.The 2 belts on the DC07 are part of the clutch and when they are strectched to a certain point (3-5years) the clutch needs to be replaced.you can check the clutch by turning on the vacuum cleaner and applying slight pressure downward on the front of the vacuum head.If the vacuum makes a loud ratcheting noise or you can stop the brush from turning the problem is most likely the clutch.One last thing is to make sure the bottom plate is on correctly I often see a misaligned bottom plate and the brush dosen't hit the carpet so it dosen't pick up.  www.sewvac.com
Jan 28, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hi loss of suction on Dyson DC07 and I have changed the belt on the brushbar and cleaned all filters/removeable parts but still suction not very good, any other suggestions?
Check for a clog where the power nozzle connects to the hose. Clogs or leaks in the hose will both cause loss of suction/air flow. Another possibility is broken or worn out fan blades.
Nov 13, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
There is no suction on my vaccum, hoses appear not to be blocked
have you checked your permanent filter. is that plugged? Have you taken the small solid plastic passage off the side of the machine and checked for a plug there?
Did you by chance rinse your cyclone with water at some point? You can disassemble the cyclone and clean that. google has some videos on cleaning your cyclone. just google clean dc07 cyclone and you'll get several
Sep 21, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Do07 not picking up out only suction with hose
Check and clean filters, looking at it from front filter is located in base on right hand side, take out filter clean sponge and let it dry overnight. see here page 5
http://www.dysonmedic.com/PDF%20docs/dyson_dc07_owners_manual.pdf
Mar 01, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson hose looses suction
You have a blockage in the wand. Stand behind the machine and:
1) Remove the u-bend which is located NEXT to the right-hand side wheel, NOT above it. It connects from the bottom of the long gray hose to next to the right-hand side wheel. It is attached to the machine with a rectangular-shaped clip - push the clip and pull the pipe down.
2) Look through the wand if you can (DC07 wand is bent) - if you can't see the ground you have a blockage in either the hose or the wand
3) Remove the hose and separate it from the wand - hold the wand up into the air and look through it - if you can't see light coming through the other end, there is a blockage in the wand. Use a long object like a stick or a metal hanger to remove the blockage.
4) If the wand is clear, stretch the hose out and look for dark spots - those are the blockages. Again use a long object to remove the blockage - be careful not to damage the hose, you don't want to buy a new one.
Jun 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Low Suction When Using the hoses on the Dyson Animal
there is a washable filter either on the side of the motor or in the dust cup clean it out using water make sure it is dry before reinstalling also check for clogs there are several pices that are removeable the peice under the hose and vent clip? on the side remove and check for clogs
May 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
The wand has no suction
There's a clog somewhere then - probably at the end of the hose which means you should take off the hose at the bottom by the cord clip and have a look. Also check all inspection air ways to ensure there are no clogs. Usually if there's no suction through the handle a tell tale sign is that something has either got stuck or there's a tear in the hose. Hope that helps.
Feb 22, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson Animal-suction loss
Had the same problem twice and washed the filter to no avail. Called Dyson to troubleshoot, and in one minute they had me removing the purple plastic noodle shaped piece towards the bottom on the side (the next time it was the silver noodle on the opposite side). Inside was a bent pen and tons of debris wrapped around it that slowed the suction. Poked the debris out, and it worked perfectly.
Aug 30, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
I lost the manual to my vacuum
Hi.
If no suction from hose check the following.
The (U) shaped inspection port at the back of machine where flexi hose enters has not come off or has a blockage.
Remove flexi hose from rear of machine once off slide it fully up the wand handle hold handle end up to a light & look up the pipe for blockages.
Check side premotor filter.
Does it pick up ok when using to vacuum carpets or is that got bad suction to ?
http://dc07.atspace.com/
Chris.
Nov 16, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 hose has no suction
Just resolved the same problem...couldn't find a blockage anywhere, but pulled handle out of hose and extended hose as far as possible upward. Aha! There was blockage in the hose at the very bottom where the flexible hose meets the rigid part.. There is a lever which releases the entry to the bottom of the hose. A pencil, lots of coins, a crumpled receipt and general dirt were stuck. Easy to clean and now it works like new again.
Nov 08, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
1,326 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
