Question about Teac CD-X8 CD Shelf System
Diagram the number of the integrated circuit?
Hi There,
Inside the Amplifier system you have, there are many IC's
installed to make the unit perform for you..These are usually numbered IC101, IC201, IC305 etc etc...
Which IC number do you need please??
Cheers From YUBEUT
Posted on Jan 26, 2008
There's a short in one of the wires plugging into my fuel pump main relay on my 94 Honda Accord EX. What's the name or number of the part (the wiring that relay plugs into) that I need to replace?
Not sure what you are asking about, but I have pasted the diagram below. The fuel pump relay is integrated to the ecm main relay. There is nothing else on the fuel pump circuit but the pump.
Sep 19, 2017 | Honda Cars & Trucks
2003 Cadillac deville trunk randomly opens on its own when sitting and not running occasionally what could be the cause.
Do you know anything about automotive electrical testing ? how to read a wiring diagram ? How to use a DVOM - digital volt ohm meter ? You can find a free wiring diagram here http://www.bbbind.com/free_tsb.html
The trunk release is controlled by an electronic control moduel .
Trunk Release Relay
Output Controls
The rear integration module grounds the trunk relay when commanded ON. The rear compartment should release.
This vehicle has a very complex body control system of three different computers
The body control system consists of the following 3 modules:
• The Dash Integration Module (DIM)
• The Instrument Panel Module (IPM)
• The Rear Integration Module (RIM)
Each of the 3 body control modules integrate a number of functional systems under the control of a single module. Each module is connected to the Class 2 serial data circuit, many of the control functions are implemented by Class 2 messages.
. Rear Integration Module (RIM)
The various RIM inputs and outputs are described in the corresponding functional areas as indicated on the RIM electrical schematics.
The RIM functions include the following:
• Automatic level control
• CIGAR relay control
• Class 2 communication requiring RIM interaction
• Content theft deterrent
• Fuel door control
• Fuel level sensor input
• Heated seat control
• HVAC blower control
• LK/CYL relay control
• Park brake relay control
• Rear defog relay control
• Rear park assist chime control
• Retained accessory power (RAP) relay control
• Reverse relay control
• Transmission shift inhibit
• Trunk release relay control
• Various controls for the interior lamps
Luggage Compartment Description and Operation (General)
Rear Compartment Lid (trunk) release actuation is controlled by the following components.
• Rear Compartment Lid Release Relay
• Instrument Panel Module (IPM)
• Rear Integration Module (RIM)
• Valet Switch
• Rear Compartment Lid Release Switch
• Rear Compartment Lid Release Actuator
Battery voltage for the coil side of the trunk release relay is supplied through the Valet switch (with the valet switch in the OFF position) by the ALDL fuse located in the Underhood Fuse (Bussed) Block. Battery voltage for the switch side of the trunk release relay is supplied by the Body fuse located in the Rear Fuse (Bussed) Block. When the rear compartment lid release switch is momentarily pressed, it provides a ground circuit for the trunk release signal of the Instrument Panel Module (IPM). When the IPM senses that the switch has been activated, it sends a Serial Data Class 2 message to the Rear Integration Module (RIM). The RIM then provides a path to ground on the F/TNK DR REL relay control circuit. The trunk release relay is then energized, and battery voltage is applied through the switch side contacts of the trunk release relay to the rear compartment lid release actuator. The actuator is connected to ground through a ground splice pack located at the left rear corner of the rear compartment, near the left tail lamp connector.
Mar 01, 2017 | Cadillac DeVille Cars & Trucks
WHAT IS THE IDENTIFICATION NUMBER OF SOUND INTEGRATED CIRCUIT
Its number will be printed on it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Schematic diagrams to many popular brand TVs are given. Hope it might help you to check it out.
Apr 30, 2015 | Televison & Video
Circuit diagram board for sansui integrated amplifier Au-x410R
Circuit diagrams are in PDF, so cannot uploaded by this window.If you wish to get more details, check the site linked here
Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 09, 2013 | Prima Televison & Video
Where is relay switch for fuel pump on 2004 dodge ram 1500
Note the diagram, located in the integrated power module, the integrated should be located under the hood. You see the fuse and circuit breaker. Just curious, engine cranking, do you have spark at the plugs and fuel injector pulse?
Mar 20, 2012 | 2004 Dodge Ram 1500
What is full meaning of the following codes in design and constructing an inverter-NE55,CD4013,JRC455,A733,IRFP150,1N4007,C945.
These numbers are the identification of some electronic devices that probably are being used in the inverter's circuit:
CD4013 - Dual D Flip-Flop integrated circuit
1N4007 - 1 A rectifier diode
IRFP150 - power MOSFET
A733 (2SA722) - PNP silicon transistor (low frequency amplifier)
C945 (2SC945) - NPN silicon transistor (low speed switching)
I could not find the devices marked JRC455 and NE55 - maybe they were not correctly marked, but there are some devices which have similar designations: JRC4559 is a dual operational amplifier integrated circuit and the NE555 is a time/oscillator integrated circuit.
You can download their datasheets from
http://www.alldatasheets.com
Hope this information can be useful!
Mar 09, 2011 | Electronics - Others
Diagram.
Hi Jah,
I would suggest that you obtain a copy of the service manual for this audio system.
The service manual will provide you with all the components used and their specific part number then you can order the part from the manufacturer or the local supplier of electronic parts.
A good source of manuals can be obtained at:-
http://www.user-manuals.com/
or
www.hisierrahifi.com
Regards From YUBEUT
Dec 04, 2007 | Teac CD-X8 CD Shelf System
Teac CD-X8 CD Shelf System Logo
134 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
