Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Homemaker 5kg washing machine blocked drain
By P4rker on Dec 04, 2007
Have a Homemaker brand top load washing machine. Stopped working during a wash and gave an error code that means the outlet drain line was blocked. The water that was still in the machine drained easily when the drain hose was layed on the ground but i am wondering how to check for this 'blocked drain'. Has no centre piece on the inside of the bowl, just holes in the bottom for bubbles. There is a single screw in the centre of the bowls which is very tight & did not want to unscrew to check under the base of the bowl & i didnt want to force it & break something. I opened the back and disconnected the drain line & it appeared there was nothing blocking the small final pump from a visual inspection. Any suggestion would be appreciated, thanks.
Comments:
Dec 04, 2007
- drain line goes directly into laundry sink, cannot be blocked
Dec 04, 2007
- the lid on this machine can be opened & the machine will still operate. When the machine goes into rinse mode instead of the water draining there is a quiet sound from under the unit, possible a pump that has failed?
Same Problem
May 13, 2009
-   i have a top loader homemaker  washing machine model hmxqb70-722  7kg after washing a doona the spin cycle keeps unbalancing and the alarm goes off every time the clothes take a long time to spin and don't spin out all the water -   marktasdevil
Solution #1
posted on Dec 04, 2007
Somewhat Helpful)
premm
Rank: Guru
Rating: 93%, 3324 votes
Could the block be in the wall drain.............
Comments:
Dec 04, 2007
- Check out lid switch in all ways...............
Dec 04, 2007
- Quite possibly its the pump........dismantle, check, or replace.
Was this helpful?
Yes
No
Solution #2
posted on Oct 31, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Never found out sorry, and for that particular brand i was told from the supplier & from a local repairer that they are basically "throw-away" items and that parts can not be purchased for repairs. 'Coincidentally' it was just out of warranty or it would have been replaced. Always the way... If you can source a replacement pump and change it out that would be my best advice/guess.
Solution #3
posted on Oct 30, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
wondering what happened as I have the same machine and now the same problem???
was it the pump?
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
elite oasis is that a quaitly machine
Answer
i have nec nw 452 machine n its stops working after water fill with le error
Answer
My washer will stop in mid cycle and then I have to push the start button again and it starts where... (More)
Answer
What is the gallon per minute rating for the wmmc2100uc model?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14935
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
