Check out http://www.remotecentral.com and look for your remote and
your TV, the code is for the TV but is geared to work with your
particular remote, so look under your brand of remote and then find the code
for your particular TV or vice versa. They should also have the instructions
on how to set the code into your remote and you may find a manual there
too.
Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red indicator stays on. Release the Code Search button. 2. Press and release the desired mode button (TV, DVD, etc.). The red indicator blinks, then stays lit. 3. Enter the 3 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes. 4. With your device on, press CHANNEL Up. If the device responds, no further programming is required. Note: If some buttons do not operate your equipment, try one of the other codes for your brand.
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
You can find the instructions here. Just follow the step by step instructions to properly select model of your Phillips remote. http://www.urc.philips.com/
It includes the codes for your remote. :} If you dont see your product on the code list try a code search. If this fails your remote might not support your device.
