Question about 2wire (1000-400108-001) Router
Laptop just bought a laptop for my daughter for christmas, i already have internet broadband with orange, what router will i need for the laptop to work?
    Brigadier General:
  • 6,966 Answers
It really depends on what "modem" Orange provided you with and how your personal PC is connected to the modem.
If the "modem" provided by Orange uses WiFi (such as Livebox) networking, then it is a matter of setting up your daighter's laptop to access and use the Livebox WiFi Network. In this case no router is needed since your modem is also a router.
If your PC is connected via Ethernet port to the "modem" and Orange's "modem" is a single Ethernet output port, you would need an AP/Router (Wireless since I am presuming the your daughter's laptop would be accessing the Internet wirelessly) such as the LinkSys WRT54G.
If your PC is connected via USB port to the "modem" and Orange's "modem" has only a USB output port (no Ethernet), you need to make your PC as the default gateway/software router and share your PC's Internet connection. If you are connecting your daughter's laptop using Ethernet cable, then you don't need a WiFi AP/Router but an ordinary hub. If on the other hand the new laptop would connect wirelessly, you would still need something like the WRT54G.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 04, 2007
Compaq armada v300
If you have a router on your broadband, you need a RJ45 network cable - right next to the modem port on your laptop is a network port - this will use the correct cables you need to connect to your router.
If you don't have a router but only a broadband modem, just connect it to the USB port on your laptop, install the software and you should be good to go.
Feb 08, 2009 | Compaq Armada E500 Notebook
Laptop finding router but no internet connection
If you can connect directly to your virgin Media Broadband and get internet then your laptop and broadband router is fine.
The wireless router appears not to have a DNS entry and you will need to add that manually.
I suggest that you connect directly to the Broadband modem, be sure you can get onto the internet. Once you have confirmed you can get onto the internet you need to get the dns information from your Broadband modem for later.
once connected directly to the broadband modem, click start>run> then type "CMD" then click open. you will get a prompt type the following and record the DNS Server ip addresses.
"ipconfig /all" then hit enter
this will display your ipaddress information but mostly you need the DNS server ip addresses.
once you have recorded them rerun the install, but this time instead of at the end of the install where it shows the Wireless router information you can modify or change it and add the DNS server entries.
Also by default most wireless routers ip address is 192.168.1.1 and you can type that from a internet explorer and change it from there as well. I believe it's no ID or user name and the password is admin.
Good luck
Jan 28, 2009 | NetGear WGR614 Wireless Router
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
Router linksy swrt 54g
I have not been able to connect to the internet on my laptop in several weeks. I called my cable company which we have our broadband connection with and they told me to contact the internet service , he said everything was ok and referred me to you. I do not know whatcould be wrong with my laptop. It was bought for me Christmas last year. Thanks Mary K.
Oct 01, 2008 | Linksys Wireless-G WRT54G Router
AP + 4
hi !!
check wethere if your router has a admin pass thats enable you to connect.or set to defult
or the cable that your using has defect check ur cable is working properly.
Sep 09, 2008 | Zoom Computers & Internet
Belkin Wireless Router
1. you need to put the software belkin installation disc into the girls laptop not just the desktop.
2. you need to plug the modem back in
3. on the back of the router press the little button NOT THE RESET BUTTON MAKE SURE IT IS THE LOCK BUTTON it will ask you for a password on the laptop
May 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Laptop
you can use Dlink or Netgear and just follow the instruction that come with the router.
Dec 22, 2007 | IBM ThinkPad R50e Notebook
Setting up a laptop to our home computer
As you already have a broadband at your house, its going to be very easy for you to connect the notebook in the same network.
I would assume that right now your computer would be connected directly to a DSL/Cable modem.
What you should do at this stage is that you can buy a Wireless Router.
The computer that you are using at the moment might be a desktop and may not be wireless capable.
So your Wireless router would be placed right next to your desktop and the desktop would be connected using a wire to the same router.
Your router which is wireless capale will let your notebook also connect to the internet. I am stressing on the wireless as you mentioned that the notebook will be on a different floor.
Note :- I have given this suggestion assuming that the notebook you have bought is wireless capable.
If it is not than you will have to pull a wire up to the other room and you can buy a normal router as well.
Hope that you find this as a good suggestion.
Thanks
Sammy
Nov 29, 2007 | Packard Bell Easy One Silver 2101 Notebook
2wire (1000-400108-001) Router Logo
210 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
