Question about Samsung SCH-u740 Cellular Phone
Dead phone I think????
Hi My problem is ... When I flipped open my phone the inside screen was white ...so I pulled the battery out and put it back in in hopes that it would restart it because nothing else worked. It had been sitting in my purse for a couple of days never bumped or got wet....battery was still on 2 bars...now even plugged into the wall outlet... won't even turn on. ... any suggestions???
Thanks,
Lynne
  • dart501 Dec 07, 2007
    I have just recently had the same problem with my phone. Verizon will not warranty it because they said it was abuse/neglect which I have no idea why they would say that I've only had it for a couple of months and looks brand new.
  • gallina43 Dec 08, 2007
    I did bring it back to verizon and they gave me a new one ...they said it was a software problem... thanks everyone
This cannot be a software problem; it is a loose connection from the phone itself to its LCD. if you press the screen it should flicker back and forth. I am having the same issue; I of course, did not buy insurance on the damn thing. Does anyone know how to open this thing up to play with the connections? I have basic knowledge of electric devices the problem here is opening it without further hurting the already ailed phone. Suggestions welcome.
Posted on Dec 11, 2007
  • 4 Answers
I have the same phone and it kept turning off on it'ds won. It may be defective. ou should definitely bring it the store for the warranty.
Posted on Dec 08, 2007
Phone got wet in salt water-let it air dry for 4 days-sim card ok-top screen works-when flip phone open-other screen lights-up but is blank-can't pull-up menu-when put battery in-phone...
Take the phone and place it in a bad of minute rice....the rice will pull the remaining moisture out of the phone... however the corrosive nature of saltwater may have left deposits inside the phone that are causing it to malfunction...it may never work correctly again... but try the rice before giving up on it...even the rice may take a few days to work...
heatman101
Jun 25, 2011 | Cell Phones
Last night my blackberry pearl flip 8230 wouldnt let me open my text messages, so i figured it just needed to be restarted, so i pulled the batter waited for a couple seconds, and put it back in. but...
hi,
dont panic .i think your battery is fully drain.it will not charge whatever you are doing so you need to charge it in a desktop charger..unplugged your battery and put the desktop charger and wait until it was full charge..
i hope it will help you ,thanks for trusting fixya
Jan 27, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
My samsung screen is white but it works ive tried everything, this hbas happen before screen going white and the battery had to be without juice to come back. it works but ithe screeen is white
hi, the main reason the screen turns whits is due to the thin ribbon that sends the data from the circuit board to the screen being damaged what happens is that the thin copper wires that are inside the ribbon ware and then break causing a short to the screen and this is what turns the screen white. this happens on most flip and slide phones as the ribbon moves when you slide or flip the phone so over time it becomes brittle and you lose the connection and this turns the screen white.
sometimes it will right itself if you open and close the phone a couple of times but this wont be a long term fix how ever it may be that bad that this will no longer work, its not expensive to get this ribbon replaced but taking you phone to a small phone shop would be your cheapest option.
May 14, 2010 | Sony Ericsson K800i Cellular Phone
The screen is all white and when i flip it open
just make sure that your phone is original and not a china phone!
Feb 09, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
When you flip phone open inside screen stays white
Moto RAZR phones are notorious for this. Best thing to do - Get a new phone. Inside of the hinge, there is a sensor that detects if the phone is open or shut. When you open the phone, it still thinks its closed, so the screen stays white, and if im correct the outside display should still work. Pretty much not-fixable unless you know someone who can take it apart and re-position the sensor (will void the warranty)
Best thing to do....Upgrade.
Nov 26, 2009 | Motorola Mobility RAZR V3
V3 wont recognise when flipped open.
It means ur handsets display strip occured problem
there is only one solution that replace the STRIP
May 19, 2009 | Motorola Mobility RAZR V3
Blank or White screen on new Motorola Krzr k1 cell phone
found the solution to the white screen! it's the flip sensor.. what you have to do is open the phone hard and fast... make it so when you flip it open, the sensor knows when to turn the screen on and off.. this may take up to 5 or more times.. jus keep opening it hard and it will eventually work!!!
Dec 05, 2007 | Nokia 6233 Cellular Phone
V3 problem
There's a small magnet in the flip that tells the phone that the flip is closed.  the sensor in the body of the phone is still thinking that the magnet is near it, so it thinks the phone is closed.  if you don't have any magnets near it (a phone holder with magnet closers, cover, etc) then it'll need to be repaired.
Oct 17, 2007 | Motorola Mobility RAZR V3
Samsung SCH-u740 Cellular Phone Logo
49 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
