Question about Telex SpinWise 7-824D (301689000) DVD±RW Burner
Can not find taret chip
I have a 7 bay (i-master & 6-slave). Lately, I can only get the top two slave driv to work. I am getting the can not find targe chip error message. Can you point me in the right direction to resolve this issue?
I have swapped out the last drive and put it in the third slave drive bay but still get the same message
Thanks
    Genius:
  • 1,665 Answers
Wd1600aajs slave settings
Hard Drive a Slave Drive Setting a hard drive to function as the secondary ("slave") drive allows you to use the drive solely as a storage unit. You can use the drive to back up valuable data on the primary drive without having to install or use an operating system on it. And all you need to get going is a screwdriver to pop the case open.
Power down your computer. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Disconnect all of the cables and then put the computer on a stable work surface such as a desk or a chair. Use a screwdriver to remove the screws securing the side paneling of the case. The screws are located at the back of the computer and along the edges--only remove the screws securing the case. Unhinge any case latches on the computer. Slide the side paneling of the case off the computer. Some case designs require you to remove the whole case, and some are broken down into removable panels. Remove enough of the case to have both sides of the computer exposed. Discharge any static that may have accumulated on your clothing before handling any internal components. Rub your hands against a solid metal portion of the case to discharge the static. Locate the hard drive. It should be secured in a station of bays adjacent to the motherboard--it'll also be near your DVD/CD-ROM and floppy disk drives. Remove the screws that secure the hard drive to the bay. Slowly slide the drive out of the bay. The drive will be connected to a data and power cable. You can temporarily disconnect them to take the drive out completely and give yourself more room to work with--but remember to reconnect them. Locate the jumper pins on the hard drive. There will be a diagram displaying the proper jumper settings for a given hard drive mode. Follow the diagram and set the pin cap in its slave position on the hard drive--for example, some drives may require the cap to be placed on the last two pins to set the drive as a slave.
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart you will have to have master with slave set up you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave single or master ::::: master with slave ::':: slave :::': black line between dots is plastic jumper note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s clip_image001.jpg Set Up a Slave Drive b> In a computer system, a master/slave relationship establishes the primary and secondary hard disk or optical drive status. Many computer owners install operating systems on the primary or master hard disk and use the secondary or slave disk as a storage drive for games or multimedia. Master/slave or primary/secondary relationships exist only with IDE or ATA drives. SATA, a newer drive technology, is a jumperless system and does not allow for master/slave settings, which makes SATA drives easier to install.
Shut down your computer. Unplug all cables and peripheral devices. Remove the left side panel while facing the front of the case. Remove screws, manipulate latches or perform other necessary steps to remove the panel. (Please see your computer or case manufacturer's documentation if you are unsure of how to remove the side panel, as this process varies.) Turn the case so that you are facing the open, previously left side of the case. Locate your drive bays. The 5.25-inch optical bays are at the top right and the 3.5-inch hard disk bays are towards the bottom right. You should be able to locate the necessary bay easily by matching your slave drive with the master drive. Clip the anti-static wrist bracelet to a metal object, and attach the bracelet to your wrist. Remove the drive from its anti-static packaging. Locate the pins on the back of the hard disk or optical drive. Jumper configurations vary according to model and manufacturer, and most manufacturers show the configurations on the drive itself. Configure the jumper according to the hard disk manufacturer's instructions. Insert the hard disk or optical drive into the appropriate bay. Secure it by screwing in at least two mounting screws. Attach an available controller cable to your drive. Most controller cables feature a Y-split cable, which makes it easy to find and attach the secondary cable that links to your primary drive. Insert the power supply cable into the port on the drive. Again, you may be able to plug in a secondary cable split from the power supply's cable to the master drive. Double-check all connections. Remove the anti-static wrist bracelet, then reattach all cables and peripheral devices. b> Configure the BIOS b> Start the computer. Enter your BIOS by immediately pressing the BIOS setup key, as shown onscreen. (Most computers feature a "Press X to enter BIOS setup" message after you hear the computer beep. Press this key. If you do not see this message, please consult your computer's documentation, as the BIOS key varies according to your motherboard.) Navigate to system setup and allow the BIOS to auto-detect the new drive. Save and exit the BIOS. Reattach the side panel if the drive is working correctly. Hope this helps.
Jan 03, 2013 | Western Digital Caviar SE WD1600JS...
