Leaking portable machine
I notice that the machine is leaking , to me its leaking when the machine has a lot of water in it and as it spins or wash the clothes the water leaves the bin and flow over the sides of inthe bin out into the outer covering of the machine .What can i do to stop the water from flowing over
  • sexykaysvg1 Dec 04, 2007
    its a portable machine, Haier fully automatic washer
  • 447 Answers
What kind of washer is this??
Posted on Dec 04, 2007
My fisher paykel wash machine is leaking somewhere. Are there any common problems I need to look at
check the drain hose, check the main seal, check the pump.is it noisy on spin? does it leak when washing or draining or both?please reply 4 more help.
Apr 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
I have a whirlpool duet. I had washed 8 towels 2
To get inside the machine for a look, you have to take the back panel off,
1. Pull the plug
2. Turn off and then Disconnect the HOT and COLD water hoses at the machine
3. Remove bottom, side and all but 2 top corner screws from the back panel (all around the outer edges only) then supporting the panel, remove one corner screw, let the panel down on that side, then remove the other.
4.Remove panel
5. Grab a light, look inside.
My guess is that the spinning, wobbling drum worre a hose thru.
Good Luck!
Hint: Put all the back panel screws in loose, all the way around... then tighten them
Mar 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking through detergent tray of my Hotpoint WF860
It sounds like the washer is not draining properly.
Remove lower rear cover of washer, locate and remove the large black hose fastened to bottom of tub.
remove plastic filter inside hose, and clean same.
Refit filter and hose, making sure it is on properly.
Be careful when you remove the hose, as there will be water in there.
As an extra precaution, remove soap draw,and thoroughly clean all parts, particularly,the conditioner parts
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint Ultima WF860 Front Load Washer
Kenmore Washer Leak
Check the back of the tub as the water is coming in. Sometimes the water inlet gets knocked out of line if the machine shakes a lot or gets moved.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Leaking water while agitating
it sounds like a bad bearing... the tub is leaking it may leak into the bearing and cause your transmission to lose oil and water ...
Nov 29, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Water leaking from the bottom of the washer at the rear right corner!
firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Oct 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Admiral Top loader leaking water
water inlet vale has internal malfunction
Jul 20, 2008 | Admiral AW22 Top Load Washer
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
