Question about Sony Playstation 3 (PS3) Console
No sound from HDMI to PS3
I have a PS3 connected via hdmi monster cable to my sharp 37 inch lcd hdtv 1080i and i get no sound at all, i bought an optical cable and connected it to my bose 321 system and still no sound. i used to get sound from the ps3 and my hdtv but not since i moved and swiched to direct tv which has been messing up my tv ever since it was installed, i also get no sound with the hdmi cable and the cable box, just picture...i used to at one point get sound. I really dont want to go the component route....but if its just for audio i guess . My sharp TV has an optical output,my cable box also has an optical out. any help would be great....the tv is less than 2 years old could i have lost the speakers somehow.
Thanks for any help guys!!
Merry X-Mas
  • 4 more comments
  • Anonymous Dec 25, 2007
    My son has just got a new HD ready tv for christmas so he can use his ps3 on it.We connected the ps3 to the tv using a HDMI to DVI-I cable and turned the tv onto its HD setting. When we turned the ps3 on and loaded a game there was no sound.We have tried various things but with no luck. Can anyone help me?
  • Assman123 Dec 04, 2008
    i tried connecting my ps3 to my samsung 21" lcd tv and i got picture but no sound. Do you think that me buying the cheap hdmi cord be the cause of this?
  • bigsams08 Jan 12, 2009
    I had the same problem I've had my PS3 for a year now and its worked fine. I just went on vacation and got back after two weeks to find that my sound no longer works. I tried the audio settings thing but it still didnt work what can I do?
  • Smittygolfer Jan 26, 2009
    For some reason I dont have any sound coming from my ps3. It only plays sound out of the tv and not the Denon reciever. I have HDMI monster cable connected to the Samsung 52' plasma from the ps3 and sound was fine....but now all of the sudden NO Sound!!!! Checked all the settings on my ps3, even tried a new HDMI cable. Still nothing. Any Solutions....or do I have to buy a new ps3. thx.
  • mgcoleman8 May 09, 2009
    my ps3 doesn't play any sound from my hdmi cord and now it doesn't play any sound at all
  • ranman2012
    ranman2012 Feb 14, 2013
    All i did was change the HDMI cable and the sound came back please check your cable before anything thanks for the input though
Go under system setting-->select sound settings-->select audio output settings -->hit x on hdmi-->hit x on automatic-->hit x to enter. This solved the issue for us :)
Posted on Dec 31, 2007
It needs to be on HDMI with Digital Output, installing new games can change the settings on you. Heres how to change it:
1. Reset the PS3 by turning off then holding power button until it beeps
2. Choose the HDMI settings on the screen when the PS3 detects its presence and select the optimal settings
3. In the PS3 Menu go into the Settings/Sound Settings/Audio Output menu and select Digital Output (and choose your appropriate theatre mode), confirm with X
Your menu screen should now have sound when you move around. This should fix the problem if everthing else here doesn't, it did for me.
Posted on Nov 19, 2009
This has to do with a firmware update. Remember that if you are running sound output via Digital Optical, some games will NOT support the DTS feature. Go into sound setup and make sure the DTS option (should be second from the top) is disabled. Some games support it (i.e. EA's Dead Space) however many games (Burnout: Paradise and both Resistance 1 and 2) do not. If you are having trouble hearing sound in blu-ray movies (for example, you have menu sound but not sound during the film itself) make sure you have Linear PCM changed to Bitstream accessible by pressing the green triangle button during the film, and going to sound options. This should resolve all problems. Hopefully a future firmware update will allow the system to be intelligent enough to pick what output mode is appropriate.
Posted on Feb 04, 2009
I connected the PS3 to tv with HDMI to DVI lead. This got me the picture. Then I used the AV composite cable supplied with the PS3 for the sound. Plug the single end into PS3, then just the white and red into the TV Audio sockets. Just leave the yellow unplugged. Go into settings on PS3 and change vision to the HDMI cable and sound to the AV composite cable. Sorted. If pic doesn't come up first time for any reason, turn off PS3 and turn it on again holding the on button on until it beeps.
Posted on Dec 28, 2009
If you did not change your sound setting to digital output then that would be the reason you still have no sound. Usually when using the HDMI cable it its a must to use the Digital optical cable for sound. Hope this helps. Some TV's do not have the Digital Optical cable input and an external sound system is required most current home theater systems will have this cable input.
Posted on Jan 26, 2009
I had the same problem with my Toshiba Rear Projection HDTV. I bouht a component cable for $20 and that was a quick fix.
Posted on Dec 30, 2007
Still no sound Bro... I got rid of my big box old school tv, and got a HDTV Thosiba... And my problem is that when i changed from Scart to HDMI i get no sound at all, not from the menuscreen, and not from youtube.... I've tried like 3 or 4 different "sollutions" and non of them is working... Has anyone had the same problems?
Posted on Oct 21, 2012
Go to system settings and reset segfault settings... enjoy
Posted on Aug 20, 2011
PS3 and Sony XBR4 HDMI, 100% perfect.
