Cadence Z5000 Car Audio Amplifier
Problem for Cadence Z5000 Car Audio Amplifier
Loud popingggggggggggggg when i turn the amp on and off....rawwww
By kuhubby on Aug 24, 2009
I have tryed mant different things to fix this prob.....as soon as i power the amp on it pops the subs really loud......I heard a few things
1. ground
2. remote
3. haveing the rca's and the remote to close runing back to the amp
4. Some One said that pionner head units just do that.
I have a Pionner deh-600ub........This sucks....can i mess up my subs with this poppppppppping? ? ? ? ? ? ? ?
Comments:
Aug 24, 2009
- This is the only car where i have had this problem. I had a JL 500/1 that did the same thing....now i have a kicker zx1500.1.....Both amps where brand new at the time of install. Everything is brand new. cd, amp and subs.. .This kicker amp has over 1700 watts rms so i think its powerful enough...I dont know...Im leanin towards something in the cd player. I am going to hook up a old deck this after noon and see what happens.....thanks for helping.
Solution #1
posted on Aug 24, 2009
Not Rated)
ronaldo_ross
Rank: Wiz
Rating: 84%, 296 votes
All amplifiers are designed so that when you first turn it on the sound increases gradually so the voltage spike caused by turning it on doesn't get amplified. The problem is in the amp itself, and only good electronic technician can fix this problem. You can't fix that yourself, but I will give you an idea of how a car amp works.
A car amp actually operates in roughly 70 volts DC. It takes the 12 volts, and steps it up to two voltages of -35V and +35V. It accomplish this by a circuit called SMPS or switch mode power supply. There is the preamp circuits then the power amp circuit. Music is fed to the pre amp, through series of filter circuits which filter out the high frequency for example so you end up with only the bass.which can be adjusted to your preference. The actual amplification goes through many stages to provide a clean distorted free sound. The final stage is the big transistors that actually drive the speakers. Usually there is a slight delay for the power amp circuit to come on that way it wont amplify the sudden surge of current when it is turned on. Some house amps uses relay in series with the speaker that has a timing circuit, and you hear it click a few seconds after you turn on the power. Relays are not used in higher powered amps. One way to fix this problem is using relays that has a timing circuit that comes on after a few second after the amp is turned on. You can put it in series with the positive side of the speaker, but only if its not a very powerfull amp. Maybe up to 600 watts. Higher powered amp may burn the relay contacts prematurely. You can learn to build simple timing circuits to drive relays. They only use a few parts, and maybe use a breadboard to test them. Don't try to mess with the inside circuitry on your amp, because they are very sensitive, specially the SMPS circuit. I hope this is helpfull.
Was this helpful?
Yes
No
Popular Solutions for Cadence Z5000 Car Audio
Questions and Unsolved Problems for Cadence Z5000 Car Audio
Do you recommend Cadence Z5000 Car Audio Amplifier?
Answer
Answer
i have a clarion head unit i have connected all wires it was working fine for about 2 days then all... (More)
Answer
what wattage is themvr-t501
Answer
owner s manual wiring diagram phoenixgold qx 2180
Answer
humming noise no sound play back . makes loud humming noise weather the rca inputs are pluged in or... (More)
Answer
i cannot find an owners or technical manual for my db drive amplifier
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Car Amplifiers Experts
Top Audio & Video Equipment Repairmen
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
