Question about Konica Minolta Di1610 Copier
Help! i get the "Machine Trouble" error
I am a user of minolta di1610 as a copier. i broke it buy pressing keys/buttons over and over. i think i pressed "paper" and "yes" button too fast and too many times. it resulted to a "machine trouble" message on the screen. this message is followed by "contact service C01510". :( and in the manual, it only says what the error is and not how to fix it:
“MACHINE TROUBLE” Error
This error indicates a serious operational problem. The copier is unable to
receive any data while this error message is on the display.
is there a way for me to fix this? can you please help me? thank you very much!
  • alohamahal Dec 05, 2007
    THANK YOU VERY MUCH!!! the copier is now fixed! you are a life saver!!! thank you so much!
    and you are right, it was the wrong "trouble code". the correct one is C0150.
    thanks again! :)
    Champion:
  • 214 Answers
Are you sure thats the right trouble code? reboot machine holding down the STOP button. this may reset this error
Posted on Dec 05, 2007
My konica Minolta buzhub 362 copier shows error 3452
Restart the machine.If code removes then its OK, otherwise press the utility/counter button and restart the machine.Don not leave the button.Keep the button pressed.Trouble reset will appear on screen hit it and restart the machine.
Nov 21, 2012 | Konica Minolta Bizhub 362 Copier
When i turn on my minolta di1610, lcd show me error ''Caution.Paper jam. Open front cover''. What's that and how i can fix it? Please help and sorry for my english 1. Power the machine OFF. 2. Press...
Front cover is placed on front of machine. Should be some tabs near top, or on either side. If not, use finger nails or thin sturdy tool or object to pop open. Should be very little resistance. Don't force it. Should see all the guts of copier or whatever it may be. Usually can see the paper stuck in there. Good idea to unplug and try pulling jammed paper out. Close and restart.
Feb 03, 2018 | Konica Minolta Di1610 Copier
Caution Machine trouble service call C0F32 any suggestions
put new developer to pcu by help of techincian,if it still there change pcu
Oct 10, 2010 | Konica Minolta Di1610 Copier
C0520
  • 1. Turn the machine OFF.
  • 2. Press and hold the STOP key.
  • 3. Power the machine ON and release the STOP button after 5 seconds.
Sep 28, 2010 | Konica Minolta Di1610 Copier
Inncorrect tc type
incorrect type of toner cartridge was installed. only use the toner cartridge that has been manufactured specifcally for this machine.
Oct 09, 2009 | Konica Minolta Di1610 Copier
Machine trouble
Sir,
To clear the fuser error code, perform the following:
3. Power the machine ON. Release STOP after 5 seconds.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 16, 2009 | Konica Minolta Di1610 Copier
Minolta di1610 error message
What error message? Does itsay toner cartragie need replaced.
Apr 04, 2009 | Konica Minolta Di1610 Copier
IError Code C13FO on konica minolta Di1610
C13F0 - Laser error
The laser output exceeds the upper limit value.
The laser output remains lower than the lower limit value.
Feb 25, 2009 | Konica Minolta Di1610 Copier
How do I input ip address in Minolta DI1610
press the Utility/Counter -> Network Settings -> IP address
Feb 09, 2009 | Konica Minolta Di1610 Copier
Problem with Konica Minolta Di1610
Incorrect T/C type means that toner cartridge have not good contact with toner chip, is good to clean this chip, or contact inside magine is not good. Change toner cartridge and if that problem remain, its needed replace contact unit on machine
Sep 21, 2007 | Konica Minolta Di1610 Copier
Konica Minolta Di1610 Copier Logo
323 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
