Back to:
Tags:
Zenith VCS442 VHS VCR
How do I get my local channels from my VCR.
posted by Drelita on Dec 04, 2007
I am having problems finding the local channels from my vcr. The only channels I found are channels 2, 4, 5. I tried to add the channels. The vcr would let me. Please advise.
Comment by Drelita, posted on Dec 06, 2007
Thank you for the informatin. It was very helpful. Keep up the good work!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 04, 2007
Not Rated (0)
Falling Down
Rank:Guru Guru
Rating: 87%, 95 votes
If you have a cable or satellite converter all inputs are converted to channel 3 or 4. If your vcr is attached to this output you will only get whatever the converter is tuned to. If you have cable, try connecting the cable that's now on the input to the converter to the input of the vcr and then add the channels automatically. However, the converter also descrambles premium channels, so you cannot get them into the vcr without going through the converter first, and some digital cable channels will not work on all vcrs. If you use the converter, always leave the vcr on channel 3 or 4 or use the converter video/audio outputs. You will not be able to record one channel and watch another without some additional hardware including an rf switch, rf splitter, and more cables.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on How do I get my local channels from my VCR.:
I don't want to Accept this solution
Can you Help with these VCRs problems?
VCRs
I have a hitachi video recorder vt-rm800ev and i need a...
VCRs
How do I stop a VCR recording? Digilogic VCR/DVD Combi...
VCRs
I have an LG VCR model no. EC490SW/EC290SW (about 6 or 7...
I need the code to use to program a Zenith VCS442 serial #...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
