Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire washing machine
My frontload washing machine won't start a cycle ,it won't spin and it sounds like water starts to fill and then stops about 3 seconds after it starts.. model # LTF2940ES0
  • 2 more comments
  • djspears Dec 05, 2007
    how do i check if the door switch is bad
  • Anonymous Feb 24, 2008
    Frigidaire, front loader washing machine (3 years old) starts to fill with water for about three seconds and then stops ... checked the soap dispenser, inlet and outlet hoses, and water pump. All seem to be OK. Any ideas on how to resolve this problem?
  • holaday Mar 10, 2008
    How do I check the door switch for loose wires? I also have a front load Frigidare washer model # LTF2940ES0 (2 years old) which does not drain, spin, fill...
    The washer attemps to fill for about 3 seconds and then stops.
  • Anonymous Apr 12, 2008
    start washer startes filling stops and wont run
Firemanjim was dead on. there is a white connector on the mother board on the bottom of the cabnet. there is two sets of wires, one small and one large. the small wires connect via a small white connector. you can gain access by lifting the lid and pushing it back down. thanks fireman jim!
Posted on Mar 12, 2010
LOOKS LIKE WE ALL HAVE THE SAME MODEL AND SAME PROBLEM. WHAT'S THAT TELL YOU? THESE DAMN MACHINES SHOULD BE RECALLED. MY REPAIR PERSON CAME OUT AND REPLACED THE SECONDARY DOOR LOCK SWITCH. TURNED ON THE MACHINE AND OTHER CODES STARTED TO FLASH. TURNS OUT BOTH FRONT AND REAR MOTHER BOARDS BLEW. ITS NOT WORTH SPENDING THE MONEY ON THEM SINCE THEY ARE OVER $200. EACH. FRIGIDAIRE WILL HEAR ABOUT THIS!!!!!!!!!
Posted on Apr 05, 2008
OK Check elec plug at motor . Mine was doing exac same thing . Take belt access panel off back and pull wire plug off motor and push back firmly on . This plug does not have a tab so vibrates off . Good luck .
Posted on Mar 12, 2008
    President:
  • 1,294 Answers
Check to see if any wire is loose on the door switch, after removing the plug from the wall socket........Also check your water inlet hoses and hose filter screens. The water inlet valve on wall shd be opened well, before you begin wash.
Posted on Dec 04, 2007
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Frigidaire GLTF2940ES Front Load Washer Logo
659 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
