PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
I recently had my Gateway ML6721 freeze up ...
By rgirling on Aug 24, 2009
I recently had my Gateway ML6721 freeze up and was asking to insert OEM supplied disk for repair. Repair didn't work was looking for missing drivers. Attempted several times to do a repair with no success and finally decided to do a destructive install and formatted the disks. Now it will install up to the option of which partition I want to install the OS to yet there are no detected partitions,''mass storage device not found''. How do I reinstall the drives if I don't have a OS?
Comments:
Aug 24, 2009
- Windows Vista Home Ultimate Hard Drives 160 GB 5400 RPM Serial ATA Hard Drive Assembly (CRU/EURP) [Part #2528238R] Support Docs Keyboards US Keyboard (CRU/EURP) [Part #8016701R] Support Docs LCD Display Panel 15.4-inch WXGA Ultrabright TFT Active Matrix Assembly (FRU) [Part #2528246R] Support Docs Memory 512 MB 667 MHZ DDR2 SODIMM Memory Module (CRU/EURP) [Part #2528157R] Support Docs Modems 56K V.92 Fax/Modem (FRU) [Part #8016419R] Support Docs Motherboard 960GL Chipset Motherboard w/UMA Graphics (FRU) [Part #4006215R] Support Docs Network Integrated Realtek 802.11b/g Wireless Networking (CRU/EURP) [Part #6008038R] Support Docs Optical Drives 8X Multiformat Dual Layer DVDRW w/DVD-RAM Assembly With Labelflash (CRU/EURP) [Part #2528249R] Support Docs Processor Intel Dual Core T2310 Processor(1.46 GHz | 533 MHz FSB | 1 MB L2)(FRU) [Part #4506447R] Support Docs Systems Gateway ML6721 Notebook [Part #1014764R]
Aug 25, 2009
- It is a SATA disk and haven't seen the message for F8 or special drivers. Gateway only supplies the OS on the recovery disk and none of the drivers, they have to be downloaded from their site. Tried installing UBUNTU to the hard drive but failed.
Aug 25, 2009
- My appologies it is ATA
Clarification Request
Posted by rachitrai16 on Aug 24, 2009
Kindly clarify which OS you are using, give me the config of your system.
Solution #1
posted on Sep 26, 2009
Not Rated)
jaye_ellen
Rank: Wiz  Computer Hardware  Expert
Rating: 80%, 140 votes
Is the new drive an IDE drive? If the drive has no partitions then I'm guessing you'd have to run FDISK on it, then FORMAT /S to put an OS on the disk. Once this is done you can use the disk. It sounds like the Master Boot Record was somehow damaged. After you have recovered the MBR it might be possible to use your repair disk.
Was this helpful?
Yes
No
Solution #2
posted on Sep 18, 2009
Not Rated)
BuzzKent
Rank: Wiz
Rating: 84%, 23 votes
You don't ! Get the model of your hard drive and go to the manafacturers Web Site. There you will probably find a sofware utility that will format and partition the disc for you. No other Computer ? Use a Friends !
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
how do i restore my aspire 5735-6694
Answer
my dell inspiron will not charge it is not the battrey or the charger
Answer
I just bought a Microsoft Wireless Desk1op 1000 wireless keyboard for my Compaq laptop. All works... (More)
Describe your PC Laptops problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
