Question about Yamaha RX-V2700 Receiver
E01 no front speaker detected
I keep getting message E01while running auto set up and I have tried everything. It looks as if there were not connected at all... any ideas? Thanks
    Genius:
  • 1,175 Answers
Have you tried another known good speaker?
If you have,then the amp for that output is probably bad.
Posted on Feb 24, 2008
Error message : e01 f09
First try holding down the cancel button for 10 seconds and releasing (might have to do this 2~3 times). The technician manual is located under the lower front panel. I've heard that locating the CCU (brain box, in lower right) freeing it up and giving it a couple of wacks has worked. F09 is pressure switch, E01 is Thermistor. The tech manual will be a great help!!
Feb 16, 2014 | Whirlpool Duet 4.3 cu. ft. Front Load...
I have just used my LIME MT9 treadmill for the first time and it keeps stopping every few minutes with an E01 error message.
lube the deck belt and proceed according. However you must readjust the speed sensor + Reed switc. Run the software calibration for easy diagnose and fix it. see the diagram attached.
God bless you
Mar 23, 2013 | Lime Pro Lime Mt9 Treadmill Exercise...
Rear speakers on vsx1122 not playing, they tested okay
Manually change your surround settings for your satellite box input. Your box may not be putting out a signal that the receiver auto-detects as a surround sound signal, thus it just plays in stereo.
Dec 26, 2012 | Pioneer VSX-1122-K Receiver
I can't download pictures to my computer error message says cannot detect camera
It may be a USB port issue or a USB cable issue. Try an alternate cable or a different USB port. Try other USB devices on those same ports to make sure they work. Try using a USB card reader to transfer photos from the card directly instead of plugging in your camera directly.
Jul 04, 2012 | Canon Powershot Sx150 Is 14.1 Mp Digital...
Error Message Reads: Check Scanner Unit E01-31
try checking the scanner cable . look through the glass back right . you will see a usb cable.. check both ends.. if there connected properly and you still get the error.. you need to replace the whole scanner unit
Oct 14, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Receiver is shutting down.....
First, I have to compliment you on a thorough and comprehensive problem description and an apparent sense of how to troubleshoot. We're halfway there already.
Your Blu-Ray / PS 3 statement is intriguing but with the E-1 code that absolves it as the problem.
You have two opposing symptoms: the live failure says you have a short while the test mode implies an open circuit. We have to isolate everything and see if it moves to another channel.
Let's run with the "E-1: NO FRONT SP" error. I think it's trying to tell us we have an intermittent sensation of an open wire in one of the Front speaker channels. * Unfortunately, the manual doesn't break out Left and Right (but I'm sure the receiver knows) to help us isolate. You say it doesn't get past the Left test. I need you to decide by listening to the Left Front Speaker setup routine if it's really working or not, and if it seems to be working, maybe the receiver is really failing at the point it advances to the Right Speaker, assuming Right follows left in the sequence.
Verify for me: You swapped the two front speakers Left to Right and replaced both speaker wires with NEW wires and had no improvement.
I'm wary of a failcode that doesn't identify which of a pair is failing, so I 'd like to see ALL NEW speaker hardware and connections in place to avoid the pitfall of swapping the L & R with each other and having one of them be the problem without changing the symptom.
We can accomplish this easily: Try temporarily running the rear speakers as the Fronts just to see if the test can pass. If so, test the Fronts as if they're the Rears speakers. You should be able to just swing the receiver-ends of the cables among the speaker posts.
Something should change or else the problem is internal to the receiver. Good luck.
Apr 28, 2009 | Yamaha RX-V663 Receiver
Cmos
You need to press F1 and go into the BIOS to setup and detect everything. You will need to set the date, verify it detects your hard drive and memory, and enable/disable items as you need for your system.
Once it looks good, do a Save and Exit.
Jan 16, 2009 | Computers & Internet
I have an onkyo tx-sr606 with speakers set up at 5-1 channel, when trying to set up the auto speaker set up i keep getting the speaker detect error message. what can i do ?
hi there. try to check if your surround speakers are on the surround terminal. do not put them on the surround back terminal because this is only allotted for the 7.1 speakers. hope this helps.. ^_^
Aug 12, 2008 | Onkyo TX-SR606 Receiver
OVERLOAD
HOW MANY SPEAKERS ARE YOU RUNNING? IF you are running more than TWO speakers, the very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: Some Pioneer equipment have internal overload protection systems to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized HK service center must do this.] But, before you take your unit in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Jul 15, 2007 | Pioneer VSX-D511 Receiver
Yamaha RX-V2700 Receiver Logo
50 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
