Question about Zio Corporation (DM-3000) CD-RW Burner
CDs skipping/Lens cleaned/Still a problem
I've only recently noticed a problem with the sound when I play a cd or dvd on my computer.. where the cd may skip or the sound is broken (generally starts at the beginning of a track). I purchased a Phillips SAC2561 lens cleaner and followed the directions. It still hasn't made much of a difference. I use my cd/dvd rom a lot. What else can I do to fix this problem without purchasing a new piece?
  • 45 Answers
Ler\ts give a try i had similar problem with mine which was due to lens problem
rectified it nd it s running smoothly
if you love your rom so much try plugging the drive into some other system and verify if it has same problem again if yes then notify me
if no then reinstall u r OS and change the cables this will help yiou man
Posted on Dec 04, 2007
Hi ..I have Pionner PD-M701 CD Chanager .the player works so fine and recognize all cds in the trays but the issue is in the reading .
hi Sam.
you could try this.
Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lens cleaner.
Why does a CD player skip? They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.
.or try this link for more info.
cd player skips Google Search
Dec 03, 2017 | The Audio Players & Recorders
Got good sound from music Cds but no picture or sound from DVDs but short informational cds will play????
The lens of the DVD drive needs cleaning. If the problem still occur then the lens is faulty and will stop play CD also in future.
Feb 21, 2017 | Computers & Internet
I have a model nsx 3150 and the cds skip a lot
Hi,what makes the nsx 3150 skipping, is because the Lens inside the DVD section that makes a DVD plate play when inserted is weak and needs to be replaced.
When a Lens is weak,it will not allow you to watch a full movie or play a CD properly. Might stop on the way or skip
What to do is this, you will need to clean the Lens with a DVD lens cleaner.You can buy from Online stores and it comes with instructions..
But note after cleaning the DVD lens, if still does the same way,that means you will have to replace the Lens inside the DVD player section.
To replace the Lens, contact the nearest repair store or outlet around your area..
Take care..
Sep 27, 2011 | Audio Players & Recorders
Hello, I have a Technics HiFi system - I've had it for 10 years. The problem is that the CD player skips and jumps. I've tried cleaning the CDs but there are no scratches on them. I've also...
Its time to replace the optical unit ( lens ) of the CD player. Brace yourself the unit on some of those old players can cost more than a new DVD player.
Jun 02, 2011 | Audio Players & Recorders
I bought a Radio Shack cd cleaner (cd w/little brush on it) to clean the lens of the cd player however the machine won't recognize the disc when inserted so I cannot figure out how to "play" it. Many of...
yes here is a simple easy way to get them to stop skipping, stick them in the freezer portion of your fridge, only if the cds have scratches on them, even the smallest scratch can cause a perfectly working cd player to make the cd skip, stick the cd in the freezer for about 15 or 20 mins and pull it out and play it, i have used this method for a lot of my video games as well and have never had to buy any "cd player cleaner cds" i hope this helps
Jul 16, 2010 | Sony CDP-CE575 5-Disc CD Changer
What is mean by troubleshooting?give some examples.
Troubleshooting simply means, investigating a problem to find out the cause and to fix the problem. We can also say; the process of finding and fixing a problem is called troubleshooting.
Example like when your computer has sound problem, we have to find out what is the cause, suppose if it's drivers related problem, after installing or updating the sound drivers will fix the problem so here, installing and updating the sound driver is the Fix.
If you cd/dvd player isn't playing your Cds/Dvds, you have to check the media (cd and dvds), after that, you'll also clean the cd or dvds. And if your cd/dvd problem is caused by the Lens not the others like cds or motor, etc.., then replacing the lens will fix the problem and there'll be no more problem with your cd/dvd player. I'll read and play all cds/dvds after the lens is replaced.
Good luck.
Thanks for using FixYa.
Jul 03, 2010 | Computers & Internet
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
Hi, am Mr.Varghese. I have LG dvd which is 1-2 yrs old. Problems are:- 1) DVD - not playing at all 2)VCD - Playing but stucks after 3-5 mins 3) MP3/Audio CD - Afer 1 song is over it restarts from the...
Hello Mr. Varghese,
Your LG dvd player's lens might need cleaning. It is having a hard time reading those cds that is why it sometimes skips or just stops in the middle of playing them. Does this happen also to new cd's? Sometimes cleaning those cds helps the lens reading them.
If you have a disk cleaner, you can run that for 30 seconds on your player. It that does not help, then you might need to open your DVD player's casing and clean the lens manually by opening your player, get a soft cotton earbud and damp in an alcohol and gently wipe your dvd's lens. Then try to return back everything and test playing cd.
Sep 25, 2009 | Televison & Video
My DVD player has had continual playback problems for many months. It skips and pauses often while playing back DVDs and CDs. These same CDs and DVDs play flawlessly in other (much less expensive) players...
Might need a tune from bose repair man, Burnt dvds sometimes has problem but wipe normally fixes it. But cds i have't had problem burnt or orginal, scraches dont usally worry to much, Thats why thinking repair man.
Hope this helps:)
Cd normally hot from unit if its in for a while.
Aug 16, 2009 | Bose Lifestyle 38 System
If you go out and buy a cleaning disc it may help. You should really clean a car cd player at least ounce or twice every 6 months to get the best sound and play out of the unit. You can pick these disc up at any walmart , kmart , or computer store. Hopefully this can help you out
Dec 18, 2007 | Kenwood KDC-MP228 CD Player
Zio Corporation (DM-3000) CD-RW Burner Logo
65 people viewed this question
Top Zio Computers & Internet Experts
David Payne
David Payne
Are you a Zio Computer and Internet Expert? Answer questions, earn points and help others
