Question about RCA 32V420T 32" TV
RCA 32V432T television ,Turns on and off on its own and runs through channels continuously
Can you help me determine what to do? victor_millard@yahoo.com
  • 4 more comments
  • jdjmsavage Feb 15, 2008
    Yes I have a similar problem and the volume goes all the way to maxium. Please help.
  • Anonymous Jun 12, 2008
    tv turns on/off by its self and the volume goes up on its on. tv works fine until it warms up, then starts acting up.
  • Anonymous Oct 04, 2008
    I have the same problem. It has now gone to completely dead.
  • Anonymous Oct 13, 2008
    Same problem
  • Anonymous Oct 14, 2008
    I have the same problem with my RCA 32V432T television and while looking through the schematics I have found and reading other posts I have found, I do believe it is the circuit board at the front panel. Mine use to turn on and off. I thought I had it fixed but now the volume goes all the way up. Thought I fixed it but now it turns on by itself and turns the volume all the way up. Bloggs lead to "leaky tack switches", what the buttons you push on the front of the television in turn press against on the circuit board, as being the problem. Some choices: re-solder all the connections, check if the IC is installed correctly, re-solder the IC or replace the entire board. The part number for the board is PN# 270961. Good luck.
  • chad_prive18
    chad_prive18 Oct 10, 2012
    whoever posted this tip i say THANK YOU MAN
The problem is most DEFFINATELY the control board behind the user buttons.
You have 3 options to fix this...
1. Replace the new board completely (no garuntee your getting a "new" part).
2. Replace the tack switches (requires soldering and patients [alot of them]).
3. Remove the board and snip the one wire marked "Key". I didn't snip it so much as correctly pulled the wire out of the plug itself. By removing that one wire from the board you disable just the buttons. You still have complete use of the remote. Who the heck walks over to the TV these days anyway!?!?
Posted on Oct 23, 2008
Thanks to Jean JG my RCA 32v420t is now working again. I was having the exact same problem, found the source but did'nt know which wire to cut. So I followed his advice and snipped the wire marked "key". My TV now works like a charm, with the remote of course. Thanks again. I hope somebody else will find this as useful as I did and fixes their "RCA" or should I say P.O.S? Needless to say RCA has lost yet another customer forever
Posted on Jan 19, 2009
My tv is also a RCA 32V420T. It started turning its self off and on and searching the channels on it's own. This madness went on for a few days, tried reset by unplugging overnight and cleaning, then banging on the front panel. It did stop the insanity. Then, about 6 months later, it started doing it again! So, after trying everthing again with no luck, we took drastic measures and cut the Key wire as suggested and happy to say -the TV instantly was under control. The second wire down was clearly marked Key on the circuit board that the switches are on, so there was not much chance of cutting the wrong wire. Was an easy fix for a frustrating problem, do not by afraid to try it yourself. Cannot use the buttons on the TV manually, but the remote works as it always has. Thanks to all with great the advice!
Posted on Feb 24, 2010
  • peggychilder
    peggychilder Aug 11, 2012
    Thanks so much for the advice. It really worked!!!!!!!!!!!
Hello everyone, I have the same problem with a RCA 32V432T and it first was turning itself on and off and scanning for channels. Now it turns on shows CATV 1 and goes off , then turns on and off over and over. I removed the front control panel and it looks ok no loose solder joints or " leaking " ....looks like the day it was made. There really isn't much to this panel a few resistors etc but not much at all. I am about to cut the wire marked KEY but before I do , does anyone know of anything I can do to this panel which will fix it? ...man I am beginning to really hate this RCA TV , it's only a couple of years old and its already going south !
Posted on Sep 17, 2009
I encountered the same problem with my RCA 32'' TV Manufactured in 2008 in Mexico. After trying everything I found on the Web, from a hard reset to banging on the TV Cabinet, I decided to investigate the problem myself. I opened up my television set and looked around for any loose or burnt parts. I did not see anything... I plugged the tv back in and it started turning on and off again. I traced the cable from the front panel to the main board and while keeping the TV plugged in I unplugged the connection from the main board. Finally the TV stop turning on and off. Aha!. Plugged the connection back to the main board and it started turning on and off again. Finally I had nailed the problem. I took that little front panel out which is very easy to do. Took it to my place of work and analyzed it under a 5x microscope. It seems to me that RCA did not do a good job on that section of the TV. It looked wet as though something was draining from the wires plugged into that board. I sprayed it with isopropyl alcohol and used cloth the clean up the connection where it looked wet. Then blew the alcohol off with air. Voila! I brought it back home, place it back on and now I do not have any problems. It works like charm. To me that board is what is causing RCA to act like they have ghosts inside them. I dont expect it to happen again, but if it does, I will just buy a replacement for that front panel board. Thanks all, I hope my experience helps everyone out there.
