Question about Lexmark E232 Laser Printer
Black Test Print Pages
I have recently replaced a Lex E232 drum. After replacing it I have black test pages coming out. What could I have done wrong to cause this error
  • 56 Answers
Hi, Did you use a brand new drum as the replacement (OEM)?
Posted on Dec 04, 2007
What is wrong with my HP Deskjet D2330, and why is it printing only blank pages?
well it has got to be the ink cartridge. wipe of the bottom of it and make sure black ink shows up
Dec 10, 2014 | HP Deskjet D2360 InkJet Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
New black ink but very poor quality print?
Is this an original DEll toner, or a remanufactured one?
Sometimes a remanufactured cartridge can need a few pages printed before the new toner 'works ' through the internal mechanisms. Not all remaufacturers actually test (all) of their cartridges. The better ones test 100%, to ensure a quality product.
It could be that the wrong toner has been used in the cartridge (not all toner is the same - by a long way).
It could be that the drum has NOT been replaced. These can be light damaged and result in a poor print quality. An original drum is purple in colour. Aftermarket drums are blue/green.
Nov 02, 2009 | Dell 3110cn Laser Printer
Prints only pink and black
seems ur color catridge is empty with some colors, go for refill or replace
Jul 13, 2009 | HP DeskJet 990cxi InkJet Printer
We just changed the toner in our fax, and now it's printing solid black pages out. Help!
Unplug the cable that connects the computer and printer together.
Plug the printer power cord into a wall outlet.
Print a self-test to determine if the problem is related to the printer, rather than the software.
If the problem occurs on the self-test page, replace the toner cartridge. A faulty or damaged cartridge may cause black pages.
Remove all accessories (cartridges, memory, I/O boards, etc.) and try to print a self-test again. Faulty accessories may cause black pages to be produced.
If the problem persists, the printer may need to be serviced.
Thanks
Fame !
Jun 10, 2009 | Brother IntelliFax-2820 Laser Fax
Printing black pages
Replace Image drum.
Your fuser is damadged.
Best Regards !
Jun 08, 2009 | HP LaserJet 1300 Printer
Copystar cd-2550 copier , drum replacment print problems
hi
the drum unit on this model has two plugs which need to be plugged in and one on the dev unit that can come loose.
also the metal mechanism under the dev unit has to be pushed in to enable toner to get onto the drum.
is the transfer roller fitted correctly?
Mar 26, 2009 | Kyocera Copystar CS-1820 Black and White...
Lex z25 not printing
Mine wasn't printing at all, but now its printing color. I still don't know why it won't print black, but what I did was go into the control panel, I clicked on printers and faxes found the Z25 and right clicked it. I then clicked on properties, I clicked on the advanced tab, went down to the bottom of that section and clicked printing defaults, that opened the window for the properties for the printer. Once there I clicked on options in the top right corner and clicked on Lexmark Z25-Z35 Solution Center. On the maintenance tab I clicked "Clean to fix horizontal streaks", it takes to you a pop-up that says "Clean and Test Nozzles" a page will start printing to show if you have broken lines or unbroken lines when you print, either way it should clear your nozzles enough for the ink to start coming out again. If you need to repeat it the "Clean and Test Nozzles" pop-up had a box that says "clean again. Once you are done with that you can close the pop-up. If that doesn't solve the problem there are other things to try on the maintenance page besides the "Clean to fix horizontal streaks". Hope it starts working for y'all too. I still have to figure out the black part.
May 06, 2008 | Lexmark JetPrinter Z25 InkJet Color...
Lex-Z25 Blank Pages
need to install my Lexmark Z25 to my laptop.recently upgraded to windows XP
Jan 05, 2008 | Lexmark JetPrinter Z25 InkJet Color...
Lexmark E232 Laser Printer Logo
213 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
