Home | Behringer | EUROPOWER EP2500 Amplifier | The circuit breaker on ...
Behringer EUROPOWER EP2500 Amplifier
Problem for Behringer EUROPOWER EP2500 Amplifier
The circuit breaker on my behringer europower
By benpayne on Aug 24, 2009
the circuit breaker on my behringer europower ep2500 keeps coming on when i turn it on after the posative and negative on one of the speaker outputs touched, is this repairable.
thanks
ben
Comments:
Aug 24, 2009
- i have tried pressing the reset switch but each time i turn it back on the breaker trips again.
Best Solution
posted on Aug 24, 2009
Helpful)
Abrsvcs
Rank: Guru  Home Audio  Expert
Rating: 88%, 1813 votes
Yes this is repairable, but there is no "reset" switch. There is a good possibility that the output transistors have failed. This unit requires service. If you have no experience with audio amplifier repair, take this to a service shop. Expect a parts cost in the $50 range.
Dan
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
Bob Gemmell
Rating: 86%, 126 votes
Should be a trip reset on the rear panel, maybe a small hole that needs a sharp pencil inserted into to reset.
Comments:
Aug 24, 2009
- Sadly it looks like you have blown a transistor or outpu diode. this will need specialist replacement im afraid, good luck
Was this helpful?
Yes
No
Popular Solutions for Behringer EUROPOWER EP2500
Questions and Unsolved Problems for Behringer EUROPOWER EP2500
Do you recommend Behringer EUROPOWER EP2500 Amplifier?
Answer
Answer
red light on permanently one 1 channel, that channel just buzzes
Answer
because one side of the amp lights up red and the other green
Answer
I need a europower pmh 518 schematic to repair the equipment. I brought it and the garanty was for... (More)
Answer
hi every one, i need schematic diagram pmp2000. or you can inform me about line from output mix... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Behringer EUROPOWER EP2500...:
Top Amplifier and Preamp Experts
Rank: Guru Guru
Solutions: 696
Experience: 30 Years of professional repair and design.
Ask Me
Find more Amplifier and Preamp Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