Getting air out of a Nissan navara d22 slave cylinder
1] Make sure that the piston of the clutch master cylinder is not stuck on the compressed position. If it is stuck in this position, nothing you do will work. That means you need to work on this problem first.
2] Assuming that your clutch master cylinder is fine, you will need a helper to bleed the clutch slave. Top off the clutch master reservoir with brake fluid. [This is usually the same fluid used on the brake reservoir.]
3] Locate the bleeder valve on the clutch slave cylinder. This is located on top of the transmission. [Sorry you have to go under the vehicle to do this.]
4] Find a box wrench [usually bleeder valves use a 6, 8 or 10 mm wrench] that will turn the bleeder valve. Leave it on the nut.
5] Connect a tubing [preferably clear tubing] that is small enough to fit snugly over the top part of the valve. Aim the other end of the tubing into a can the size of a soda.
6] Make sure the slave valve is closed. Ask your helper to depress and release the clutch 3 - 4 times. On the fourth time, ask your helper to keep the clutch depressed, [and push it down all the way to the floor if it goes that far] and not to release it,until you say so.
7] Open the valve with the box wrench [1/4 to 1/2 turn] just enough to allow the air/brake fluid to come out.
8] Close the valve.
9] Ask your helper to release the clutch. Repeat steps 6 to 9, until the clutch feels firm. You may have to repeat this process 3 to 4 times to get rid of all that air.
10] Turn the valve off just tight enough so it does not leak.
Nov 28, 2012 | Cars & Trucks
How to connect it as a slave. there is no guide to follow on hd label
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
???????????????? slave? :::':
May 20, 2011 | Seagate Cheetah 15K5 Ultra320 SCSI 146GB...
Cant bleed clutch changed both cylinders still no clutch
does the slave cylinder have a bleeder? it should. auto parts stores sell hand-operated vacuum pumps for bleeding brakes. i have used mine to pull fluid through clutch hydraulics to get enough pressure to commence the regular bleeding process. hope this helps.
Nov 10, 2010 | 1988 Chevrolet K2500
I need the book too know how too instal the jumperwho put the driver slave or master
hi
  • Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
  • Step 2 To change the designation of a new drive to be a slave drive, skip to step 4.
  • Step 3 To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
  • Step 4 Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
  • Step 5 Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
  • Step 6 Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
  • Step 7 Install (or reinstall) the hard drive in the computer. (See "How to Install a Second Hard Drive.")
  • vote me if you solve your problem
    Jun 13, 2010 | Ximeta Hard Drive
    How do you replace the slave cylinder
    Step 1
    Raise the vehicle and support with jack stand placed underneath the frame.
  • Step 2 Remove the cover from the reservoir on top of the clutch master cylinder. It will be located in the engine bay on the driver side of the firewall, near the brake master cylinder. Fill the reservoir with DOT 3 brake fluid. Do not allow the reservoir to run dry at any time during the bleeding process.
  • Step 3 Locate the clutch slave cylinder. It will be bolted to the clutch housing. Locate the small bleeder screw near where the hydraulic hose connects to the slave cylinder.
  • Step 4 Connect a length of clear plastic tube to the bleeder screw.
  • Step 5 Open the slave cylinder bleeder screw, by turning it counterclockwise. Have an assistant pump the clutch pedal until clean brake fluid seeps out of the bleeder screw. Then close the bleeder screw. Make sure the clutch master cylinder does not run dry.
  • Step 6 Have the assistant pump the clutch pedal a few times and hold it against the floor. While the pedal is held against the floor, open the bleeder screw and allow the some fluid to seep out. Close the bleeder screw before releasing the clutch pedal.
  • Step 7 Repeat the process listed in the step above and watch the fluid seeping out of the slave cylinder. The clutch is fully bled when there are no more air bubbles in the fluid seeping out of the slave cylinder. You will be able to see the bubbles in the clear plastic tubing. Do not allow the clutch master cylinder to run dry at any point.
  • Step 8 Lower the vehicle.
  • dont forgate to rate
  • Mar 02, 2010 | 1999 Isuzu Rodeo
    1984 mazda rx 7 the clutch dosnt want to com up
    spring on the pedal could be bad or the slave cylinder in the trans. could be bad
    Nov 09, 2008 | 1984 Mazda RX-7
    Hard Drive Installation
    Hi emceedrive, I gather you are using ATA/PATA IDE hard disk drives? Each hard disk drive has a large white sticker on it. Listed there are pin settings to set the IDE to Master or slave & Master with a slave. (We want to leave you're drive with windows on it alone). Not changing its jumper or not adding a jumper for now. We are not hooking up you're second drive just yet either.
