Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon pixma mp 160
Paper jams on right side of paper feeder and will not feed thru
  • amyv Feb 02, 2008
    I'm having the same problem, I did all the maintenance as suggested in the manual. Was able to print a few black and white pages. The auto sheet feed wheel is on the right side only as far as I can tell. It seems to be grabbing at the paper too quickly and doing such grabs many sheets and pulls them through so quickly the paper twists and that causes other problems.
Paper jammed in side wheel. i unjammed it but it still wont reset and print
Posted on Nov 24, 2008
    Scholar:
  • 29 Answers
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Yesterday someone replied to my problem, i tried it this morning and its fixed 1st time.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 02, 2008
  • 4 Answers
HI this is happening to me right now too-- try this-- I'm not sure if it's going to work-- but it's worth a shot.
On your computer, go to a print menu to print a document.
click on properties
go to maintenance tab
try the quiet/sleep mode
also, try going to custom and slow down the printing allowing for a little extra dry time.
reason I suggest it: my printer is doing the same, it's almost like the auto sheet feeder (only on the right side--why paper is grabbing weird) is grabbing too quickly. When in sleep mode, it seems to slow it down a little. I've also been printing 1 page at a time. I'm not saying this is a permanent fix, but at $50 for a pack of ink-- hopefully if you can't fix it-- it can get you to use up the last of the ink you have incase you decide to get a new printer.
Posted on Feb 02, 2008
Mp 530 error code 103.0.0
you will see small levers were the paper passes. check if one of them are not stuck.
Oct 20, 2011 | Canon PIXMA MP530 All-In-One InkJet...
The printer keeps telling me it's out of paper, which it isn't
1> Open the sheet feeder cover and pull out the paper support.
Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
Pinch and slide the paper guide to the paper's left side.
Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
Pull down the paper output tray supporting with both hands.
Pull out the extension completely.
Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
My all in one has an error message
E3 is a paper jam they may be small bit paper jam in side
Jan 17, 2010 | Canon PIXMA MP160 All-In-One InkJet...
How topaper load cannon mp 160 pixma
Loading Paper into your Canon MP 160 Pixma.
A) Loading Paper :
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Set the Paper ThicknessLever to the correct position for the paper.
Note : Set the Lever to the left for most paper. When the Lever is set to the right, the confirmation message appears before the machine starts printing.
Important : Make sure the stack does not exceed the Load Limit Mark.
B) Loading Envelopes
Follow the following steps:
2) Prepare the envelopes for loading.
Important : * Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
* Remove any curling by holding the edges diagonally and bending them gently.
* If the edges of the envelopes are inflated or curled, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
* Ensure that no curl or puff exceeds 1/8 in. (3mm).
3) Place the stack of envelopes (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Load the envelopes in the Auto Sheet Feeder with the short side down.
* Set the Paper Thickness Lever to the right.
Important : Make sure that the stack does not exceed the Load Limit Mark.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
Dec 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
I have a Canon PIXMA MP 600. The paper doesn't feed properly anymore. Everytime I get an error: Auto sheet feeder. There is no paper load paper. I checked everything and there is no paper jammed. Is it...
Greetings,
If your are not loading from the ADF, check the settings and see if it is set to get paper from the Auto-Sheet Feeder.
Sometimes having an equipment repaired costs more than buying a new one.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 20, 2008 | Canon Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
304 people viewed this question
old marine
old marine
