Question about Dell 924 All-in-One InkJet Printer
Sensor I get a message that there is no paper in the printer. tried faking it out, but nothing. DELL says.."The paper sensor no longer works. Have it checked out, & then buy a new printer" From them obviously!!! could it be paper dust or something. It is only a little over 1 yr old, & rarely used. HELP!?!
  • 1stimegram Dec 07, 2007
    Thanks for the suggestion!! I have to hide it in my trash, cause I would have to pay the dump to take it lol !! So, I have already started to search for that perfect HP. Which I did find & will buy.
    My son told me to throw that Dell away cause it isn't worth any aggrivation.
    Your site is now added to my favorites!!!!
  • 56 Answers
Hi, More than likely it could be the paper sensor !!! It recognizes the tray has paper and when the tray is loaded with paper. My suggestion for any dell printers are to take them to your local dump and get rid of it. The only reason I say this is because dell makes these printers where the parts are impossible to get and when you can find them your better off buying a new one!! I know it's frustrating but my suggestion is to try Hp or a diffrent MFG!! Good Luck! Thanks
Posted on Dec 04, 2007
Hp fake paper jam
Usually if it says there is a paper jam, there is. Remove the paper trays, look at the rear, and also open the rear of the machine. If you had a jam and removed the paper, make sure the piece of paper is whole. A mall piece in the sensor will give the error. I had that on a large Dell network printer. Also try removing the power to the machine for 10 seconds.
Apr 14, 2017 | HP Office Equipment & Supplies
How do I get the paper jam error message to turn off after fixing jam on Dell C2660 printer
Turn the power off and let it sit for a few minutes. While it is off, open all the paper path access areas and check for any pieces of paper or buildups which may affect a sensor.
Close it back up and turn it on.
Here is a link to the manual, which has two good areas covering paper jam troubleshooting and resolution (around pg 300).
Mar 03, 2015 | Dell Color Printer - C2660dn
Error, paper out, when paper is loaded.
check there is the sensor cable is broken or the sensor is faulty.
Oct 12, 2014 | Epson WorkForce WF-2540 All-in-One Inkjet...
After inserting new cartridges jobs no longer print. If you go into maintenance mode on the printer it scrolls a message "align cartridges" across the display. If you press the Check mark button at that...
Are you using Dell Series 9 ink cartridges? Dell Series 9 ink cartridges have a sensor that cannot be reset. Article on refilling Dell ink cartridges
It is possible to get a Dell Series 9 ink cartridge with a bad sensor. Take it back to the place of purchase for a replacement.
May 21, 2010 | Dell 926 All-In-One InkJet Printer
I have a Dell s200n printer, the green light bleeps and states load/ remove paper, I have tried loading new paper removing etc however nothing works, I have reset the machine and still the error stays, can...
you have a paper jam or a bad paper sensor. open the back/rear and look for ajam in the fuser. if no jam you have to call a rinter tech to find the bad sensor
Dec 30, 2009 | Dell S2500N Printer
Dell 1815 All in One Printer Says No Paper When Paper is Full
Most likely the printer is asking for paper in the Manual Printer Feeder (not the tray). Try put paper in the MPF.
Sep 01, 2009 | Dell 1815dn All-In-One Laser Printer
Printer complains: Insert Paper fully into MPF
Pull the paper tray out and look for any obstructions in there.  Check for broken parts as well such a sensor.  Sometimes they get out of position as well.
Sep 17, 2008 | Dell 3100cn Laser Printer
Dell 5200M laser printer
there is a flag in the output bin that lets the printer know when there is too much paper on top of the printer and it stops so that the papers do not continue to feed out and overflow.
Either the flag is stuck in the up position, in which case you can just gently move it so it is hanging straight down, or the flag has been broken off and no longer functional ( in which case the flag and/or sensor would need to be replaced).
May 22, 2008 | Dell M5200n Laser Printer
Add paper message
you will be glad to know, this is not your printer's fault. We went round and round with dell support when we first got 150 dell 1600n's. We sent in copies of documents that were causing the problem. Finally, they figured it out for us. Embedded in the document was junk that was telling the printer to pull from tray2. All you have to do to fix the problem, is take the word document, go into file, page setup. on paper tab, select default tray for first page, default tray for all other pages, and apply to whole document. to clear the message, you will have to delete the print job from the queue, and turn off the printer, then turn back on, and you should be set. The message add paper, is really what the printer should be telling you, except that it should add to tray2, so you know it is trying to pull paper from the manual sheetfeed port on the front.(you could add paper there, till the document finishes printing, but our docs are hundreds of pages, so that is not practical. Barry Smoke Network Administrator AR Division of Legislative Audit
Feb 25, 2008 | Dell 1600n All-In-One Laser Printer
Dell 3100cn Duplex won't feed
I'd suggest it is a sensor issue. Since the error comes up, the printer stops responding - even if everything is okay.
Jul 28, 2007 | Dell 3100cn Laser Printer
Dell 924 All-in-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
