Question about Samsung HP-T4254 42 in. Plasma Television
Hdmi i tried hookin up my dvd player to the hdmi 1 and 2 with different cable hookups and i get sound on both but no picture. what gives?
    Scholar:
  • 137 Answers
When these set first came out, the HDMI connector was not properly bolted down. With the weight of the HDMI cables it would break the solder and thus separate the HDMI connector from the main board. The ONLY way to fix this problem is to change the Main board. Part number BN94-01226A. Average price $172.65
Posted on Dec 06, 2007
New 50" hisense tv .. unable to use hdmi for cable box .. tried different cables and all 3 hdmi outlets on tv ????
There might be a setting on your cable box for audio output. Use the cable remote and look in the audio section of the settings menu and select HDMI output. Mine is under Audio Digital Output in the Audio/Video menu.
Feb 21, 2015 | Hisense 50 Class 1080p LED Smart HDTV -...
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
Vizio blu ray player
Have you tried a different hdmi jack, or a different cable?
May 05, 2013 | Televison & Video
Screen on Philips Flatscreen HD has turned green there is sound on all Freeview stations only, no picture but DVD player works perfectly well and in full colour Why is this and what needs fixing. Freeview...
If the hookup is HD from a box you have Green(video) Blue and red--check first they are connected properly at both ends. Component would also use two more cables for audio.
If HDMI maybe a bad cable or issue there. HDMI has issues with and creating no sound problems.
If a DVD player does work fine it means a hookup issue of some kind or a very odd problem in the set(unlikely).
SD TECH
If using HDMI at least attempt a component hookup.
Apr 22, 2012 | Televison & Video
Philips DVP 3982, 4 months old, hdmi connected to vizio tv. Suddenly now it plays sound but not picture. If I hook it up with composite cables it works, but of course the picture isn't very good. I tried a...
I have few options for you to get the video back on HDMI:
1. Try out changing the video resolution on HDMI set up (select 480p..1080p).
2. Play NTSC disc (to get the 60Hz out from Player). If your are in US.
3. Select the TV system as AUTO/NTSC to get the 60Hz out only on HDMI.
4. if the Deep Color option is available in HDMI set up menu..set it to OFF.
Let me know if you tried all these and still no output.
Apr 26, 2010 | Philips DVP3982 DVD Player
When i use a hdmi cable in my samsung dvd hd860 there is no sound, why is this
I had a Samaung DVD VR-375 and it plugged straight in and had video and sound both with one HDMI cable. BUT I also have 2 new LCD TV's that provide and additional audio hookup to go with the HDMI hookup. Look for an audio OUTPUT ( L and R) from your Samsung HD860 and electrically connect it to your TV input associated with HDMI marked L and R.
Sep 17, 2009 | Samsung DVD-HD860 DVD Player
Malata DVP 892 hookup problems
I had the similar problem at first. You need to use another disc before you can configure the video output. Make sure you enable the HDMI output.
Apr 21, 2008 | Wanlida Group Wanlida/Malata Combination...
Help!
Try pressing the HDMI button on your remote a couple of times, pause about 5seconds after each press it might be slow to change. If this doesn't work try connecting just the yellow lead(composite video) into the DVD player to the TV like the old days, probably AV1 or AV2 in the back of the TV. Then access the setup menu(setup button on remote). This will bring up a menu. Use the down arrow on the remote until HDMI setup is highlighted. You should then get a selection to turn HDMI on and select the different outputs(576, 720p, or 1080i). You might actually find the picture to be worse on some DVDs.
Apr 06, 2008 | Televison & Video
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
Samsung HP-T4254 42 in. Plasma Television Logo
101 people viewed this question
Jerry Greenberg
Jerry Greenberg
