Question about Panasonic CT-2784VY 27" TV
RESETTING LOCK CODE ON OLD CT-27D11DE PANASONIC TV
I HAVE FORGOTTEN THE LAST CODE AND I DON'T REMEMBER THE
PROCEDURE TO RESET THE CODE
    President:
  • 4,402 Answers
Reset is usually 0000
Posted on Dec 04, 2007
Child lock code been forgotten
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Oct 06, 2015 | Panasonic VIERA TX-L24X5B 24" LED TV...
How to reset the hour meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic PT-52LCX16
How to reset the lamp meter on a panasonic pt-52lcx16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
A have a lock code than i have forgotten. My phone is unlocked and I want to lock it again but I don't remember de code. Could you help me reset de phone. Best regards
if you have a hint on your old phone code,simply turn off your phone and remove battery for about an hour... put it back and turn on again then enter your hint code before....good luck
May 29, 2011 | Nokia 2630 Cell Phone (Unlocked) - Black
A code was entered on my panasonic tv. i want to get the channel lock off can't remember the code.
Hello
There is one way to unlock your Panasonic TV. There is a procedure. Follow it and see whether your set can be unlocked or not. In most Pansonic sets this will work.
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
You must have its original remote control to do this effective.
OK
Mar 23, 2011 | Televison & Video
How do you reset the parental password
I have a Panasonic CT-27D12D with the exact same symptoms with the exception that my LOCK SET was OFF. I call the Panasonic technical servicxe and they had me to press simultaneously the "POWER" and "ACTION" buttons on the TV for about 5 seconds. A Self Check screen appear with OK's beside a list of functons checked. Next I was told to turn OFF the TV for about 5 seconds then turn it back ON and see if I could enter my Lock code. It worked. The procedure apparently reset everything.
Jun 23, 2008 | RCA 27F530T 27" TV
Vchip was accidentaly set by guest and password was forgotten
For Panasonic:
Parental Lock Feature
Combo's, Screen will say VCR Lock Activated.
During stop or power off, hold the stop/eject button on the unit for at least seven seconds.
Combo's, Another method
With unit on and no cassette inside, hold the rec/time button on the front of unit for 7 seconds.
CTV's Lock Mode
Only the on/off button will work,the others have no effect. Press the action and power buttons at the same time on the front of the set for 10 seconds or so.
LCD TV's, Lock Mode
If customer forgot Parental Lock Code, unit must be re-initialized.
Press and hold the Volume down button on the front panel, press the OK button on the remote for 5 seconds.
DVD's Lock Mode
Setting Method
The sales demonstration lock function is set by simultaneously pressing the "POWER" button of DVD Player on the remote control unit and the "STOP" button on the main unit. ("LOCKED" is displayed when the lock function is engaged.)
Release Method
The function can be released using the same procedure as for setting. If the remote control unit is not at hand, the function can be released by using the same method as for player initialization (pressing the "PAUSE," "SKIP/SEARCH<<"and "OPEN/CLOSE" buttons simultaneously).
VHS-DVD Recorder (DMR-ES40V), Forgotten Ratings Password
From the Owners manual: Open tray, Keep Pressing Rec and Play/X 1.3 buttons on the remote for 5 or more seconds.
Another servicer found resetting to defaults worked well.
(VCR>DVD Dub) + (Open/Close) + (DVD Rec)
Bill
Apr 01, 2008 | Panasonic CT-27E13 27" TV
Panasonic CT-2784VY 27" TV Logo
258 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
