Question about Panasonic KV S2026C Path-Through Scanner
Remove paper from scanner
I get an error light and a message to remove paper from scanner. There is no paper in the scanner. What is causing this and how can I fix this error?
  • 3 more comments
  • Anonymous Mar 05, 2008
    Same problem, cleaned everything but to no avail
  • Anonymous Jul 02, 2008
    I have the same error. I've cleaned the sensors and rollers as instructed, then using the user utility, cleared the counters and still have the same problem. Everything apprears to be in place and there was never any paper jammed or left in the scanner. Is there any way to fix this or is the machine busted?
  • Anonymous Jul 08, 2008
    Same problem. Have turned on, turned off, opened door, closed door - no paper is stuck, yet the machine insists there is a paper jam and refuses to work. Help?
  • keneblack Jul 11, 2008
    same exact problem, no solution here. Please help!
  • tsbmd Feb 14, 2009
    Same problem with mine. I try wiping down with alcohol swabs and using a compressed air canister to blow out any dust. Usually after doing these things and waiting, it will start working...only to go thru it again the next time I want to scan.
I have this same problem every time I unplug my Panasonic KV-2026C. I've lost the original disk with the utilities, and the Panasonic web site says, they only provide the disk with the original equipment. You know, I'll never buy another Panasonic product. But I'm usually able to get the ready light to come back on by doing the following. I use a clean cloth that is soaked in Rubbing Alcohol (not nail polish remover, but pure rubbing alcohol). I basically open up the back, and clean each roller. There are two green tabs at the top of the back of the scanner. These need to be opened up (be careful, because the parts sort of fall out if you're not careful, and they are difficult to re-assemble). Again, wipe everything down with the rubbing alcohol. Close up the upper tabs. Make sure you wipe down the glass slits on both the door (front-of-the-page scanning port) and on the unit itsel (back-of-the-page scanning port). Before you close up the back door, let it sit for about 5 minutes, allowing the rubbing alcohol to evaporate. I also connect the scanner to the laptop and get the "blip" sound from Windows to recognize the scanner. I don't know if that's important or not. Then I say a healthy prayer, plug it back in and shut the back door. If there is a god on duty that day, the ready light comes on, and stays on as long as I have the power connected. I just went through the process and it worked!!!! The minute the power is off, the error light stays on. Good luck, my friends! Joe Diehl, Seattle WA
Posted on Aug 10, 2008
I have the same issue with my Panasonic...and do the same routine as Joseph Diehl, but add a little bit. In addition to rubbing alcohol, i used can spray on the whole back "inside" portion of the machine. I also rub the sensors and reflective "mirrors" which usually helps. Normally i can get it to work, every once in a while it needs a days rest...and then it works. Sometimes it just needs to be turned on in the early morning, opened up, sit there and warm up, and then used later on in the day! Good luck...a lot of voodoo goes into making this machine stay in operation mode.
Posted on May 21, 2010
In addition to the comment i posted 7/2/08, it gives me error code U18-18000000
Posted on Jul 02, 2008
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
Printer TX550W has message "A printer error has occurred. Turn off and then on. See your documentation".
Hi, this error message usually caused by jammed papers or foreign objects inside your printer. To resolve this issue, please try the following steps.
1. Turn off the printer.2. Open the scanner unit.3. Check for any jammed papers or foreign objects then remove it.4. Check the ink cartridges and lids if push down fully.5. Close the scanner unit.6. Turn on the printer.
If the same error reappears, try the following.
1. Turn off the printer.2. Open the scanner unit.3. Remove all the ink cartridges.4. Turn on the printer >> your printer will display install ink cartridges.5. Install all the ink cartridges, make sure it clicks into place and also the lids should be push down fully.5. Close the scanner unit.6. Press the Start or OK button to charge the cartridges.
If the issue persists, your unit will require service. Please contact Epson so they can check if your printer is still under warranty or ask them for the nearest service center in your area.
Nov 23, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Epson BX600FW Photocopier saying paper jam and we can't see any.
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message. A paper jamb could be caused by dirty orsticky rollers, also failure to remove all traces of paper from a previouspaper jamb.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.
Try cleaning the rollers with methylated spirits
May 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Printhead carriage jam facult is showing. No jam, I tried calling the help line. I still have the printhead error fault.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
It says there is a document jam and to clear scanner but there is not paper in the machine. What do I do?
Nov 09, 2010 | Brother MFC-8460N All-In-One Printer
It is saying paper james in the printer, open the scanner unit and remove paper, however there is no paper, have turned off the machine and still comes up with the same problem
Oct 25, 2010 | Office Equipment & Supplies
My Documate 152 is saying paper jam but no paper jam
E08 error message which indicates papert jam is caused by lose or mis-alligned input paper tray (automatic document feeder).
Resolve issue by powering off the scanner, opening the paper path section, removing the adf, and then re-seating the adf.
Mar 26, 2010 | Xerox DocuMate 152 Pass-Through Scanner
I have a toshiba EStudio 162 error message L100-00 how do I fix
Hi:
If the error code is an L-1 the most lokely cause is the scanner lock on your machine is engaging with the scanner assy. Bend down and look at the left front corner of the copier right inside of the area where you grab your copies. You should see a clear round plastis knob. This has to be in the fully unlocked position If it is partly turned then this can be stalling your scanner assy and throwing the error code your seeing.
Good Luck
Andrew
Jun 12, 2009 | Toshiba e-Studio162D Copier
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Panasonic KV S2026C Path-Through Scanner Logo
2,310 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
