Question about JVC Everio GZ-MG21 Camcorder
Everio "HDD ERROR" When trying to record
My wife was trying to use the camcorder and it wouldn't respond, it just showed what ever the camcorder was pointed at but wouldn't record or even shut down. She thought the battery was dead so she docked the Everio. When I picked it up there was a message that stayed on the screen that says the drive temp was too low?!? The room was 72 degrees? I reset the camcorder and the error "HDD ERROR" appears when ever I try to record or in anyway access the HDD. What happened and what do I do to fix it? Thanks for you time.
  • 3 more comments
  • Anonymous Dec 24, 2007
    Our camera must have fallen and someone picked it up while it was charging the pattery. Now it doesn't do a thing but says "HDD ERROR".
  • Katie Geek Aug 13, 2008
    I attempted to record, and the camera gave an error saying the temperature was too low, which is not true because it's summer.
    Then, I took the battery out and the error left.. only to find out when I try and record it says HDD ERROR.
    I wish I could fix this :(
  • Anonymous Aug 15, 2008
    Hdd error asking me to format drive every time I start this piece of ****. I have to shut down and restart for 20 minutes before it goes away. A few times i went ahead and executed the reformat. Nothing happens, the data stayed intact and after a few tries it decides to start recording properly.
    While in error the record time goes red 00 ...
    Worst piece of electronics ever
  • Anonymous May 04, 2009
    I have the same problem with the temperature, HDD error, and long start up time. I am going to call JVC, and reference that I am not the only one having this problem. Thank you. I hope there is a solution, my first and only childs photos are on it..
  • Anonymous May 21, 2009
    Same problem
How do [ clear the hard disk error from my camcorder jvc everio hybrid
in the main menu you can format the HDD, if not possible take out the HDD connect with a dock to your computer, format it.
Nov 27, 2015 | JVC Everio Gz-mg130 30gb Hdd Camcorder...
I have the Everio 30BG and have downloaded all the files onto my computer, however there is a message showing 'insufficient space' when I try to record, and yet there are not files. HELP>
Are you saving to the micro SD card or to the HDD? You need to go into your menu options to ensure that you are saving to the HDD automatically. Sometimes I used to save to the SD for pics and the HDD for video (set up in the menu). Maybe you are deleting the HDD files but automatically recording to the full SD card?! Check
Aug 05, 2010 | JVC Everio 25x/20GB Hard Disk Drive...
My JVC HDD GZ-MG365 will not record to the HD. It keeps coming up with an HDD error.
Try to format your HDD on the camera itself. Formatting is available in the menu. Formatting your HDD outside your unit is not recommended. Make sure to back up important files. Hope it Helps
Jan 17, 2010 | JVC Everio GZ-MG365 HDD Camcorder
HDD Error!
Dude, I just now had the same problem, help if you can!
infused08@gmail.com
Sep 06, 2008 | JVC Everio GZ-MG130 Camcorder
Help me
Hi .Just click on Menu-button, then with joy-stick (on left side of cam-monitor)go up tu "Rec Media for Video"...then you push joy-stik to the right...and then you see 2 lines media types -HDD and SD....again with joy-stick you push to up side (where is HDD )...and then again push joy-stick to center( to select the recording media type)...and your cam is ready to rec on HDD
Jul 09, 2008 | JVC Everio GZ-MG130 Camcorder
My JVC Everio Camcoder keeps saying HDD Error!
reformat your hard drive. That way it will correct the error or flag it as a bad sector.
Jul 08, 2008 | JVC Everio GZ-MG20 Camcorder
I have a everio camcorder
Generally an HDD error indicates that the heads are not spinning at the correct speed or at all. Look inside and make sure that there is no debris inside the compartment and try again. If you find nothing, the unit will need to be serviced.
Dan
Mar 19, 2008 | JVC Everio GZ-MG21 Camcorder
JVC Everio GZ-MG21 Camcorder Problem
Can't help u much, however, I rec'd the "HDD error" msg as well. All I did (out of panic) was turn off computer, pull out battery, put battery back in and then it was fine again for viewing off camera.
Hope at least THAT helps!
Jan 21, 2008 | JVC Everio GZ-MG21 Camcorder
JVC Everio GZ-MG21 Camcorder Logo
858 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
