Question about HP PhotoSmart 1115 InkJet Printer
Color cartridge not properly installed
I get the message "color cartridge not properly installed" even though the cartridge is new and correctly positioned. Any ideas?
  • paulff Jun 09, 2008
    I also have the same problem. Using an HP 78 Color cartridge, the printer worked fine. I removed the cartridge when prints showed signs that the cartridge was low on ink.
    I replaced the same catridge back into the printer (before and after having the cartidge refilled - which I have done many times before) and got this same error message about the catridge not installed properly.
    I've tested the black ink catridge - removing and replacing without problem.
Sometimes the contact pins on the rear part of the cartridge carrier don't make good contact. I used a VERY fine silicon carbide sandpaper (1,500 grit) and GENTLY rubbed it over the little contact pins and also the large vertical contact bar. Blow out any residual dust if necessary, then reinstall cartridge. I find this helps much of the time. Good contact between the pins and the copper contact-strip on the cartridge are vital. From JERRY.
Posted on Jul 24, 2008
    President:
  • 4,402 Answers
Are you sure you have the exact same print cart and not some rebuilt? also make sure it's firmly inplace,
Posted on Dec 04, 2007
How do I make a test page for my printer to check color.
You need to clarify :
1. Your printer cannot print color even though it prints color well from a test page;
2. Your printer cannot print color in a test print page.
If it is the first one, then you have to set it properly in Window Print Configuration page of that printer;
If it is the second one, then you have to check whether you have installed the color ink cartridge properly in the printer. If the color ink cartridge is installed properly, try to replace another new color ink cartridge. Finally it is still not work, then you have to bring back to the repair center.
Jan 19, 2013 | Dell V715w All-in-One Wireless InkJet...
I don't want/or need the color cartridge. Is there any way I can use my printer without the cartridge. Now all I got is the error message "insert color cartridge" and cannot use the printer even though I...
You can't use your printer without color cartridge.The printer need both cartridges to initialized.Only with both cartridges inside in printer you'll printing scanning or copying.
Nov 04, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
How to take out the cartridge
Manually slide cartridge to middle of access door, then lift front part of cartridge up and then lift up straight to remove rest of cartridge
Aug 24, 2009 | Office Equipment & Supplies
Error message says check color cartrigdge even
You did take the protective film off the new cartridge, correct?, could also be the contacts that recognize the cartridge ae dirty, also, try unplugging the power cord on the printer and plug back in to reset
Aug 22, 2009 | Office Equipment & Supplies
Trying to insert new black printer cartridge
your printer will not operate with the 'color' cartridge missing you will have to install a color cartridge.
May 19, 2009 | HP OfficeJet J4580 All-In-One Laser...
Dell A960 cartridge problem
Does the black cartridge print? If not did you take the tape off of it? Error 50 is a generalized error reading relating to a number of cartridge problems. If the color cartridge is empty, it may be theproblem although I have not found this to be true on Dell printers. If you remove the color cartridge and reinstall it the reading will indicate its full (even though it isn't. This may solve the problem.
Sep 19, 2008 | Dell A960 All-In-One InkJet Printer
Use of black ink
My husband answered this for me- it takes different colors to make black, therefore it uses some of the color ink
Jan 16, 2007 | Canon Pixma iP6600D InkJet Photo Printer
HP PhotoSmart 1115 InkJet Printer Logo
117 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
