Question about NetGear WGR614 Wireless Router
Can't connect tried so many times but having difficulty, my main port computer not connecting to them internet
    New Friend:
  • 33 Answers
Most of the people are facing problem while connecting to internet. For most of the people their NAT router are the biggest problem for their internet connection. You can take the help of wireless router which combines the functions of two device the router and the wireless access point. The wireless access point is simply a network which is used to connect to the internet. Free Government Cell Phones Get Free Cell Phone 250 Free Min Month
Posted on Mar 02, 2015
  • 556 Answers
First if your computer has an ethernet port attempt to connect through the router to the internet with a wire. If that works the next question is did you buy this device new or used? If used we can work to assure we know the configuration of the device. Second what is the manufacturer and model of your computer? Third, if the wireless adapter is not built into the computer what do you know about the make and model of the wireless adapter? Armed with the above information we should be able to resolve the issue.
Thanks
Posted on Dec 06, 2007
Have Netgear wndr3300 router...has been in use with main desktop and 2 laptops running windows 7 for some time....son came home from army with an HP running Vista....no matter what we try...will not...
you might try a connection through the modem first to see if you can get a connection
check your son's computers settings ie: firewall also he might have a default internet setting you might have reconfigure all internet settings on his computer
check the leads from the router whether usb,ethernet make sure they are not bad/faulty and have secure connections or try different ports
click start control panel administrive tools computer management device manager scroll to network adapters + to expand any yellow ! ? or a red x will mean that the driver is corrupt and needs to be updated
hope this helps
Jan 17, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
I cannot use the switch to connect more then one computer to then internet at the same time. Only one computer can connect at a time. I have rebooted my cable modem with two compuetrs attached to the...
The purpose of a switch is communicate with several other devices. The ports out are each independent; such as a 5 port Gigabit Ethernet switch. The main input is direct to a source (like a wireless or wired Modem) and in turn it communicates between the modem and any one of the 5 independent lines OUT (usually out to another device, such as another computer). If the switch fails to communicate with other devices, it may be defective or the power supply could be at fault. Check connections. Especially check the main cable from the modem to the switch.
Jan 14, 2018 | Dynex 5 Port 10/100 Ethernet Switch...
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
I am trying to install a Netgear WGR614v9 router. Disk will not install it, so tried a manual install. Shut down all firewalls, used no passwords or security settings. It keeps throwing me back to the...
The router needs to be configured manually. Follow the steps below.
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing). Or password is admin also.
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Configuring router for Cable Internet
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Step 1 Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Step 2 Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' and password is blank (nothing). Or password is admin as well.
Step 3 After logging into the router select Setup. Set Internet Connection to 'Dynamic IP (DHCP)' option.
Step 4 Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the cable modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your cable modem as well.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Oct 06, 2009 | NetGear WGR614 Wireless Router
My computer can see my router but can't get past my modem
1. delete all the saved networks from your computer
2. Make sure that firewall id disabled in computer
3. Tried to set your wireless as unsecured network and try to connect
4. Uninstall/Reinstall wireless adaptor and tried.
Aug 05, 2009 | Belkin (F5D7230-4) Router (587009)
Not seeing the internet. We have a sattelite internet system and the modem works great. I am wired into it now andhave internet no problem. But when I run the "EASY" installation of the wireless router, it...
If you are having difficulties accessing the Internet, you need to do MAC Cloning.
Disconnect your computer from the modem first and plug it to port 1 on the back of the router. Access the router's admin page by typing http://192.168.1.1 on your Internet Explorer. When you get to the router's setup page, look for the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the modem was directly connected the last time. This will place the MAC address of your computer into the router. Save settings then turn off the router.
Now connect your modem to the WAN/Internet port of the router. You connection should be: PC to port 1, Modem to WAN/Internet port. Reboot the router and reboot your cable modem as well.
You should be able to go online after that.
Aug 05, 2009 | Computers & Internet
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Having to reboot router at least once a week
Hi, First of All I would like to inform you about the Ideal Broad band Setup. An ideal BB Setup should be in the Following Way :-
Master socket (main telephone socket) << Filter << Router << Computer.
There should not be any other things connected in between. you can connect it to the secondary or extension socket as well but it depends. sometime you may face problem with it.
As you told that you have a Hub connected to the Router If there are multiple Ethernet ports on Router there is no use of it at all but if there is only 1 port then you can connect Hub after router.
Try this and I m sure you will not face any difficulties in future.
One more Advice for you If you face any Difficulty like yesterday Internet was working fine but today its not or similar ..... Just do this ........... Switch OFF your Router. wait for 40 sec. Switch ON your Router n Wait till you get All the lights Solid Green on the Router (not Flashing apart from Ethernet Light) Try Connecting to Internet in most of the cases it Works :)
Feb 18, 2009 | NetGear WNR854T Router (WNR854T100NAS)
WRT300N dosnt connect
if your connection (isp) is CABLE you will need to clone the mac of the main computer.
For cable connection verify what computer can go online with your modem, once you know the main pc connect it to port one, access the routers setup page by typing 192.169.1.1 then locate MAC ADDRESS CLONE in line with basic setup. enable it click the macclone button then save settings.
connect your modem to the internet port on the router, do a power cycle on the modem and router.
then check the status tab on the linksys setup page if you have numbers on the dns it should be online.
Sep 12, 2008 | Linksys WRT300N Wireless Router
Additional computers & internet access
You can do this. Identify the ip address of your main router. EXAMPLE: If your main router has 192.168.1.1, you can connect the cat5 cable from your main router to the INTERNET PORT of the NR041. Set the NR041 ip to 192.168.2.1.
JUST MAKE SURE THAT THE IP ADDRESS OF THE TWO ROUTERS ARE DIFFERENT.
You can then connect the 3 computers to the NR041
Good Day
Mar 07, 2008 | Linksys (NR041) Router
NetGear WGR614 Wireless Router Logo
70 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
