Question about Memorex MMP3731 MP3 Player
Missing program for mmp3731b
Well I lost my setup disk for my mp3 player memorex mmp3731b. Any options
  • 9 Answers
SOURCE: RCA M4018 8GB MP3 Player
Mine didn't recognize either, so what I did is go into the device manager, find the opal in the listings, double-click, disabled the device, re-enabled it, at which time it shows that there's a firmware error. I then re-installed the driver from the cd, unplugged the opal, plugged it back in, and for whatever reason, the computer then recognized the opal as a mass storage device, instead of a portable music player. The computer now sees it everytime, and all I have to do is drag and drop any files I want into the opal. Works like a charm. Hopefully RCA will provide an updated firmware program in the near future, but this might work for you for now. Good luck!
Posted on Apr 04, 2008
  • 563 Answers
SOURCE: memorex video/mp3 player
I work for Memorex tech support. Our number is 800-919-3647.
You can't sync the Memorex player to iTunes, however, you can copy music from your iTunes library for use on your Memorex. First you must convert the music you want to copy into .mp3 format since iTunes uses a different format (AAC) as its default. Follow the instructions below to change the import settings in iTunes:
1. Choose Edit> Preferences, click the General tab, then click Import Settings.
2. Choose MP3 Encoder from the Import Using pop-up menu.
Once that's done, go back to your library and highlight the songs you want to convert. Once they're highlighted, right-mouse click and you'll see an option for Create MP3 version. This will not effect iTunes ability to play the music and if you have an iPod, it will not be effected either. After the conversion is finished, I suggest draging the songs you want for your Memorex player to a folder on your desktop. These .mp3 files can be copied onto your player and will play just fine.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 04, 2009
  • 496 Answers
SOURCE: Lost CD that came with Sony MP3 Player
you dont need any special program here are some instructions for you hope this helps
**Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder, available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Posted on Oct 07, 2009
  • 24 Answers
SOURCE: My PC will not recognize my Memorex MMP8595 mp3
If you're on XP, just plug in the player and wait until it says "Ok to remove", then hold play for 5 seconds, and it will switch to USB storage mode.
Posted on Oct 11, 2009
Testimonial: "It worked, thank you so much for your help. After working on it for two weeks, that one simple step finally got the ball rolling. Thanks again."
  • 94313 Answers
SOURCE: i have a sansa clip
Posted on Oct 29, 2010
SOURCE: memorex touch mp3 player won't turn on
Mines doing this too - I reset by inserting a paperclip into the tiny reset hole on bottom right side of unit. Pain to have to do every time but it solves issue.
Posted on Jan 20, 2011
0 characters
1 Points
Cannot get the cd to install. no driver. cannot get the mp3 back on. came on once and now is gone again
If you are using Vista or Windows 7, try running the installation CD 'setup' program in Windows XP compatibility mode.
Dec 24, 2009 | Memorex MMP8590 MP3 Player
My PC will not recognize my Memorex MMP8595 mp3 player. I have windows media player and I can create a playlist but when I request the songs to sync to my MP3 it will not do it. The option is on...
Oct 07, 2009 | Memorex MMP8595 MP3 Player
Boot error
Hello all:
I just resolved this same boot error problem with my Memorex MMP8567 mp3 player. After talking to technical support, they could not resolve it, so I decided to try it myself. Here is what I did step by step:
1. Downloaded and installed the firmware for the player from memorex web site.
2. In windows xp, click on Start>All Programs>Digital Audio Player>Memorex MMP8567 Firmware Download to start the firmware program.
3. Connect the USB cable for the player to the computer's USB port.
4. Remove battery from the mp3 player and connect it to USB cable. At the same time depress and hold BOTH the 'menu' button on the left of the player and the volume control button on the right of the player for a few seconds until you see "initializing" in your firmware software program. Then click on the "format" option within this same firmware program. (Note: this will erase all your files on the player, but will also get rid of whatever is causing the boot errors!)
5. When the firmware program is ready, click on start and wait until it is finished.
6. Your MMP8567 should now work just fine!
I hope this helps out someone. Good luck!!
Minnesota, USA
Sep 20, 2008 | Memorex MMP8567 MP3 Player
Memorex mp3 player drivers
You can use Windows Media Player to put songs on it. Thats how we do it. i can give you a step by step how to .. if needed is my email
Sep 12, 2008 | Memorex MMP8567 MP3 Player
Help lost my istall c-d
Look for your software downloads here:
Jan 10, 2008 | Memorex MMP8565 MP3 Player
Cant get music to my mp3
  1. dowload this coverter tool.
  2. instal the program .
  3. open the program.
  4. select the music's that you want
  5. covert the music's that you want
  6. copy the music's to the mp3
  7. done , hear the music's
here is link to download the program :
please rated my solution...
Jan 13, 2007 | Memorex MHD8021 (2 GB) MP3 Player
Is ithe model # mmp3731a? You can get the manual at the memorex website.
Nov 12, 2006 | Memorex MMP3731 MP3 Player
Memorex MMP3731 MP3 Player Logo
80 people viewed this question
Top Memorex MP3 & Digital Media Players Experts
Starnley Johnwells
Starnley Johnwells
Are you a Memorex MP3 and Digital Media Player Expert? Answer questions, earn points and help others
