Question about Audiovox VM9512 Car DVD Player
Help me installing my unit so i can view movies cannot seem to get those 2 wires connected to the right thing.
Which 2 wires?
Posted on Dec 31, 2007
Rear view camera instalation
Mount the camera on the back and the monitor in the front. Run the necessary wires and connect it to the power supply.
Feb 24, 2013 | Rear View Safety Rear View Night Vision...
Is there a ground wire in the stereo wiring harness in a 2001 plymouth neon? if so what does it look like?
Usually the wire is green or black. Best to use a multimeter to check these right and not make a mistake as if you are not tech savvy a meter will steer you to do hook things up right.
Sep 01, 2012 | 2001 Plymouth Neon
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
I have my panasonic surround sound system installed, and all the wires are done right, but im not getting sound from the center speeker or the two rear ones.
Make sure you are in a "surround" mode. It might just be in a stereo mode now which is LF,RF, and sub. Since there is no model number, I'm going to guess, but most Panys have 2 buttons towrd the bottom. One labeled movies and the other music (or something similar). Press the movie button. Look for Dolby PLII, Dolby PLx, or something similar. If the video out of the unit is connected to the TV you can check the speaker levels. Some models will do a test tone to make sure all the speakers are connected and you have them in the right location. Some models even allow to chose between 3.1, 5.1, and 7.1. If this is a new unit it will default to the highest setting.
Please rate if this was helpful.
Apr 07, 2011 | Panasonic Televison & Video
My new radio plays every thing but when i put a dvd it says warning please stop watch vedio player . you can hear the movie but there is no picture
the parking brake wire must be connected to the parking brake system of you car. When the parking brake is engages, the LCD will be allowed to view your video. If not, the screen will produce an image saying, parking brake. this is a feature designed for the driver not to watch a video while driving. The video output on this unit will not be affected by this, el wire to connect is Pink - parking brake. this is wire connect with ground.
Oct 18, 2010 | BOSS AUDIO SYSTEMS BV9970 Car Video Player
E-Brake Problem
you have connected it correctly, that is just how those units work. there is a pattern to the ebrake for it to view video.
1. start with the ebrake off and follow this pattern.
2. on for 2 secs, off for 2 secs, then back on
or you can just put a toggle switch instead of connecting it to the cars ebrake wire. wire as follows
1. use a 2 wire switch.
2. connect one wire of the switch to ground
3. connect the other one to the ebrake wire of your dual unit.
4. then you would do the same pattern with the switch as you would have with your ebrake. this will allow you to view while in motion without your ebrake engage
hope this helps
Aug 26, 2009 | Dual XDVD8181 Car Video Player
My phase linear uv7i can't plays dvd's or cd's and the screen is totally blue
caution it´s unlawful to operate a vehicle while video is dispayed in thr drivers viewing area
engage emergency brake sequence to enjoy video???? help help please
Jan 26, 2008 | Phase Linear UDV9010 Car DVD Player
DUAL XDVD700 BYPASS
The way you bypass the E Brake is you have to ground the wire to the radio sleev itself. There are two different peices. The radio itself and the sleeve that holds the radio in place. Take the yellow wire (the ebrake wire, not the yellow ignition wire) and open the metal connector up just slightly. Attach that wire to the top of the sleeve on 1 of the teeth located near the front of the unit. You have to make sure that the connection is good or it will not ground. Next slide the clear plastic over the wire so the only connection is with the tooth.
Then Insert a cd or dvd in the player. Press play on the remote and then push stop 2 X times on the remote. After you have done that press 26604 on the remaote and then press enter. This will permanently unlock the parking brake feature and allow you to watch dvds while in motion. If you need any further help you can eamial me.
Nov 19, 2007 | Jensen VM9510 Car DVD Player
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Audiovox VM9512 Car DVD Player Logo
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