Posted on Oct 16, 2008
Take the control board ( that thing wich the buttons are attached to) off then find the word `key' on it follow its path to the wire and snip that wire
note: this will disable the buttons on the tv but u can still use it with a remote control ive done it works my tv doesnt turn off on its own anymore
Posted on Oct 10, 2012
The way the tact switches are built, they have a metal plate on the front and grounded metal on the back. They seem to be acting as a capacitor and sending false information to the CPU. I soldered a wire from the front of the tact switch to the back thereby grounding the front metal of the tact switch. Problem fixed.
Posted on Nov 26, 2009
    Problem Solver:
  • 13 Answers
Kudos to andredibrava on his solution. I removed that circuit board behind the switches and there was a clear goop around some of the solder joints. I cleaned it with a qtip and rubbing alchohol. It works great now.
Posted on Nov 13, 2009
Mine turns on and off by itself,i was on this website looking forr an answer
Posted on Jun 09, 2008
Same prob here.If anyone know please let me know the tv is only 2yr old.thanks dragonmaster5565@yahoo.com
Posted on Jun 01, 2008
Rca 32" 32v432t
What is the problem with your RCA TV? Provide some more details, please.
Jun 23, 2012 | RCA TruFlat 27F520T 27" TV
I have an 32 rca t.v my son has locked and won't
I got this from the manual. Page 26.
Press MENU to see the main menu.
Press CH+ or CH- to highlight preferences.
Press OK to enter the preference submenu.
Press CH+ or CH- to highlight Par. (Parental) Control.
Press OK. Enter Password will appear on the screen.
If you want to set a new code, go to steps 6-8 directly. (You can press the number buttons to enter a four-digit code. The code "0000" is the default password. If you have not set a code previously, then "0000" is the code.)
Resetting Your Password
Press VOL+ on the remote and the CHANNEL + on the front of the TV at the same time. Enter New Pwd. will appear on the screen. (You must be in the Enter Password screen when attempting this.)
Press the number buttons to enter a four-digit code. The code will appear on the screen as you enter it.
Press OK to save the code.
Press MENU repeatedly to exit the menu or the menu will automatically disappear within a few seconds if no buttons are pressed on the remote control.
If you need more, get the manual here:
http://www.retrevo.com/support/RCA-32V432T-TVs-manual/id/402ci372/t/2/
Pages 25 through 30 are all about lock and channel/show blocking.
Jun 05, 2012 | RCA Televison & Video
I have a 32" RCA 32V432T TV that only shows snow now. I've checked everything externally but still no picture. Any solutions?
There could be several things that can cause this: 1. There are no analog channels in your area. 2. Check the menu setup and verify that you select the proper input (antenna, cable, etc). 3. The TV tuner is defective Try using the composite input on the TV (there are normally 3 jacks per input). Yellow for video and red and black for audio. If you dont have the proper cable, pick one up in you local 99 cent store or an electronic store.
Connect the "output" of your device (VCR, cable box, Tivo, dvd player, etc) to the "input" on the TV. Then use your TV remote to select the proper input.
Hopefully this helps. Good luck.
Sep 27, 2010 | RCA 32V420T 32" TV
Lightning Surge, RCA 32V432T, will not power up
Throw TV AWAY,these tvs had alot of problems without lighting hitting them,It probably played out FBT flyback transfomer CK hori out put Transistor if shorted replace FBT also.
Aug 06, 2009 | RCA D52W19 52" Rear Projection Television
Television turns on and off, turns up volume and changes channels
Hi
Replace all tact switches at the control panel... all switches is have bad resistance thats why your system is abnormal!
Thanks!
Feb 24, 2009 | RCA 27V520T 27" TV
Rca tv model 32v432t
This set is not digital tuning and you would need a converter for off-the-air reception. You can get full specs and manual downloads from RCA's site:
http://tv.rca.com/en-us/productdownloads.html?MN=32V432T
Nov 18, 2008 | RCA 32V420T 32" TV
Rca 32v432t tv plays,turnsoff,turnson, and stays in autochannel search mode
your going to need to do a resolder of dry looking solder jobs and or poor solder jobs
this could also be your front control board , try disconnecting it and see if the tv stays on
it is possible that the sensor has gone bad or the crystal needs to be replace or worse the EEPROM
my rca 27 in was doing the same thing , i resoldered the board and it worked great for 7 months
so do a resolder of all suspicious solder and heated components
then let me know what happens
also what is your model # for your rca tv ?
also one of rca's kits for repair is some solder and paste , so that should tell you something in its self about rca repairs ( the solder with the paste is supposed to make it handel heat better )
please give a fixya rating so that if you need more help in your tv , I can continue to help you further , thanks
electech
Nov 08, 2008 | RCA 27V530T 27" TV
32" rca picture stretched
Before you fool around with this, it may be under warranty. Check that first. Second, does the picture stretch in both directions or just vertically? If just vertically is it more pronounced at the top?
Thanks,
Dan
Apr 03, 2008 | RCA 32V420T 32" TV
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
RCA 32V420T 32" TV Logo
2,287 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
