Sanyo tv # DS35580
Tv has nothing but snow. tv says no antenna hooked up but there is a cable hooked can play dvd's and when I was playing with remote I did get a picture for a sec.Yes the cable is ok I think or should I say Hope it's just a setting. I have done many channel searchs. for awhile that worked but now nothing but snow. thank you Linda
You need a new tuner
Posted on Dec 26, 2007
    Problem Solver:
  • 7 Answers
Check the 33vdc on one of the pins going into tuner,
if present, open tuner box and check all the grounds
around the edge for bad connections
Posted on May 02, 2008
My tv just went off all at once to nothing it just looks like snow on it thats it and we have it hooked up to cable and was viewing it at the time
snow is an indication of signal failure either from the station or an antenna connection problem
if it all channels then I would be looking at the cable connection at the cable box or outside antenna connections
Mar 03, 2016 | Panasonic Original Pansonic Tv Vcr Dvd...
Fix tv picture
If the TV is receiving its signal from a cable TV box or DVR then you need to find out if the problem is in the TV or the cable box/DVR. Connect a different source to your TV such as a DVD or Blu-ray player and play a DVD movie. If the problem occurs again it suggests the TV needs repair. If the TV works OK when playing a DVD movie then that suggests that your cable box/DVR needs repair or replacement.
If your TV is receiving its signal directly from an antenna or cable outlet on the wall then you should try replacing the cable wire from the wall to the TV with a new wire. If that doesn't help then your TV probably needs repair or replacement.
Dec 29, 2015 | Sanyo Televison & Video
My tv sanyo cm21kf81A, chassis number FC3-G221 has snow noise on all tv channels, but AV1 and AV2 play good sound
First check cable wire or whatever is connected to set for channels--the leads are connected and wiggle them with set on to see if it clears up--could be a connection where cable wire is connected at end--loose connection there etc.
If tuner is bad causing this and you use a box for signal--most have rear audio/video outputs you can connect to a unused video/audio input on rear of set---bypass the tuner in the set and operate set that way changing channels on box instead of set.
let me know if you have questions or have more information.
Mar 21, 2012 | Televison & Video
I'm not sure how to connect my Toshiba SE-R0346 to my Sanyo TV. I plugged the cable line into the "Antenna in" port & then another cable line from "Antenna Out" to my TV. If I...
Exactly as you have done is fine all you need to do now is play the tape, (so you know what to look for when it is displayed on the screen), decide which channel you want to view the vVCR through, say 9, select the channel and set the TV to search tune on that channel. Store it when your taped programme appears.
Alternatively, have the set up as you have described and press auto install. That will retune the whole of the TV and include the VCR.
Hope this helps.
Nov 03, 2010 | Toshiba Televison & Video
Can we record with our sanyo drw 500 and a digital tv? If so, how do we do this?
If cable/SAT box, hook-up that box video/sound output to DVD video/sound input. If no cable/SAT box, hook-up cable from wall into antenna/cable in on DVD and tune DVD to channel wished, and hook-up DVD TV antenna out to TV antenna in. If DVD has no antenna/cable in, TV must have video/sound output. Hook to DVD video/sound input. Hope this helps.
Apr 18, 2010 | Sanyo DRW-500 DVD Recorder
New sanyo hdtv and old vcr...can't get menu to appear on screen
there is an input or input select button that gives you cable,hdmi and video composite,to run the vcr. hook up cable and put the tv on channel3 to make sure that works first,then play with the rca cables. keep in mind a tape has to be playing,the new tv have a signal sense circuit,if there is just "snow" you get a blue screen
Jul 22, 2009 | Goldstar GVR-E435 VHS VCR
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting you can record 1 cable..2.vcr dvd..3 make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
Bought 2 DTT-9900 converter boxes and hooked them to 2 TV's, get signals after playing around with antenna. but after using both TV's to play a dvd (dvd player hook to TV) The sound went down to almost...
Try turning off the converter box when using the DVD player. The zenith have a second sound control on the converter box remote thus you may have to adjust the sound on the tv remote because you are using the dvr. I set the zenith sound level at the highest level and use on the tv remote only to adjust sound. This eliminated a hiss that the sound control on the converter box was causing.
Apr 28, 2008 | Zenith ZN110 Remote Control
No Video
You can get a converter box for dvd hookup to the cable connector at the back of the set at Wal Mart or Radio Shack.
Dec 27, 2007 | Sanyo DS27910 27" TV
Stuck on Channel searching!!!
the problem is we have no cable-none at all. The tv is used only for playing DVD's. solution check dvd to tv wire or socket if it is ok then play dvd in another tv if it works fine then problem in tv. for that check tv tuner & its circuit for loose. check tuner itself
Sep 11, 2007 | Sanyo DS20930 20" TV
Televison & Video Logo
221 people viewed this question
Top Televison & Video Experts