    Oh, please you're not an idiot either.
    Unplug the power cable from the PC & open you're case.
    Please open you're ASUS P4P800 SE manual to section 2.2.3 Motherboard layout. We want to connect the data cable to SEC_IDE1 first because once PRI_IDE1 is connected you will not be able to connect SEC_IDE1's data cable up to the DVD drive bay.
    So grab a data cable for you DVD drive. It may have three connectors on it. Plug the connector that is the furthest from the other 2 connectors on the cable into the motherboard slot named SEC_IDE2. The data cable only goes in one way. Run the remainder of the cable up to the DVD player but do not connect it to the player yet. It is ok to fold the data cable which will help in routing it upwards to the DVD bay. Than connect the data cable to you're primary master IDE drive. (The one with windows already installed on it). The data cable should look just like the DVD data cable. Again you want to connect the furthest connector on the data cable into the MB slot named PRI_IDE1.
    For now it’s best not to install the drive into the drive bay. Stand it up next to your case or lay it down flat with a sheet of paper under it. Connect the power cable to the drive. Plug in the PC's power cord & power up the PC & start pressing the delete key every two seconds until the bios main menu loads. You should see the Primary Hard disk drive listed at the main menu. Now go to the title Boot in the bios. Open boot order. The boot order of the devices should be as follows.
    Boot device 1. (Floppy Disk Drive)
    Boot device 2. (DVD Disk Drive) [None shown it’s not connected to the system].
    Boot device 3. (Model number of your Primary IDE Master HDD).
    Once this is set, save the bios & exit. The system should auto restart & windows should load. Let windows finish loading. Than shut down windows normally.
    Unplug the PC's power cord. Since you had to remove a DVD drive you'll need to set the remaining DVD player's jumper on the drive to a Master & connect the data cable & power cord to it. (You may have to remove the DVD to see where the Master pins are located. It will be marked on the DVD player near the pins).
    Now take you're new drive, do not insert it into the drive bay. Look at you're Master drive's white label. Set the jumper on the master drive first. It should be set as a Master drive with a slave.
    Connect a jumper for this.
    Go to you're new drive. Again look at its white label. Set this drive's jumper as a Slave drive. The Master drive should be connected to the end of the data cable. The new slave drive should be connected to the next in line connector.
    Once all data cables & power cables are connected plug in the PC's power cord & boot the system, again pressing the delete key every two seconds until the boot main menu loads. Now you should see the Primary IDE Master drive & you're new Primary IDE Slave drive listed. You should also see the DVD as the Secondary IDE Master. Go to the title "Boot" again. Set the boot order as mentioned above. Save & exit the bios. Windows should load as it did before. Once windows has finished loading open windows Explorer & see if you're new slave drive is listed.
    Shut down the system & unplug the power cord. Unplug the slave drive & mount it into its drive bay. Take a black marker & mark the side of the drive as slave. Disconnect the Master drive & connect it into its drive bay. Reconnect the data cables & power cables. Check all connectors before closing the case up. Re-connect the PC's power cord & boot the system. Everything should be fine. If you have a problem getting the data cable connected to the slave drive because its closer to the DVD drive as opposed to the Primary IDE Master drive you can make the slave drive a Secondary IDE Master (Change its jumper setting according to the drive’s label for Master with a slave) & connect the DVD player as a Secondary IDE Slave. (Change its jumper to slave). Change the Primary IDE Master drive’s jumper as a Master with no slave, single drive. That all.
    Good luck emceedrive!
    Take your time. Any troubles please post here.
    You should be fine though.
    Mike
    Aug 11, 2008 | ASUS P4P800 SE (890552603657) Motherboard
    CD/DVD won't read
    try this Step 1: Start Registry Editor loadTOCNode(3, 'resolution'); Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the Upper/lower Filters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
    Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value? The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
    do same thing to erase the lower filter then restart your computer
    Jul 12, 2008 | Computers & Internet
    1999 Dodge Ram
    Your pressure plate is going out.
    Please Rate this !
    Jul 07, 2008 | 1999 Dodge Ram
    Telex SpinWise 7-824D (301689000) DVD±RW Burner Logo
    83 people viewed this question
    Top Telex Computers & Internet Experts
    Longtime User
    ray gallant
    Tom Chichester
    Are you a Telex Computer and Internet Expert? Answer questions, earn points and help others
