Question about Seagate (ST3160827AS) 160 GB Hard Drive
USB Mass Storage
Harddrive would not boot. I bought a Enclouser to put the drive to try to read the data on it but can not get it to show up onthe MY COMPUTER screen. The new hardware found seemed to work. Is there a way to just get the data off
  • bartd Dec 04, 2007
    thanks
  • vitty Feb 15, 2008
    when the hard disc is inserted,the computer gives a sign that a USB is found.but there is no sign in the computer, and u cannot open it.
  • 449 Answers
Let me know if your hard disk is a Usb type. and if it is a usb type i suggest you buy a laptop hardisk adapter so that you can slave the hard disk with your system.byeeeeeeeeee
Posted on Apr 02, 2008
Try opening some files saved in your usb. Example if you have files saved in excel format, open your excel program then click in open files and select files saved in your usb. You will be able to open the files in excel using this method. You can do the same for any file you want to open. The downside is you cannot open the whole usb file and navigate or explore as usual.
Posted on Mar 14, 2008
Which mass storage device asus eee1005ha is?
The harddrive
(A USB thumbdrive is a removable mass storage device.
An external harddrive is a removable mass storage device.
A harddrive is a mass storage device that is installed IN the netbook.
NOT considered removable, therefor the one mass storage device)
Regards,
joecoolvette
Dec 17, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I have a Kingston 2.GB Data Traveler filled with data, and no instructions on how to open it to read it. Please tell me how to open. Thank you.
Your USB drive should show up under My computer. Double click on my computer and look for an icon that says something like mass storage device. The drive should be E: or above. If you double click on that icon, everything saved to the drive should show up just like any other harddrive. You can drag items to or from this drive.
Feb 20, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My WDBAAU0015HBK external harddrive don't boot when i start up my computer. It says initalising USB divices and then when it autodetect the USB mass storage devices it stops. In the BIOS i put the boot...
It sounds like the BIOS is set to auto-boot from the USB device.
Have you reset the 'boot order' in the BIOS?
Also if you are still running sp2 go to Microsoft update and install the updates. You should be running on service pack 3.
(the updates are free, and are more secure than sp2)
Jul 20, 2010 | Computers & Internet
I have a LG Cu920 model and bought a micro sd 8GB card and used the USB data cable to connect to the PC and i am unable to get connection established as it displays connecting to mass storage device and...
When it displays insert memory card for connecting as mass storage device, switch off the phone and reconnect so the phone will perform as a memory storage device.
Good luck.
Mar 16, 2010 | LG Vu CU920 Cellular Phone
Bought a Creative I/O USB2.0 to SATA/IDE Cable to retrieve files from an old harddrive and put on my new harddrive. When I plug the system in, my mouse doesn't work properly. Mouse arrow struggles to move....
This is most likely a defective adapter cable. I just bought this same cable and it was dead-on-arrival. The customer reviews on Newegg have about 30% negative reviews for it. Seems the power supplies are subject to failure quite often.
Although, if you are getting the transfer to work, you may just be saturating the USB bus. If this is the case, then when the transfer is done your mouse should go back to working ok. It's better to not try using your computer during a harddrive transfer anyways.
Dec 04, 2009 | Creative Labs Creative I/O SY-U2-IDE USB...
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Can not see my Harddrive
if it says its in the safley remove, but its not showing up, it might have the same drive letter as one of your other hard drives, for XP: 1.go to control panel (start -> control panel) 2.click on "switch to classic view" (top left) 3.click on "administrative tools" it should open up and show more icons 4.click on "computer management" it should open the computer manager 5.on the left side, with the drop down menu's and stuff, open storage, then clikc "Disk Management" 6. in the window left of what you just clicked,find your drive, you should not the capacity and basic stuff about your drive, you should be able to find it 7. right click on your drive and click "Change Drive Letter and Paths" 8.click "Change" 9. in the drop-down menu choose a new drive letter, that isn't being used 10. click Ok and it should work. if it doesn't see if your drive needs to be plugged into a wall to get extra power. or somthing
Dec 07, 2008 | Computers & Internet
Can the disc of a external harddrive be change to get your data recovery back
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Jan 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Isn't being read anymore
Please repair the master boot record(mbr) might be damage cause of viruses. If the harddrive detected in the CMOS there is no possible that can able to format the harddrive using windows utility such as XP Bootable CD or 98SE.
Hope this will be helpful to you.
Oct 25, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
Seagate (ST3160827AS) 160 GB Hard Drive Logo
90 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
