Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Door leak The dishwasher is 2 and half year old and is randomly leaking for at least one year or even more. The leak originally occurred at both lower ends of the door, close to the hinges. The leak was about one liter and the door panel sound insulation soaked with water. After door panel was removed, the leak location was identified at both ends of the lower door gasket. The outside part of the U-shaped gasket was filled with water, and eventually water was spilled on the floor. The leak can go away for weeks, but it comes back. If the cause of the leak is the faulty gasket, why it occurs randomly? Could it be a pressure build-up in the tank, I checked the vent valve and hose on the side wall, it looked OK, so what is it?Thanks,sab from Montreal
I had the same problem. On the right side of the tank in Bosch dishwashers there is a steam port. If you place a large object in the right hand edge of the tray, a pressure build up causes the leak. Put large stuff on the left and you should be good to go!
Good luck.
Posted on Jan 17, 2008
Why is my dishwasher leaking soap foam from the lower left area of the door?
A leaking dishwasher can be caused by excessive soapsuds. Excessive soapsuds are the most common reason dishwashers leak. Excessive soapsuds will cause dishwashers to leak from the door. Good dishwasher detergent will have no more than half inch of suds on top of the water. So any time your dishwasher is leaking from the door open the door, if there is more than a half inch of suds your problem is in your soap. One drop of hand soap, hand dish washing soap, or any other soap will cause dishwashers to leak. Now, I am not suggesting that you intentionally put this soap in the dishwasher because if you did the soapsuds would be from top-to-bottom of your dishwasher. Now if there are a lot of suds you can fix it by pouring vinegar or cold water into the dishwasher and running it, this will kill the subs.
Jul 08, 2013 | Computers & Internet
The top draw has a small leak in the back. Its about 5 years old. How do I pressure the lines to find the leak?
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Answer 2 (Door seal replacement)
Hi
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repair person. The door seals on this Kitchenaid dishwasher are pressure fit into a metal channel that runs along the inside of the wash tub.
To install, simply remove the old seal paying close attention to which way it was installed, apply a bead of adhesive inside the channel, then install the new seal in the correct direction. A test fit prior to applying the adhesive is a good idea and if you are having trouble with one side being to long, try folding the seal in half, take hold of the looped end, and insert it under the door latch. The reset should go in properly. The new seal will be a tight fit which is the way we want it so it may take some force to get it fully seated. If the door is hard to close, then the door seal needs some more work.
Thanks
Rylee
Nov 09, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Whirlpool dishwasher du915PWP leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
hk
Nov 07, 2009 | Whirlpool 24 in. DU915PWP Built-in...
Leaking door on Bosch dishwasher
I DONT THINK THERE IS A ASSEMBLY MANUAL BUT THE DOOR HINGES IS LOCATED UNDER THE LEFT AND RIGHT SIDE OF THE MACHINE. YOU HAVE TO CHECK THE HINGE PULLEY THEN CHECK THE LOCK.
Sep 23, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Maytag Jet Clean leaking through right side of door during rinse
It is important to examine the leak to see where it probably originates.
If the water is leaking from the right hand side of the door on your dishwasher, it is time to replace the gasket that seals the door when the door is latched.
Aug 10, 2009 | Dishwashers
WP Dishwasher leaks when washing but not when draining.
This type dishwasher has a gasket/seal beneath the lower rack (sump gasket)
You would be able to see it if you pulled out the lower rack and removed the lower arm and filter (please only do this if you are mechanically inclined. Also, replacing a sump gasket is a MAJOR repair and pretty tough to do. You don't say how old this dishwasher is but if it is more than 4 years old, unless you have an extended warranty, it is probably best to replace rather than call for repair service.
Mar 28, 2009 | Whirlpool 24 in. DU948PWPQ Built-in...
Dishwasher is leaking from under the door
the lower door seals may be damaged or contaminated with old food debris. also check the "n" seal around the door are clean.
Mar 18, 2009 | Frigidaire 24 in. FDBB944C Built-in...
GE Nautilus
make sure the door is not hitting on cabinet when shut.
Dec 31, 2007 | GE Nautilus 24" Built-in Dishwasher
It's Leaking Water!
Most common reason is that the lower spray arm splits on the seem and sprays water under the door, to proove if it is this remove lower spray arm and run through program if no leak fit new arm. Regards Advisor
Aug 30, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
377 people viewed this question
Top Bosch Dishwashers Experts
shaun taylor
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
