Question about Zebra TLP 2824 Printer
Zebra LP 2824
My printer just stopped staying on line after I replaced the roll of labels. The light was green and now its red. It goes green for a couple of labels and then red again.
  • Spazz92692 Apr 29, 2008
    Mine prints one label then back to red, I recalibrate for the labels according to your previous directions then it just stays red.
  • Anonymous Mar 18, 2014
    printer just printer a line & no content on sticker labels
Why the lamp light red and green with print?
Posted on Aug 26, 2012
  • 53 Answers
The error you are getting is a label size error. a label variance of as little as 1/203th of an inch can cause this.
you need to recalibrate the printer to the media, hold feed when powering up the printer letting go once the light flashes 4 times. this will force the printer to autodetect the label size.
if you are specifying the label size in you software or driver settings, measure and double check the label size
Posted on Dec 07, 2007
Printer
Hi
Try disconnecting printer from computer, power off and killing any print jobs in the print queue.
Then check that the printer powers on whilst un-connected to the PC, if light stays green, then the problem is related to PC interface. If the light goes red, then it's a hardware fault, maybe remove and replace cartridge, check no paper is jammed and try again.
Regards
Rob
Plain, Printed and Barcode Labels
May 09, 2012 | Office Equipment & Supplies
After I sent a print job to the printer, it prints out the label required but it does not stop feeding the labels. Please advice how to resolve this.
hi,
- Turn off the printer.
- Remove the labels roll and then load it again.
- Press and hold the green[feed] button and switch on the printer.
- Release the button after it flashes red.
- The printer will run a self test.
- Turn it off and then on again.
- Now print.
good luck!
Sep 15, 2011 | Zebra TLP 2844-Z Thermal Label Printer
2 blank labels are coming out after the correct label
hi dmieze.1.Switch off the printer
2.Remove the labels roll and then load it again
3.Press and hold the green led button and switch on the printer.
4.Release the button after it lights red.The printer will self test.
5.swicth it off and the on and try printing now.
Aug 26, 2011 | Zebra LP 2844 Thermal Printer
My tec b452 printer is showing error red light stays on ribbon and labels are loaded correctly
Check that you are not in direct thermal mode and if the roll is correctly placed on the supports. If the roll is not meant for this printer then you have this error
Sep 11, 2010 | Toshiba TEC B-452 Thermal Label Printer
Everytime I print a label it stops short of the
This is an easy printer to fix since there is only one control button. Turn the printer off. Hold the green feed key down while turning the printer on; once the red light begins flashing, let go of the feed button. This will do three things: the printer will calibrate with the installed media, it will print a configuration label and the printer will go into dump mode. Press the feed key again. One more label will come out with with the words "Out of Dump" printed at the top. If the printer still fails to print, remove the ribbon and try the same procedure with direct thermal labels (UPS or FedEx). From there, consult the manual for more troubleshooting tips.
Jan 29, 2010 | Zebra Eltron TLP 2844 Thermal Label...
Prints only part of label
Fixed problem. Labels were too thin so LED was still being detected to stop progress of labels. Fixed by sticking some backing paper over the sensor and seems to be working fine.
Jun 12, 2009 | Zebra Eltron Orion LP2443 Thermal Printer
Issue trying to print mulitple labels, red light
The physical label size must be set in the printer driver, both in the "Properties" and the "Default" tabs.
Jan 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
TLP2848Z blinking red, will not print
1: Is it a TLP2844 or a TLP2844Z.
Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
Calibration:
If its a TLP2844. Load media. Connect power.
Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
Calibration:
If its a TLP2844z.
Load media. Turn printer on and wait for green light (Approx 1 minute)
Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
Dec 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 2824 red light
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Sep 03, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2824 Printer Logo
1,172 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
