Question about Akai LCT3201TD 32 in. LCD Television
Audio Output Problem
In trying to hook up RCA connections to the audio output jacks of the Akai LCT3201TD LCD TV, there is no output. I have verified that the source that I am outputting to works. Any suggestions?
  • 386guy Nov 28, 2008
    Audio output jacks on right side of TV as you're looking at it from the back do not seem to have any output to my home theater system. I have coax from DVD and it works fine but there is no sound output from RCA plugs for TV mode when using local cable. Speakers on TV work fine but no output to home theater system.
Select DVD Input source, then press the Setup button on the remote (it's under the DVD control block near Subtitle). Go to the Speaker Setup Page and select LT/RT or Stereo. After I set it up it seems to work for other Input modes also. I have the 27" model.
Posted on Dec 22, 2007
Can you hook up a digital converter to a akai model num lct3201td 32 inch tv
The converter box connects to the antenna input of your TV or, for better picture quality, L audio, R audio, and video outputs from the box can be connected to corresponding inputs on the rear of your TV.
Nov 02, 2016 | Akai LCT3201TD 32 in. LCD Television
We have just bought an Akai 32 inch full hd tv (ak32fled) and are trying to hook it up to our surround sound system. We have hooked it up so that we can watch dvds through the tv, but there doesn't seem...
There should be audio out sockets at its rear side. Refer user manual for details about how to connect it with external audio output devices. If you feel any difficulty, contact the authorized dealer.
Oct 05, 2013 | Akai LCT3201TD 32 in. LCD Television
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
Don't know how to connect to tv
If the TV has audio output available, there will be RCA jacks somewhere for that. The standard colors are red for the right channel and white for the left, and they'll be clearly marked as audio outputs. Not all sets have audio outputs, though, while they usually have audio and video inputs. So if you find RCA jacks on the set be sure to see how they are marked.
If the TV has output jacks, all you need is a cable with the appropriate plugs at each end. The TV needs RCA plugs, while the input connector to the speakers varies by manufacturer. Typically the speakers will use a 1/8-inch stereo jack if they were made to be used with a computer, and RCA jacks if they were meant to be used in a home-theater setting. In TV sets with audio outputs, the output may be fixed and independent of the TV volume, which means you can turn the TV volume down and use just the external speakers. Or the audio output may vary with the TV volume, meaning you'll always need to have the TV volume on as well. Some people find this annoying.
If the TV doesn't have an audio output available, you can't hook the speakers to the TV. What most people do in that case is use the TV as a video display in conjunction with an AV receiver. The audio and video sources connect to the receiver, which in turn drives the speakers and provides a video output to the TV.
Feb 27, 2011 | Durabrand 5.1 Surround Sound Computer...
My akai lcd tv model lct2721ad sound will not work.
We need to verify if the problem is in the preamp or poweramp sections. Hook up the powered PC speakers to the AUDIO Line out RCA jacks and verify that sound is OK there, if it is OK, The problem will be in the power amp sections that drive the speakers. If it sounds bad at the RCA jacks, the problem will be in the sound processor board which mean the main board will have to be replaced, same if the power amp is bad.
Nov 06, 2009 | Akai LCT2715 27 in. LCD Television
Need headphone solution for Panasonic c12lcd tv
I have a Panasonic viera 32in lcd hd tv. I'm trying to hook up headphones but there's is no apparent audio output jacks. But there's is only one digtal output jack! is this the jack ? and if it is, what cables do I need to make the headphones work? or am I forced into by an amplifier
Sep 30, 2009 | Panasonic Viera TC-32LZ800 32 in. LCD HDTV
Proscan 32lb30Q. I need to hook up wireless
You can buy a digital to analogue converter that connects to your COAX digital output and then connects to you RCA jacks. They run around $75. The only problem I've encountered is the DVD does not work through the COAX output, just TV. I'm looking into it.
Jul 01, 2009 | Proscan 32LB30QD 32 in. LCD TV
Akai TV
there was n0 earplug input, but u can use the Audio Out: RCA and u will use a earplugc0nverter t0 rca HERE
Jan 15, 2009 | Akai LCT3201TD 32 in. LCD Television
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
Sep 12, 2007 | Digital Audio 5-OUTPUT COMPONENT VIDEO...
Akai LCT3201TD 32 in. LCD Television Logo
156 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