PS3 and Samsung LNT-4669FX (my brother house), HDMI cable, NO SOUND once the game started. I have tried 3 games.
I did not tried to solve problem.
I guess some incompatibility.
Bye,
Posted on Feb 21, 2008
  • mattmack27 Jan 08, 2011
    THIS IS HOW TO RESOLVE NO AUDIO ON PS3:
    From the PS3 main menu:
    1. Settings->Sound Settings->Audio Output Settings
    2. Change it from HDMI to Digital Out (Optical). I do NOT have optical hooked up on my PS3, so if you have it hooked up, you may want to unhook it.. probably shouldn't matter.
    3. I left what was defaulted: "Linear PCM 2 Ch. 44.1 kHz" and 48kHz
    4. Right on the D pad (X selects/unselects options) to move to the next screen.
    5. A confirmation page, hit X to Enter, saving the changes.
    6. Start up a game, you shouldn't hear any sound (as expected)
    7. Exit the game, then go back to Audio Output Settings and switch back to HDMI. I selected "Automatic" for "method for setting the output format."
    8. A confirmation page, hit X to Enter, saving the changes.
    9. Start up a game, you should now hear audio with your game (once again).
    The problem is most likely caused from having switched your PS3 to a different TV for a period of time. At least that was the reason for me
Make sure the hdmi cable is pushed all the way into the playstation, worked for me!
Posted on Apr 13, 2010
How to connect the PS3 to RX-V365 to get best sound qualitity in films. I have sony BRAVIO LCD wiht PS3 and I recently bought RX-V365 Yamaha home theater system. Please advice on connecting all three to...
You can connect PS3 video via HDMI to receiver and from receiver via HDMI to TV. But RX-V365 doesn't support HDMI audio, so you have to connect audio separately via SPDIF digital cable. I think PS3 uses optical SPDIF, so you will need optical cable. If you can't find cheaps optical cables in your shop, you can try byuing from ebay ($1-5 max.)
Feb 13, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
No sound from ps3 when connected with hdmi to sharp lc-42d64u lcd, connected to sony dav-hdx589w via digital optical cable
on your PS3 go setting>sound setting> audio output settings to adjust settings for the audio device (OPTICAL or HDMI)
Dec 05, 2009 | Sharp LC-42D64U 42 in. LCD HDTV
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I have sharp 37 inch LC-37D44U MY PS3 is not working with it it green lights keep blinking power light and OPC. BUT THE HDMi ports work beacause i checked it with other devices. so i dont know why its not...
Does this happen when you input certain signals to the HDMI2_bing.gif ports? Or all signals (e.g. 1080i, 720p, 1080p, etc.)? And which ports are affected - side HDMI, rear component, etc.?
I had this issue and Sharp sent out a local repair tech to install a new main circuit board, then two weeks later, a new side board (where the side inputs connect into the system)... their first visit allowed my TV to accept signals in the rear HDMI ports (all signals worked well), but then I couldn't get a signal processed via the side HDMI port. At first, just 1080p would not display (caused the OPC/power green light blinking), and after a few days, any signal hitting that port would cause the error lights to come on. But as I said, eventually, a new side board resolved that issue.
Sep 11, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
I want to connect my ps3 via hdmi cable to my magnavox 51mp392h/17 hdtv but theres no hdmi jack on my tv what to i do?
If there is NO HDMI on the TV, There are 2 options to still get HD. 1. Check if your TV has a DVI input, If it does you need a DVI to HDMI converter. This can be a problem with some TV models it might not sync up 100%. 2. I recommend doing this, Purchase the Component Cable For the PS3 from Best Buy or any Game store. Make sure it is the ONE for the PS3!!!!!!!!!!!!!! This cable will give you up to 1080i resolution and stereo Audio. Plug in the Red, Green and Blue into the Component (R,G,B) Input in the TV, The Red and White (audio) will follow into the same Input (White and Red) just match the colors from the cable to the TV. On the PS3 in the Menu go to the 2nd row from the Left and down to DISPLAY SETTINGS. Select Component (under HDMI) check off everything except 1080p and then SAVE by pressing X. If you have a Receiver (AMP) that your Audio goes into, Then you can buy an Optical Cable for Surround Sound. Plug in the Optical cable then on the PS3 go into the menu, 2nd row, Sound Settings, Choose Optical, Then choose Auto and SAVE! Hope this will Help!
May 04, 2009 | Philips Magnavox 51MP392H Rear Projection...
HD WONT WORK ON MY PS3!!!
Hi
Try This links and follow the instructions! CLICK HERE
Thanks!!
Nov 12, 2008 | Philips 27PT8302 27" TV
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
HDMI Monster cables
I had the same issue. I think you have to reset your PS3. I don't remember how I fixed it but I did find the anwser in the PS3 user manual "Trouble Shooting".
Dec 27, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Playstation 3 (PS3) Console Logo
48,455 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
