Connecting a surround system to yamaha rx-v660 receiver
Connecting a 5 speaker surround to rx-v660 yamaha receiver is easy, but how do I connect a subwoofer to this system?
  • lcorrell Dec 22, 2007
    How do I connect a KLH Bassbite III audio system to a Sony STRDE595 receiver?
5 Suggested Answers
remington870
  • 48 Answers
SOURCE: Speakers connection
There shouldnt be a problem with that at all. The subwoofer needs to be self powered. The Yamaha has a "Subwoofer Output" on the back. Just connect it there.
Posted on Apr 04, 2009
easyq
  • 144 Answers
SOURCE: The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
Posted on Apr 17, 2009
tvservice306
  • 458 Answers
SOURCE: Yamaha RX-V660 Display Light Out
if you not tech ..suggest send to service
this problem is display negative voltage missing......or display driver ic bad.....
Posted on Nov 11, 2009
guru_fixya
  • 944 Answers
SOURCE: I have a Yamaha Receiver
No it is not compatible to use RX-V 467 with Bose Lifestyle Acoustimass 9.RX-V 467 is a 5.1-channel AV Receiver.
Bose Lifestyle Acoustimass 9 subwoofer are designed to be used with their special equalizer and require a 'Pre-Out Main-In Coupler' or 'Tape Monitor' connection. The compatible models are the:
  1. RX-797 (Pre-Out/Main-In)
  2. RX-497 (Tape Monitor)
  3. RX-397 (Tape Monitor)
  4. AX-596 (Pre-Out/Main-In)
Even though you try to connect it will have buzzing noise or no sound.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 14, 2010
Speakers not playing
The problem can be the cable or speakers or RX-V463 or settings. Need to check one by one.
Set the RX-V on DTS or Dolby Digital
1) Check Cables - connect the 2 (surround) cables from RXV's Centre Out to Centre speaker. If the Centre speaker works, then cables are ok.
2) Check speakers - Connect each Surround speaker to RXV's Centre out. If it works Speakers are ok.
3) Check RXV - Set it on DTS or Dolby Digital
Connect RXV's surround out (one at a time) L and R to the Centre speaker. If there is no sound, the problem could be RXV's settings (I need to read the manual).
Hope this helps.
Nov 20, 2013 | Yamaha RX-V463 Receiver
Yamaha Receiver RX-V3800 Rear Left surround click sound
It's possible it is some sort of interference pickup, but another possible I've come across a number of times on Yamahas is poor earth connections via the back panel.
All the circuit boards have earth connections on them and the screws holding them to the back panel form an earth bonding connection. Tighten all the screws on the back to eliminate this possibility. Costs nothing to try and may just solve it.
Jul 19, 2010 | Yamaha RX-V3800 Receiver
How do I connect my Yamaha RX-V463 surround sound system to an analog tv? The tv only has the three RCA jacks for audio and video. the RX-V463 has many jacks, and the manual is no help. the manual does...
Actually, the Quick Start Guide on page 6 of the manual shows the TV connection.
Consider that the TV is simply a visual element in your entertainment system and the rest will sound easy.
Run a single RCA cable from the receiver to the TV's Video IN so you can use its menus and view whatever video comes into the receiver.
Manage whatever audio you want to hear in HI-FI directly from its source to the receiver and NOT washed through the inferior audio electronics and speakers of the TV.
Jul 18, 2010 | Yamaha RX-V463 Receiver
I have a Yamaha RX - V665 and the right rear surround works only part of the time.
Start by using an old test speaker and connect it directly to the right surround output with a short wire and monitor it.
If it sems to work with no issues, you either have a bad connection at receiver or speaker, or a break in the speaker wire somewhere.
If you have the same problem with the test speaker, you have a rgt. rear output issue in the receiver and it needs repair.
Hope this helps
Apr 17, 2010 | Yamaha RX-V663 Receiver
Not enough bass going to speakers
Are you using it in full surround? Check all of your connections on the speakers,check the inputs and check your eq settings.
Dec 26, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Nov 09, 2009 | Audio Players & Recorders
Hooking up a Logitech Z-2300 subwoofer to a Yamaha RX-V392 receiv
This is the exact same setup im lookng at, just a different Yamaha receiver (RX-V663). Since the 3.5mm headphone jack and and the sub preout are both 'line level' you just need to pick up a male RCA to female 3.5mm jack converter from radioshack. I'd expect it to be around $5-8.
I have already stripped my old 5.1 HTIB system rca connector to use the surround speakers with my receiver. They work but are cheap speakers. Im tempted to do something similar with the z-2300 speakers, much higher quality, but I would definitely use a converter instead of stripping to keep them backwards compatible.
Jan 10, 2009 | Logitech Z-2300 Computer Speakers
Yamaha RX Z9 and two-channel system integration
The A-B speaker switch is intended to direct amplifier output to a pair of speakers in a different location when set to B.
Feb 26, 2017 | Televison & Video
Yamaha RX-V660 right channel gone
Try checking the connections.
If your really value your receiver it would worth it.
Jun 22, 2008 | Onkyo TX-DS575 Receiver
552 people viewed this question
 Grubhead
Grubhead
