Question about Kenmore 13789 / 13782 Dishwasher
Kenmore Elite Model 13782 Dishwasher
The door will not close, it keeps jumping open even when empty (there is nothing pushing it from the inside. I have had it for about 8 months.
  • 6 more comments
  • Anonymous Jun 24, 2008
    Had my machine 2 days when I encountered the same problem.
  • Anonymous Jul 15, 2008
    Same thing. Less than one week. Door pops while running.
  • GDiazIII Jul 17, 2008
    The door will not close, it keeps popping open. The clean light is blinking.
  • Anonymous Sep 09, 2008
    I have the same probelm what did you guys do?
  • chase66 Nov 05, 2008
    I just bought and replaced one and I am still having the same problem. The will not latch at all.These are 2 brand new dishwashers. Does anyone know how to fix the problem?
  • Anonymous Feb 25, 2009
    Mine too, the door just pops open. When it isn't running its no big deal because the door stays upright, but when its running it will sometimes just pop open before it's done. I've fiddled with it so that it doesn't do it EVERY time but it still does it. If I bend the metal hook down a bit and then angle the tip of it back up a bit I can get it to USUALLY make it through the whole cycle without opening but not always, and its a pain.
  • AZ Consumer Apr 23, 2009
    Same problem with the latch. I have been dealing with this for almost a year and will be calling them for warranty service about this. It pretty much negates the 4 hr delay feature AND the energy savings considering all the redo loads I have had to run. When the first one was brought to my house, the installer wouldn't even install it because the latch wouldn't close it...right out of the box. This is definately a design defect!!!!
    The model number is 665.13789.K603
    Problem Solver:
  • 6 Answers
I had warranty service come and replace the latch-door part # 8193830 which can be ordered from (~$38.00). The part was sent to my house prior to the service call. It is a simple replacement...just need to unscrew all the screws around the inside door to get to the latch. It seems to have solved the problem but it isn't clear what was wrong with the original one. The spring wasn't broken and nothing appears worn. We'll see....
Posted on May 06, 2009
I had the same problem and had a tech come fix it. There were two linked to it. The spring holding the latch was off and my circuit board was burned. Had both replaced and it worked fine afterwards. Good Luck
Posted on May 05, 2009
Hi Lulie,
I had a dishwasher that did that a I had to have the little hook replaced -- Its plastic so it probally brook like mine. I am so sorry to bother you but could you please look inside the door of your dishwash and get me the model number please. Its to long of a story to tell you why - but I would appreciate it so-o-o-o much. Thank you Jeanette
Posted on Dec 25, 2008
Kenmore Elite Model 665 dishwasher won't start. The lights on the panel come on but nothing happens.
If you hit any 3 buttons in sequence your unit will go into diagnostics and tell you what the error code is
May 10, 2014 | Dishwashers
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
Kenmore dishwasher will not start
The most probable cause is the door latch (or switches in the latch) are not working right, and the controller thinks the door is open, even though it is closed.
Aug 13, 2012 | Kenmore Dishwashers
My kenmore is not pressure sealing
the problem is that the compressor is not working
call a technician for a proper diagnosis
and it is not a pressure sound but a vacuum sound as the door when closed drops the temp inside the unit and that creates a vacuum making the door temporarily hard to open
May 15, 2017 | Kenmore Elite Side By Side Refrigerator -...
I have a Kenmore Elite refrigerator model number 59673503201 and there is a terrible fish smell coming from the bottom portion of the appliance where the freezer is. It is not coming from trash, or food...
Please note when you keep fish in freezer once, the smell will be longer even you remove it. O.K. Now solution for your problem- Please unplug power.Keep fridge door open. Take wet cloth dipped in soap water and clean all compartment including freezer . Keep freezer door also opened.Then clean with dry cloth. Spray room spray in your room not into the fridge. And allow 5 hrs to circulate fresh air to pass thr' your fridge and then close fridge and freezer doors. Plug fridge and run for one hour on empty. After one hour store items in fridge and/or freezer.
Keep all food items in closed style which will avoid odor spreading and also be a hygienic. Thanks.
Jan 30, 2011 | Refrigerators
Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
May 05, 2009 | Kenmore 13789 / 13782 Dishwasher
Need the model number of the Kenmore Elite dishwasher 1378(2)
The model number will be something like 110.123456
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 25, 2008 | Kenmore 13789 / 13782 Dishwasher
My kenmore elite ultrawash dishwasher, model # 665.16289402, will not start. The green clean light keeps blinking and when you go to push start after selecting which wash program it does nothing.
youll need to enter a diagnistic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, htne press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Dec 24, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore elite quiet pac 9
unplug dryer, then take the top off and check your connections to door switch.i believe this model has a broke belt the bottom with the machine unplugged and reach inside and see if the belt is broke.if it is then replace the belt.
Nov 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
403 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
