Changing paper roll on Citizen CX-121 Calculator
Hi
I'm having trouble trying to replace the paper roll on my cx121 calculator. I can't seem to find exactly where to feed the paper into. I've tried every possible feed inlet whilst I press the 'feed' button, but it just won't accept the paper.
Any ideas guys.
thanks in advance
Jen
  • mummaroo Apr 11, 2008
    Thanks for this - it worked a trick. You're brillaint!
  • sandy612 Aug 20, 2008
    I cant find the paper feed to install the paper roll.
At the back between the top cover and bottom cover is a tiny groove to slip the paper in. Simple if you know how. I need a manual please.
Posted on Apr 11, 2008
Sharp calculator EL-1197P III paper feed stuck
Hi
I trust you are well.
This might be trivial however when you replace your paper roll the edge of the edge paper must be cut straight otherwise the paper will not feed correctly.
Hope this solution is as easy as that, If not open the claculator paper feed compartment and check the gear mechanism for chipped teeth or foreign objects stuck inside.
Hope this helps you
Kind regards
Aug 15, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
What size paper roll is used for TI 5045sv? Can't seem to find it anywhere!
Standard 2-1/4 inch wide plain paper single copy calculator paper rolls, available at Office Depot, Reliable Office Supplies, and many other office supply stores and catalogs. Probably have them at Staples, too.
Mar 24, 2013 | Texas Instruments TI-5045 SVC Calculator
How do I install adding machine paper roll
Slide off the upper cover of the calculator, and cut across the paper roll to form a clean end.
If you are mounting the roll externally (outside of the back of the calculator), then look for a slot in the rear of the calculator, which will accept the paper. Feed the end of the paper through the rear slot, and then into the internal feed slot, and hold the [FEED] key. After that, you can flip the arm back to mount the roll and replace the upper cover.
If you want to place the roll inside of the calculator, then you need to feed from the bottom of the roll into the internal feed slot, and hold the [FEED] key. After you are finished, replace the upper cover.
Nov 23, 2009 | Canon P1-DHV Calculator
Replacement paper roll size???
Your calculater takes 2 1/4 inch wide standard rolls of paper. These rolls are available all over the place so you should have no trouble finding the rolls.
Sep 26, 2009 | Sharp EL-1197PIII Calculator
Don't have a manual; have pulled the top off but can't figure out exactly how the paper should go in.
Sep 08, 2009 | Texas Instruments TI-5019 Calculator
How do you load the paper?
Aug 31, 2009 | Canon P23-DH Calculator
Need help replacing the paper roll on a Casio BIG 12-Digit adding machine.
Aug 21, 2009 | Office Equipment & Supplies
Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Apr 09, 2009 | Sharp EL-1801C Calculator
632 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
