Comfort Glow Vent-free Gas Heater CGN18B
I have a Comfort Glow Vent-free Gas Heater model number CGN18B. The pilot light will come on when i set the dial to "pilot". However when i turn it "high" the pilot light will go off. Any ideas?
  • Anonymous Jan 11, 2009
    where in the sam hill can u buy the right one for these heaters, u only solve part of the problem,
    i have searched an searched, aside from buying a new heater, for which i 2 in my garage now that nee thermocouples
    cheeeeeeeeeeeeeeeeeeeeeeee
  • sarah ahearn
    sarah ahearn Jan 15, 2009
    The unit goes on the pilot light lights but when I turn it on it stay on weather it be on high or low it shuts down
Check with Ebay seller s.a.w.inc for available thermocouples. If that doesn't solve the problem the valve unit will likely need replaced.
Posted on Feb 13, 2009
  • 625 Answers
The pilot light is operated off a millivolt generator. that is the small tube directly in the pilot flame. its purpose is to generate a small dc current which is connected to the pilot valve inside the main valve. setting the control to pilot opens just the pilot gas supply. when operating normally the millivolt generator keeps a small electromagnet pulled in that keeps the pilot gas supply open. if it don't work the pilot gas supply valve closes. replace the thermocouple.
Posted on Dec 07, 2007
I bought a comfort glow vent-less space heater model # CJ18NL. It had a natural gas valve on it and the guy said I could put on a propane valve, which I did. It's not lighting. Is this model only good...
According to the Comfort Glow Website, this is a Natural Gas unit. If you use propane you will need
a minumum 100# LP Cylinder and a pressure regulator. I have a Comfort Glow unit and went through the same process.
If you have it hooked up to a 30lb cylinder without a regulator I would think that if you purged the gas line
of air you should be able to light the pilot.
On a new unit you can expect to push the spark ignitor button at least a dozen times while holding
down the gas valve button.
Good Luck
Feb 19, 2010 | Desa International GWP20T GLOWARM Wall...
Looking for a Comfort Glow Kerosene Heater Manual. Model #PHS/D
I am looking manual or answers for Comfort Glow Portable Heat System Model PHS/D with serial # 3D006270186
Jan 03, 2010 | Desa International Comfort Glow Infrared...
Pilot won't light
You may have to bleed some more air out of the system.
Your ODS pilot may be clogged with dust or lint and needs to be blown out with air(less than 30 psi).
Your regulator or gas valve may be faulty.
Dec 09, 2009 | Desa International Comfort Glow Infrared...
Do I leave gas value open when comfort glow vent free gas heater is not in use.
Just for tha sake of safety, close it!. You never know when something will happen. Usually right after you have questioned something and ignore it! Good luck...Lee
Nov 10, 2009 | Desa International Comfort Glow Infrared...
The pilot on my Comfort Glow Gas Logs CLD3924PTA won't stay lit. Can anyone help me with this problem??? Thanks
You must have some kind of flame sensor and it sounds as though it is not working correctly. If the pilot lights and then goes off, I would look there first. Good luck...Lee
Nov 04, 2009 | Desa International Comfort Glow Infrared...
I have a Comfort Glow propane heater connected a 20lb tank. The pilot has a hard time staying lite but when I do get it lite ang turn the hearter on low it will shut off in a minute or in some cases 20...
If you have a pilot, you have a thermocouple. I would start with the thermocouple. The thermocouple is supposed to be heated by the piolet and to keep the pilot gas on. If it is faulty, the pilot will quit and the heater will not reignite until you light it again. Good luck...Lee
Sep 21, 2009 | Desa International Comfort Glow Infrared...
Have Model CGP30TB Copmfort Glow propane heater. Pilot light won't stay lit. Flames also coming from what seem to be air vents just below flame on pilot light.
sounds like an obstruction in pilot assembly.try using canned compressed air to blow directly into pilot. this technique is successful about 70%. if not,pilot assembly must be removed and cleaned thorougly
Sep 10, 2009 | Desa International Comfort Glow Infrared...
I have a comfort glow gas heater that the pilot lights and when I start the heater it works for about 30 seconds then the whole thing shuts down.
Jan 02, 2009 | Heating & Cooling
Heating & Cooling Logo
677 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
