Question about Samsung DLP HL-P5663W 56" TV
Samsung 46 inch DLP, Screen goes black, sound still on
My 46 inch DLP picture goes black after an hour or so. If I turn off the TV and back on the picture comes back for a few minutes and then goes black again. TV still has power, sound and the bulb is still on.
I taken off the back panel and cleaned the inside around the fan.
    Habit-Forming:
    New Friend:
  • 11 Answers
Hi there!Take it back to where you purchased it from,that's if it is still under warranty. If its not,ask them to give you the details of the technician they usually take their out of warranty items.I work from a furniture store and that's what we do.if its a local supplier,then they'll still charge you for repair since its out of warranty. Hope this helps!And don't switch it on again the problem may develop to worse.
Posted on Jan 11, 2018
  • mishael mailoshi
    mishael mailoshi Jan 12, 2018
    Novelist:
  • 100 Answers
Considering it runs for an hour then fails it must be a heat issue, the heat builds up then it starts to fail. Have you checked that the fan is actually running after cleaning it? Its usually pretty easy to hear and you should feel airflow from it, and it should be moving a good amount of air. The only other suggestion i could make is something on the main circuit board inside is getting hot/failing, could be bad capacitors, could just be dust buildup, but since you said you cleaned inside i wouldn't think its buildup anymore. It might just be something failing from age. I know i post this over and over about TV's on Fixya, but THE MOST common issue i face with any TV repairs is generally failing/leaky capacitors on the power supply. I keep a large box of various values of capacitors and its about a 99% success rate fixing them by replacing aged capacitors.
Another thing you can try, let it cool of a while, remove the back cover and leave it off and put a small fan nearby blowing in, then turn it on and see if it stays on longer, that could help rule out a cooling problem also.
SOURCE:
jerryg50
  • 1691 Answers
SOURCE: 46" Samsung DLP Lines & Freeze up
This is a possible fault in the power supply, and can be a problem with some decoupler caps on some of the boards. The vertical bars and unstability are usually attributed to having high frequency noise and or clocking pulses crosstalking on to the power distribution lines that run through the boards. This can be switching power supply noise, or cross-talk from clocking pulses.
Another thing that can cause your described fault is unstable clocking between the devices that are reading and writing to the data busses. There are a number of data busses running through the set for the boards to be able to communicate with each other.
The tech will use the process of board swapping to service the set, and then do the adjustments as necessary to make sure the new boards match up.
Yes... DLP sets are fairly expensive to service!
This is my personal opinion. If the set is out of warranty, I would change for a Plasma or LCD set. If you compare the performance of these to ther DLP, the difference is very big. From what I am seeing from a service point of view, the DLP's are lower in reliability.
Jerry G.
Posted on May 06, 2008
  • 191 Answers
SOURCE: green lines on screen
your power moudle is bad. check for swollen or burst electolytic capacitors
Posted on Nov 11, 2008
freetek
  • 5569 Answers
SOURCE: have little white dot's on screen will changing
Highly unlikely the bulb could be at fault; it sounds a lot like a defective DLP chip. If you are not aware of how this device functions, it is an array of physical mirrors which can fail individually and cause the effect you are having. The bulb failing would cause a loss of the entire screen, not just a few points.
Posted on Jul 05, 2009
SOURCE: My 56 inch Samsung DLP keeps shutting off. I have
Once before I had this same problem and FixYa gave me the solution. When you replace the lamp door, there is a switch inside so be sure the door is put in at an angle so to hold the switch up. It solved my problem after numerous repairmen missed it.
Posted on Sep 05, 2009
  • 32 Answers
SOURCE: Samsung 50" HD DLP TV video goes out
Common problem of a bad lamp call your local repair shop on price and availability of lamp.
Posted on Jan 20, 2010
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Not getting a picture from a Samsung 46" LCD TV
check if the back lamps are still on when you lose image, all you have to do is get close to the screen and make is totally black and if is not that means you have a back light working, but if the back light is gone you may have a defective panel.
talked to samsung TA about the same problem I had and the recommend to replace the power supply first to confirm a defective panel because a panel is quite expensive
Jun 14, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
TV Picture problems
My samsung did the same thing right before my color wheel went out. Can't be sure but that is what was wrong with mine. hope this helps.
Jan 25, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp replaced color wheel
Need to get in the service menu.
That is not for customer for only autherized samsung service man konws about that.
Please contact samsung service center with phone.
Aug 16, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Sumsung HLP 4663W
Might be a bad ballast, has the picture been dark?
Jun 21, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
941 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
