Question about Reddy Heater-30-55,000 BTU Variable
Please HELP When the motor runs but will not ignight
  • Anonymous Jan 07, 2009
    The fan will begin to run however the ignitor won't start the heater
  • Anonymous Jan 16, 2009
    fan runs does not ignite
  • 625 Answers
Www dot desatech dot com is a parts distributor for reddy heat products. on their main page they have a short troubleshooting guide. the motor needs to provide 3.5 psi of air across the fuel nozzle to suck the fuel out of the reservoir. check your ignition source (spark plug, hot surface igniter) if the hot surface igniter is broken get a new one, if the spark plug don't spark, check the gap might be too big. see if the spark plug is grounded. poor grounds will cause intermittent sparking. check the high voltage wire for breaks in the insulation, might be shorting out to ground BEFORE the plug. gap should be 75 thousandths.
Posted on Dec 06, 2007
Ive got 40000 reddy heater 1yr old. plug it in the ignitor glows and fan starts turning, but no fuel comes out. then it shuts off
Posted on Dec 29, 2007
Bradford White gas power vent water heater; just replaced power vent motor and fan assembly because a bearing went out. Now the new fan motor runs constantly without igniting. Is there a switch that...
Some how you have disconnected the sensor that tells the main burner that the fan is on. Its trying to light but cant. On some models there is a air pressure switch that reads the pressure inside the vent pipe itself. It will have a small hose on it and if that has cracked or was not replaced it wont light. This is how its supposed to work--- vent fan comes on,sensor confirms fan is on,hot surface ignighter starts to glow red,and main burner is opened,another sensor confirms that main burner is lit,then hot surface ignighter turns off. Hope this helps.
Jan 11, 2013 | Water Heaters
Kenmore 80 series dryer is not heating, please help
Check the vent to make sure its not blocked in-line and outside.
Gas or electric? Gas, you'll have to check your thermal fuse for continuity and then your ignighter. Electric check your heater element for continuity and then the thermo switches also for continuity. You should also check your door switch and after all that if that doesn't help check the motor is sending the signal...even if it is spinning the motor.
Thanks,
Shawn
Jan 31, 2011 | Kenmore 63942 Dryer
Will the fan on the reddy heater not run if the ignighter is bad? When i plug it in the fan doesn't run.Do i need to replace the motor?
The fan motor runs regardless of the igniter as it is also the fuel pump. Possibly you may need to replace the motor but try this first. Remove the top section of the heater this exposes the fan motor, try spinning the motor by hand,it should spin freely if it does not try some light oil in the front and rear bearings of the motor and turn it by hand until it frees up. You may need to do this several times!! Now that it is spinning free put the heater back together and try it out. If it does not work a new motor is in your future. Hope this works out for you.
Dec 26, 2010 | Reddy Heater-30-55,000 BTU Variable
When oven is turned on ignighter glows but gas is never relesed to ignight.Would only happen once in a wile and was fixed by shuting oven off waiting a few min. and then turning back on.problem has been...
Sorry to read about your problem, I hope this helps you out.
You have a sticking gas control valve, or defective
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire FGF326AS Gas Kitchen Range
R55B Reddy Heater won't stay running. (PMS? menopause?)
Wow! Yours is the best description of a problem I have ever seen!!! Before I read the whole thing I figured you missed the pressure check as most people do but you nailed it. This is what I would try, Replace the air filter, the fuel filter, and the fuel (to make absolutely sure there is no water in the fuel) and readjust the fuel/air mixture. If that does not do it replace the cadmium cell they only cost pennies. Let me know how you make out and good luck.
hardrocko
PS, I have one of these so I am pretty familiar with the problems.
Feb 03, 2010 | Reddy Heater-30-55,000 BTU Variable
Runs but does not get hot. ignighter works, but it runs forever,I changed the thermal fuse but that did'nt help.????????????
Hi, If the ignitor glows and then shuts off before the gas ignites, you will need to change the coils on to of gas valve.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Jun 26, 2009 | Dryers
OVEN WON'T WORK
you need to replace the bottom oven ignighter take the racks out then remove lower oven bottom take it out then remove flame spreader and ignighter will be on burner bar get replacement from appliance repair store take model number with you just because it glowes don't mean its good it should light withen 30 seconds
May 24, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Dryer Ignitor turns on then back off with no flames afterwards
the government mandated that gas appliances start using electronic ignighters because pilot lights would keep blowing gas even after they blew out now the way they work is calibrated on how much amps the glow bar draws the rest of the amps go to the safety valve to open it when the glow bar is drawing enough amps to be hot enough to ignite the gas now what this means is even though the glow bar glows it can still not be hot enough to ig night the gas so the safety valves don't get the right amps to the solenoids to open so you could have a weak ignighter or bad solenoids on the safety valves now i would lean toward the solenoids but i would buy both and first replace the solenoids then the ignighter if the solenoids work take the ignighter back
May 22, 2008 | Kenmore 74602 Gas Dryer
Reddy Heater-30-55,000 BTU Variable Logo
293 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
